Old 05-16-2016, 09:41 PM
grandville455's Avatar
grandville455 grandville455 is offline
Originally Posted by 68greenbird View Post
Nice work, did the track hold ?
The track is unbelievable, and only going to get better! I just need to find optimum launch rpm and tire pressures yet. Thinking it likes the higher rpm's but so hard to hold it on line, and it raises car loosing front end travel to get weight on back sooner too.. might be better to go lower and flash it harder to hit tires harder..
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 05-16-2016, 11:13 PM
Mikes455Wagon's Avatar
Mikes455Wagon Mikes455Wagon is offline
So are you thinking you might need a converter tweak now? Just curious.
Old 05-17-2016, 10:18 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I noticed this when I watched your video. It comes up in the front and back. I'll check some of my videos but I'm pretty sure mine doesn't move when I stall it up to 2500.
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
Old 05-17-2016, 10:23 AM
Curious George's Avatar
Curious George Curious George is offline
Awesome! I never made it there n/a, but I'm confident you will.
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
