#61
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
#62
Me
![]() It's not that repairs are not allowed - it's just that they need to be of good quality. NZ went through a period of time where cars were being imported that were cut and spliced or just poorly repaired. These were ending up on NZ roads and then disentegrating in accidents. We knew what we would be facing so none of this is a suprise.
Peter 1974 Trans Am, 400 4-speed, 3.42 rear.
#63
Interesting Thread!! We are headed over there in June(hopefully), my son & daughter in law live in Palmerston North. We will be there 3 weeks
#64
The repair certifier has looked at the car and the quarters have to come off and be replaced. I have been working with a restoration shop that can do the work - we are just in the process of sourcing quarters and determining what panels we are going to use for the rework.
#65
" Long may we DRIVE !" |
#66
No rot that would warrant full quarters.
The welds need to meet a certain standard and they don't try to ascertain that with the welds that are already in place. The repair certifier requires the quarters to be removed, the body alignment checked, then the quarters replaced with the closest 'full' NOS or new repro quarters along with new outer wheel houses and trunk dropoffs. All of that work needs to be done by a certified repairer/welder (I can't do it myself). Then the repair certifier inspects and signs off on the bodywork prior to paint/sealing and then again after that. And the panels needs to be shipped from the US of course.
#67
Welcome to New Zealand !
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following 3 Users Say Thank You to b-man For This Useful Post: | ||
#68
This seems like an employment drive. Factory spot welds were increased in power for the 1973 model year for safety. ( this is why 72 strike cars and shells could Not be used)
Why can't your quarters get additional spot weld or even put that panel back on? This is beyond being scared of junkers on the road. They see an old car and see this>>> $$$$$$$$ I see 15k or more of work, in your location, and maybe not match paint. Too bad you can't enjoy it.
#69
Like I've said throughout this thread - there's no surprises here.
#70
Finally sourced all of the panels and they are in LA waiting to go onto a container - will likely be 3 or 4 months before they arrive here.
Got full quarters, trunk extensions, outer wheel houses, rear seat floorpan, door skins and rear torque boxes and spring perches. Hopefully that's the bodywork covered.
#71
The torque boxes dont fit that well. Have to beat them into submission. Also the rear seat belt "nut" welded on the new Torque Box is ROUND. Your car may still have the rectangular "nuts" These can be swapped over.
Good luck!
#72
With the body panels being 3 to 4 months away, I'm going to use that time to tackle anything else that might cause problems with the certification process. I had a local shop here put the car up on a lift and go over everything in the suspension. Ive ordered a center link and idler arm as there was some play in both. Also ordered all of the bushings and insulators for the rear end. Those parts are all shipping air and should be here in a couple of weeks.
#73
Your rear anti sway bar shouldn't be so tight that it doesn't move. Lube the bushings too! Good luck!
#75
I had a minor win with the windsheild washers today. Requirements here say that if the car is fitted with them, they must work - and I've not used them once while I've owned the car. After some contact cleaner and a new o-ring kit they sprung into life and work perfectly. First time they've had washer fluid through them in at least 20 years.
All of the other parts I ordered arrived safe and sound from the US via Fedex. Shipping costs weren't too bad and it's nice to know that I can order parts from RockAuto and get them here relatively quickly.
| The Following 2 Users Say Thank You to pontiacstogo For This Useful Post: | ||
#76
Yay - all of the body panels are on their way. Scheduled arrival date is MUCH sooner than I expected - everything is supposed to arrive on 4/28!
I've got a hell of a lot to do prior to the body panels arriving. Plus I need to get together with the shop that's doing the panel work find out what they want me to remove (or leave) on the car prior to them starting the work.
#77
So much for 4/28!
The container has FINALLY been loaded onto a ship bound for NZ. Short of it sinking, it should be here on 6/13. I hope to have the panels picked up and the TA underway at the bodyshop by the end of June. While I've been waiting for the body panels, I've got the windsheild washer working and replaced subframe mounts, leaf spring bushes, transmission mount and sway bar bushings. I've got engine mounts and control arm bushings to go. Last step will be to remove the interior (everything except the dash and kickpanels). It's a process!
#78
I have to ask, are you wearing a mask during all of this?
#79
Dropped all of the sheetmetal off at the body shop today. Weird that one door skin was boxed and one wasn't.
| The Following User Says Thank You to pontiacstogo For This Useful Post: | ||
#80
For anyone still following along..
Stripped the interior so that the car can be shipped to the bodyshop next week. I offerred to remove some of the exterior stuff too but the guy doing the work asked me to leave everything on so that they can check it all for fitment once the panels are replaced.
