Old 04-02-2022, 07:37 PM
Joe's Garage Joe's Garage is offline
Go to the main page of PY.
Scroll down to the bottom.
Left side.
There is a box that says 'Responsive 2017'.
Click on it and choose 'PY Online 2015'.
Your format will change to the 2015 format.
Now you should be able to Post, Reply and Send Messages.
You MIGHT need to click on one of the 'Smilies' to get the text to start without FB crap.
Good luck!
  #62
Old 04-02-2022, 08:43 PM
jamesq's Avatar
jamesq jamesq is offline
Thanks, it worked!
Is there a way to set the 2015 as default?
When I logged out and then back in, I was back to 2017 version.
James Q
James Quayhagen
  #63
Old 04-02-2022, 10:03 PM
I guess because I’ve been using the 2015 version for quite some time I haven’t experienced any issues.
Thanks for posting this thread, an easy fix.
I’m still wanting our forums admin to find out just exactly what’s corrupting the forum software.
  #64
Old 04-02-2022, 10:05 PM
Stuart's Avatar
Stuart Stuart is offline
I just temporarily switched to the 2017 version and it still works okay for me. It may be dependent on your computer and browsing software - I have a MacBook and use Safari.
  #65
Old 04-02-2022, 10:18 PM
fyrffytr1's Avatar
I am having the same problem, using Firefox on Windows 10. Went back to the old version and it works.
  #66
Old 04-02-2022, 10:20 PM
fyrffytr1's Avatar
Originally Posted by jamesq View Post
Thanks, it worked!
James Q
I don't log out. I just close my browser. When I open PY back up it is the older version.
  #67
Old 04-02-2022, 10:22 PM
fyrffytr1's Avatar
I just noticed that I don't have to go back to the main screen to see what version I am using. It is in the bar on the bottom left of any page I go to. There is a drop down menu showing all options.
  #68
Old 04-02-2022, 11:27 PM
tooski tooski is offline
I have found that if I click on 'Reply with Quote' the new window/page appears. As I scroll around, the cursor changes from the arrow to the finger point hand. The bottom of the page then shows it is a link to facebook. If I then click, it does take me to facebook. Clicking when the cursor is an arrow, nothing happens. I am on 'responsive 2017'.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
  #69
Old 04-02-2022, 11:41 PM
Default Try this.
Left side.
Good luck!
The Following User Says Thank You to Joe's Garage For This Useful Post:
  #70
Old 04-03-2022, 01:04 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Thank you! The 2015 version is working for me.
  #71
Old 04-03-2022, 05:34 AM
chuckies76ta's Avatar
Default Facebook
Click on some links on P/Y and you end up in Facebook. Anyone else? Has blank boxes that direct you to Facebook.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
  #72
Old 04-03-2022, 05:38 AM
JSchmitz's Avatar
JSchmitz JSchmitz is online now
Look at this: https://forums.maxperformanceinc.com...d.php?t=857745
The Following User Says Thank You to JSchmitz For This Useful Post:
  #73
Old 04-03-2022, 06:36 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Lovely, every time I try to answer a PM it takes me to Facebook......
  #74
Old 04-03-2022, 07:37 AM
Stuart's Avatar
If you're having weird problems with getting redirects to Facebook when using the forum, try changing your view: scroll down to the bottom of the screen, and in the lower left there is a little window where you can select different methods of viewing the board. The problem appears to be related to using the "responsive 2017" format. Change it to one of the other options and try again.
  #75
Old 04-03-2022, 08:08 AM
242177P's Avatar
242177P 242177P is offline
If you're having weird problems with... The problem appears to be related to...
There wasn't anything wrong with Responsive 2017. The problem is Facebook.
  #76
Old 04-03-2022, 08:51 AM
mgarblik mgarblik is offline
I do not have a Facebook account and never will. However, about 1/3 of the threads on the forum divert to a Facebook opening page when chosen. I have switched to the 2015 view as instructed and it seems to work ok. Way, way above my pay grade to know what caused this or how to fix it. Good luck to the mods and administrators.
  #77
Old 04-03-2022, 08:52 AM
gman005's Avatar
gman005 gman005 is offline
I am having the same problem as Cliff.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport. RIP
75 Grandville Convertible.
  #78
Old 04-03-2022, 08:59 AM
Longs's Avatar
Longs Longs is offline
My assumption is that whoever was able to access the PY coding did so with the "Responsive 2017" version enabled and may not have even realized there were other versions of the site.
i also don't assume that because the redirects are to Facebook that it WAS Facebook who did it, could have just been a random, annoying choice, or some way to harvest Facebook logins by tricking people into thinking they had to log into Facebook.
The Following User Says Thank You to Longs For This Useful Post:
  #79
Old 04-03-2022, 09:09 AM
No issues here on I Pad, have always used 2015 version.
  #80
Old 04-03-2022, 09:47 AM
misterp266's Avatar
Exactly!
" Darksiders Rule "
