Old 01-18-2023, 07:40 AM
Cliff R's Avatar
Cliff R Cliff R is offline
I found this picture which should help. It shows how much different a spread bore intake pattern is to a square bore. All of the Edelbrock AFB and AVS clones would be square even if they happen to bolt up to a spread bore intake using the dual bolt pattern.
The Following 2 Users Say Thank You to Cliff R For This Useful Post:
Old 03-17-2024, 04:44 PM
Rob in NH's Avatar
Rob in NH Rob in NH is offline
It runs really good, no problems with cold or hot startup. I did have one hiccup and that was one of the floats stuck open . It was set wrong from the factory, Shaker 455 came over and set it all up for me , he really knows about everything to do with carburetors of all kinds, highly recommend him for this work.
Old 03-19-2024, 11:29 AM
sportylemans sportylemans is offline
Thanks for the update. What model #did you go with?
Old 01-18-2023, 07:53 AM
Cliff R's Avatar
BTW, if you don't think cheap sells with this hobby consider this. WAY back when Edelbrock discontinued their line of 1901-1910 Q-jets and destroyed the molds I contacted them about it. An employee at that time on the tech line told me that it was purely a marketing decision.
They were selling apprx 1 Q-jet to 30,000 of their 600cfm Performer Series AFB clones. At that time the entry level Performer series 600cfm manual choke units were a tad over $200 and the Edelbrock 1910 850cfm units were closer to $500. Even though the 1910 is superior to the Performer AFB in terms of performance and efficiency they just didn't sell because of the price.
Edelbrock was also shooting themselves in the foot with the Q-jet offerings because it wasn't going to get them a matching intake manifold sale as the end user could put them on stock spread bore intakes.
So like many this associated with this hobby it's going to boil down to money (or being "cheap"), not how good something is or how well it works.........FWIW......
The Following 3 Users Say Thank You to Cliff R For This Useful Post:
Old 01-18-2023, 08:52 AM
chiphead's Avatar
chiphead chiphead is offline
I also think the target market doesn't understand any of these differences between a well done Q-jet and a cheap AFB clone. The AFB is shiny and new and it'll make the car run, so SOLD. They have no idea about tuning.
On the car I just bought, the PO slapped a QF 850 double pumper and RPM intake on a warmed-over 400. It ran rich so he swapped it with a QF 750. It still ran rich, fouled plugs, wouldn't idle, etc. I found that the idle mixture screws were closed, the fuel level was too high, the choke was wound tight, the fast idle cam was totally out of adjustment, the pumpers were out of adjustment and a leaking vacuum plug.
I'm always amazed that people think you can take a carb out of the box and slap it on without tuning it. I'm also amazed how many people think the idle mixture screws affect the cruise mixture. I'm boggled.
The Following User Says Thank You to chiphead For This Useful Post:
Old 03-19-2024, 01:07 PM
Rob in NH's Avatar
The Following User Says Thank You to Rob in NH For This Useful Post:
Old 03-19-2024, 11:48 PM
chiphead's Avatar
If you don't want to build a Q-jet, and you're not running a spreadbore only intake, a 750cfm vacuum secondary 4150 is likely the way to go. Set some proform metering blocks up like a classic holley, install the quick change secondary spring kit and go to town.
Old 01-18-2023, 09:33 AM
Cliff R's Avatar
Below is some information I've exchanged with folks who are experts in their field when it comes to aftermarket carburetors and carburetor tuning (they do it for a living).
Before I retired I woudn't share this information because it looks like I'm trying to "bash" the competition to steer work in my direction. In any case, a couple of comments below from folks with EXTENSIVE experience with these things:
"The magazine and the tv hot rod shows do not want to feature anything that does not tell the tale they wish to promote. I have done some work with the new Edelbrock AVS2 carbs with the annular boosters that the media say is great but when I replace the primary boosters with a standard booster the car runs way stronger, so much for believing the media."
"I am backdating most of the newer holley idle wells to 0.106" since most newer holleys have an idle well that is formed with a tapered core plug and I always place the idle jet in the lower position. The people I knew at Holley had sent me a prototype of the 750 cfm ultra series carb that was built by Bo Laws and it was very nice but once they brought the production in house it was not as good as the Bo Laws unit. The idle jet is longer than the one Bo Laws used thus it either sticks out of the passage on the gasket side or out into the idle well which restricts the flow. I either shorten a new idle jet or install an allen head jet that I drill to size. These changes cure the lean off idle problems we see with most newer Holleys"
I shortened up the emails but I think anyone reading them can get the drift. Instead of correcting design flaws with their products these companies just continue to dump them on the market. At that point if the end user isn't happy with it he's either got to become a carburetor expert or hire one to end all the drama. Not a bad deal if you have a part-time gig on a picnic table in your back yard and know where to go in and make the needed changes to get that junk up to par. I started my business in similar fashion. I used to work on ALL types of carburetors until they got piled up too deep around here. Then I decided to pick one type and stick with it, which was a very good business decision. I still turn down at least a dozen jobs a week and I closed down that part of the business over a year ago!.........
