Old 08-30-2017, 04:24 PM
SD Formula's Avatar
SD Formula SD Formula is offline
SD Formula, Really nice work thus far. Grey colored springs are correct, or you may want to sand blast and apply the RPM (Rust Prevention Magic) that Bentwheel Bob is using on the restoration of his '72 455HO Formula in the '70 - '73 Firebird section.
Dennis
Thank you for your quick response, I will pass it along to MFG. The springs are from Eaton Detoit Spring and have a heavy coat of lumpy blackish material on them. It will be hard to remove, and I'll CK out BWB HO!
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth!
  #62
Old 09-06-2017, 10:12 AM
SD Formula's Avatar
Hey guys I could use a little help on Spring identification. Does this spring look like a 74 FB front spring. It is suppose to be and Eaton Detroit 455 SD spring, 18 and a half inches long. It is really hard to get compressed and into place. Any suggestions?Click image for larger version
  #63
Old 10-08-2017, 11:38 AM
SD Formula's Avatar
Default Bolts & more pictures
The exhaust manifold to cylinder head attaching bolts, black phosphate or cad?
ID:	464975   Click image for larger version
  #64
Old 10-08-2017, 02:37 PM
SD Formula's Avatar
Default SD EX. Flange
Does this look like an original SD 455 exhaust manifold to exhaust pipe flange?? Cast iron.
ID:	464986   Click image for larger version
  #65
Old 10-10-2017, 10:59 AM
SD Formula's Avatar
Anybody have an opinion on this or on the exhaust manifold bolt finish?
  #66
Old 10-10-2017, 12:52 PM
SD455DJ SD455DJ is offline
Yes it does...cast iron.
Dennis
  #67
Old 10-10-2017, 12:57 PM
SD Formula's Avatar
Thank you Dennis. Any comment on the SD exhaust manifold bolts?
  #68
Old 10-10-2017, 03:07 PM
SD Formula, My guess is cad plated, but I'm not the expert. Hopefully someone with more knowledge than I will chime in.
Dennis
  #69
Old 10-10-2017, 05:32 PM
SD Formula's Avatar
Dennis
Thank you. I had the original bolts replated cad, but started to think maybe that wasn't the correct finish.
  #70
Old 11-05-2017, 12:05 PM
SD Formula's Avatar
Recently the temperature and humidity in Florida has become more suitable for the painting process. The body and other sheet metal parts have been prepped for paint for over a month now. Here's some photos of brown oxide and Honduras maroon painted parts.
ID:	466939   Click image for larger version
ID:	466940   Click image for larger version
  #71
Old 11-05-2017, 12:50 PM
SD Formula's Avatar
More
ID:	466951   Click image for larger version
ID:	466952   Click image for larger version
  #72
Old 11-05-2017, 01:18 PM
SD Formula's Avatar
More
ID:	466956   Click image for larger version
  #73
Old 11-05-2017, 11:29 PM
SD Formula's Avatar
Tags
Name:	2017-11-05 22.10.38.jpg
ID:	467029   Click image for larger version
Name:	2017-11-05 22.01.23.jpg
  #74
Old 11-06-2017, 04:41 PM
SD Formula's Avatar
More
Name:	2017-11-06 15.32.38.jpg
ID:	467083   Click image for larger version
ID:	467084   Click image for larger version
ID:	467085   Click image for larger version
  #75
Old 11-14-2017, 10:06 PM
SD Formula's Avatar
Default Here is something a little different
MFG, my super duty restorer runs a one man backyard shop with one part time helper for cleaning, sanding, bead blasting, etc.
He almost exclusively, does start to finish Restorations.
His most prolific work has been on 53 through 67 Corvettes of which he has restored approximately twenty five.
All have been NCRS Top Flight and or Bloomington gold certified.
In addition he has performed Restorations on many 55 thru 57 Thunderbirds, 55 to 57 Chevrolets, Shelby GT 500 & Mach 1 Mustangs, 1st generation Camaros, & British sports cars, to name a few.
When he is not working on restoring cars he restores his own automobile memorabilia such as gas pumps, signs, & other service station equipment, Coke machines, jukeboxes, Whizzer motor bikes & other cool stuff.
He has one of the largest spark plug collections in the US.
Here are a few photos from his museum.
File to big more in next post!
  #76
Old 11-14-2017, 10:38 PM
SD Formula's Avatar
Default Museum
Sorry about the rotation of some photos.
Name:	2017-11-14 21.27.44.jpg
ID:	467760   Click image for larger version
Name:	2017-11-14 21.29.47.jpg
  #77
Old 11-14-2017, 10:46 PM
SD Formula's Avatar
More
Name:	2017-11-14 21.42.13.jpg
ID:	467763   Click image for larger version
Name:	2017-11-14 21.42.46.jpg
  #78
Old 11-14-2017, 10:56 PM
SD Formula's Avatar
Not exactly on the subject of my SD restoration. Let me know if you like to see any more of the Museum stuff. Even if it's sideways!
Here's a real rare and unusual gas pump. from the 1930s. I think!
Name:	2017-11-14 21.40.32.jpg
  #79
Old 11-15-2017, 01:58 PM
SD Formula's Avatar
More pix
ID:	467816   Click image for larger version
  #80
Old 11-17-2017, 06:53 PM
SD Formula's Avatar
Today the body was removed from the rotisserie and moved to the lift where the differential and rear suspension will be attached.
The upper dashboard area will need to be painted before the windshield is installed.
Date coded windshield & side glass has been ordered. Reproduction rear, shaded, heated glass does not appear to be available. Luckily the original rear glass is in good shape and the heater function works.
ID:	467953   Click image for larger version
ID:	467954   Click image for larger version
