Old 04-14-2025, 08:20 PM
Back from being wal-nutted on the fronts and blasted blasting on the back...
Journey continues... Click image for larger version
Sent from my SM-F721W using Tapatalk
  #62
Old 04-20-2025, 06:20 PM
wth is the "wheel cap lock set" and do I need that too?
shopping around for rings/caps/lugs but wasn't aware I needed anything else.
Old 04-20-2025, 07:17 PM
chuckies76ta's Avatar
If you’re looking at caps for honeycombs there is no locking cap. They just snap in The trim rings snap in also.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
  #64
Old 04-24-2025, 07:49 PM
Oh ok... Then what the heck are these fer?
Old 04-25-2025, 03:59 AM
Sorry I’m not sure what they are. Hopefully someone can chime in.
950 Quickfuel.
  #66
Old 04-25-2025, 06:57 AM
foxgapLeMans foxgapLeMans is offline
What am I looking at, need a pic
  #67
Old 04-25-2025, 07:02 AM
I found a local shop with a lug centric balancer, the car goes in on the 9th for a front end alingment and he is going to rebalance the wheels at that time. Right now they were done on a bubble balancer, really looking froward to feeling the difference.
  #68
Old 04-25-2025, 10:35 PM
These https://www.jegs.com/i/OER/691/9773569/10002/-1
The GM stealership can do mine here allegedly...hopefully they will price match the tires
Old 04-26-2025, 11:01 AM
78w72 78w72 is offline
Based on the description, these are just an anti theft thing, says it keeps the clips from retracting so the caps cant be stolen... not required for installation.
Also says "70-81 honeycombs" but HC's werent available after 76.
  #70
Old 04-26-2025, 11:12 AM
When balancing these or any wheels, ask if they do dynamic balancing over the basic static balancing. Static only puts weights on the back side of the wheel where dynamic puts weights on the back and the front of the wheel.
But for most these classic wheels, weights on the front lip of the wheel looks bad and can cause corrosion where the weights are, most shops will have tape weights that can be attached from the inside towards the front of the wheel keeping weight off the visible front face of the wheel.
On every car Ive owned from classic to daily driver, the dynamic balance is far better than the basic static balance & shouldnt cost any more. Bubble balancers are better than nothing but also only do a static balance and usually not as accurate as a real wheel balance machine.
  #71
Old 04-26-2025, 12:15 PM
burd burd is offline
Stopped by to se a bud on Thursday, he has 4 - 15” honeycombs stacked up in the garage. lol.
  #72
Old 04-26-2025, 12:33 PM
Everything at yer fingertips in Detroit rock city...
Old 04-26-2025, 12:34 PM
Ok apparently illiterate...thx
added to cart...this mini restoration may make it worth my while
rings back-ordered...natch
Old 04-27-2025, 09:57 AM
Anyone have an idea of how those wheel cap locks mount? Looking at the pic I cant see how they mount or stay in place on the back of the wheel, unless they just press in & are held in by a lip or part of the metal in the back area of the center hole? Dont see any other hardware to mount/secure them.
If youre getting the repro caps at $75-100 for all 4, Im not sure they need an anti theft device, doubt anyone will steal the repro caps at a car show or in your garage. Might be worth asking jegs for more installation info. Also once you get the caps you will see they are somewhat hard to install because the clips are very firm and once installed its takes quite a bit of effort to remove them from the front. Just a heads up to help decide if they are really needed for repro caps on classic cars that are rarely left unattended.
  #75
Old 04-27-2025, 10:04 AM
I don’t think he’s going to use them, there’s another guy by me, some prob know him, he’s been selling off his SD collection, he has 2 sets, all restored. W/ nOS rings and caps. He had the car w/ the sunroof in. Barry is selling restorable sets for 800 (4). Not cheap anymore.
I had 4 crappy caps that shoulda been flung in the woods, some guy at Dayton wa happy to get them.
  #76
Old 04-27-2025, 11:18 AM
Too late for me...everything on the way from Jegs/Gina
I guess I'll find out but still have to paint the wheels of course...
Old 05-22-2026, 10:30 AM
slow updates...
walnut blasted, primered, mounted, going to finally paint the fronts
ID:	670718   Click image for larger version
  #78
Old 05-22-2026, 10:35 AM
new meats...sorry, wife dropped pone and broke my only cam
ID:	670720   Click image for larger version
Name:	Selected photo.jpg
Old 05-22-2026, 04:21 PM
Held for Ransom's Avatar
I wonder how the OER paint matches to the OEM Paints from YEARS ago?
So long, farewell.
  #80
Old 05-22-2026, 04:29 PM
Might weigh one of those big honking things.
30 lbs a piece with trim ring & center cap?