Old 01-18-2023, 11:17 AM
Jay S's Avatar
Jay S Jay S is offline
Interesting stuff. Seems like I recall the annular boosters on the AV2 loose about 50 cfm against the regular boosters like a AFB. At some point of performance you will notice that, but that will never show up on a stock 350. IRC, some guys pull the boosters on the AVS2 and put regular booster in them? The AVS2 is popular for the 68 to 71 Mopar’s that ran the original AVS. I have a tunnel ram combo I am working on I was thinking about using an original Carter AVS carb, probably not a AVS2.
Our experience has been you can take about any aftermarket 600 cfm carb to replace a 2 bbl and you will be blown away by the power increase and probably run just fine, improvement over and old used 2 bbl in pretty much every direction. It is only after a year or two and run some fuel thru the new carbs and all the poorly mfg’s parts inside the carb comes unraveled you realized what the expert carb guys where taking about.
But you do not always get that lucky. We have a nearly new Holley 750 Ultra that we bought cheap because it wouldn’t it run right on a friend’s 383 SBC 430HP engine. Speedway motors shop in Lincoln,NE worked on it, even had it on the dyno, eventually said it was “too big”. The guy just thru money at stuff and hires projects out. So he switched to a smaller Holley street avenger, it didn’t run right. Then he put a FI tech system on it. That didn’t work for him either. LOL…He ended up with a qjet on it! Another friend bought the basically new $800 Holley 750 ultra for $200. His q jet on his 455 was running terribly rich. So we helped him try the Holley. Basically new yet, it ran like total crap. Took it apart and had huge jets in it like it was an 850, jetted into the 80s.. Appeared the previous tuner was trying to mask a problem it had. We spend a good part of the day messing with the ultra and never could get it to run very well, seemed like it was missing 50 HP. Out of desperation we took the top off the qjet and Jet’s upgrade, the adjustment screw holding the primary metering rods had cam undone. Tightened that up, and pulled the ultra off and put the jet qjet back on, it felt like we gained 50 HP. Still have no idea what is wrong with the 750 Ultra. I was able to tune it so it at least runs well cruising. Full throttle though that new carb still has something very wrong.
Old 02-01-2023, 10:18 PM
Tom Vaught's Avatar
Boost Engineer
Lots of bad info out there.
Each Annular Booster loses 5 cfm so a 20 cfm loss. PERIOD.
Tom V.
Old 02-02-2023, 12:19 AM
Jay S's Avatar
Thanks Tom. There are only annular booster on the primaries, so at most 10 cfm, and they do not look very restrictive to me. I think the annular boosters were a pretty decent improvement.
On the fuel line routing you can move the inlet to the from the right side to to the left side on the carb and run a factory line for a 389 and an AFB. Not an exact fit but much better than routing the line to the back corner of the carb.
ID:	606509   Click image for larger version
The Following User Says Thank You to Jay S For This Useful Post:
Old 01-18-2023, 04:56 PM
Cliff R's Avatar
"Many of the folks here (Cliff for certain, I don't know about Kenth) are retired, and as Cliff stated "have no ax in the ax fight (or maybe it was "dog in the hunt), same cliche". I should have retired two decades ago, but having difficulty finding a buyer for the business (looks like son will take over part of it)."
Jon, here in these parts it's "no ax to grind and no dog in the fight", but still pretty much the same thing......
Old 01-18-2023, 05:54 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I have motors with just about all of the choices out there . Qjets, Holleys AND dual Edelbrock clones on my 470' 409. Can't say to Cliff's long term issues but 25 dyno pulls tweaking rods/jets as well as lash and timing I think they did OK
they were not OK out of the box. float levels not even to Edelbrocks specs. A step leaner jets also.
Name:	409 dyno pull.jpg
ID:	605457   Click image for larger version
Name:	409 dyno #23.jpg
Skip Fix
Old 02-02-2023, 08:40 AM
64speed's Avatar
64speed 64speed is offline
again I will probably get flamed for this but the Quick Fuel brawler has been great for me and easy to setup
Old 03-20-2024, 06:45 AM
Cliff R's Avatar
"I should have retired two decades ago, but having difficulty finding a buyer for the business (looks like son will take over part of it)."
Same problem here. Have had a couple of "tire kickers" take a look at the business but never got close to a sale. The last one just kept asking questions and taking up WAY too much of my time. It appeared to me that they were just looking for information to start a business on their own without buying mine....good luck with all that.
I decided to close down the rebuilding/restoration portion and just sell parts. Was hoping that was going to be a part time gig, but it's worked it's way into full time and growing bigger by the day. I'm also turning down at least 10 jobs a week, sometimies double that number, so there is still PLENTY of work out there despite it being 2024 and quite a few more options for carburetion/fuel delivery have been added to the market.
I'll add here (keeping in mind I have no dog in the fight) that hardly a day goes by I don't get a call from someone who went down the fuel injection (electric carburetor) path and absolutely HATE them. The Sniper seems to get the most complaints, seldom here too much about the others, but it's ALWAYS the same thing. The love it at first, and after multiple issues and failures occur they want to amputate the entire system and go back to a carburetor.
Personally, IF I were to ever look at any sort of "upgrade" from a carburetor it's going to have 8 bungs in a single plane intake with 8 injectors spraying toward the intake valves, not a "wet flow" TB type set-up, especially with a cold intake manifold. The factory couldn't even get that deal figured out and ditched all those systems by the mid-1990's, and for good reason. With a dry flow intake and individual injectors it's just going to be a LOT better everyplace for the end user.....IMHO.......
