#61
Eric
| The Following User Says Thank You to Elarson For This Useful Post: | ||
#62
Thank you for the info. I'm another one who looks. Wonders why someone is doing certain things. I've read reread alot of articles. Have Herb Adam's book on 'Chassis Engineering'. On my 73 F drag car I modified the front spring perches according to Herbs ideas trying to increase anti squat.
#63
Sounds like a nice setup. What gears in the 9"?
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#64
3.55. Should be good for about 140 mph at 6500 in 4th
Eric
| The Following 2 Users Say Thank You to Elarson For This Useful Post: | ||
#65
Seriously with 3.54:1, the OD allows my combo to do 2500 @75, but the standing pull from 65 to 90+ mph is like the pull of a 1/4 mile run, actually the butt and other cognisant cars make it compelling to suggest;
If you got a 455 in a road race, you might want to reach for an OD gear shift.
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
#66
Should be a good combo. Always like cornering , autocross my 78 with road race slicks for quite awhile.
Back when my '78 TA had the stock 180 HP motor TH350 took it to a track day at Texas World Speedway with the Porsche Club. With the 2.56s I could run most of the road course in 2nd, but on the long straight the motor would only pull 4000 and that was all it had-still 130mph And the stock springs at that speed felt like Grandma's Cadillac over bumps! Way soft.
#67
Agree! Engine should easily be capable of many 140 MPH / 6500 rpm (4th gear) pulls in a 20 minute session, based on the description of the build.....
Between Skip, Myself, and now you, Eric, there is not much Road Race experience out there. Tom V.
| The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
#68
Eric
#69
Nice build by the way, Should be a lot of fun. GT |
#70
it really means and I too am trying to learn all I can. Didn'tmean to hyjack sorry. GT |
#71
Here is a good read on the subject. https://suspensionsecrets.co.uk/anti...lift-geometry/ anti squat would be the tendency for the rear of the car to resist compression. Why you want this in a road race situation is the fact that as the rear squats, while it does add traction at the rear, it unloads the front, reducing traction on your steering tires. this will typically result in a tight exit on power from the apex. Anti dive does the same thing, but at the front of the car under braking.
#72
Eric
#73
Yes you know the mind thinks I can. Taking that 74 shell and using it for a road race car using Herbs ideas. Problem $$$$ for the needed dry sump(I just think it is insurance but probably not needed),then the best brakes(when i was young didnt think much about them other than they are there), then the engine best parts$$$$. So car body may go down the road. I have the original 74SD TA, the put together 73 SD drag car,a 10k 67 400 4spd ,4.33,RA. Firebird. And my sitting 63 Lemans,(326 3spd long gone) project. 57 olds,400 m40. At 75 I'm seriously thinking selling the shell.
#74
Herb Adams and Tom Nell did stuff for reasons. PERIOD.
They installed a Cheater oil pan/ Dry Sump Tank/and Camshaft Driven Oil Pump in the engine and F-body. If you have never had any road race track time on a vehicle ), your money might be better spent on your other "collection" vehicles. The Vega/Astre body would not be my 1st choice for that adventure. Tom V.
#75
It's been awhile since the last update. Engine and transmission are finally in the car. Wilwood manual brakes are installed, plumbed and bled. I had an adapter plate made to solve the problem of the missing accessory mount hole on the hi-port heads. Next step is wiring and plumbing. Then build a custom air filter housing for the shaker scoop.
Eric
#76
Nice, that missing bolt on High Ports can kinda be a issue. I wish they had it in.
I am using the stock alternator adapter like you are. What I did was drill and tap a hole in my 3/8" thick elephant ears to get it done. I wonder why KRE deleted it. |
#77
Eric
#78
Looks good Eric. I noticed you have a heater hose block off cap on the timing cover. Not sure if you have a use for that fitting but if not it can be tapped for a 3/8 pipe plug.
Everything looks great! |
#79
Eric
#80
The Firebird is finally on the road today. Open headers so all the neighbors could experience it with me. This thing is rowdy! Gobs of torque, even off idle.
It still needs work...exhaust system, parking brake cables, front alignment, adjust front ride height up a little. It's up on the lift now. Eric
