Tim. Are these the Johnson Short Travel Lifters? Sorry to see this happen to you.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
I may be wrong, but think pins usually don't walk out without the lifters being hammered.
Yeah this does suck, sorry to see this bud. .
I should add that these lifters are not from current production. There were purchased around 10 years ago and sat on the shelf and just recently installed.
Tim Corcoran |
That shouldn't matter
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
Paul
The reason I mentioned that was I didn't want to discourage anyone from buying Johnson Hyd Roller lifters because they are an excellent product. Not sure what happened to mine but if it was a manufacturing defect it was from a long time ago.
Tim Corcoran |
Tim - can you advise the valve spring pressure open and closed, assuming you have that?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
Have you thought about sending that piston to Ross/Butler for eval? A touch of blending still "might" be useable
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
| The Following User Says Thank You to Formulas For This Useful Post: | ||
For one thing the damage is right inline with the wrist pin. This is a high stress area when the piston changes direction. It was hit hard enough that I am unable to rotate the wrist pin with my fingers. I'm sure it could be honed but was it weakened because of the deformation? I don't know and not sure I want to take that chance.
Tim Corcoran |
Tim - for your rebuild you might consider Gaterman Products lifters, their p/n GP1008.
This name will be new to the Pontiac crowd, but Bill has been engineering/building lifters for a long time. Hit their website and read the complete FAQ section before purchasing. He provides interesting info. I have two sets in service right now (462 stroker with a Bullet cam and 400 standard with an LSM cam). Both are noise-free and zero performance issues. I like the three supply holes Gaterman incorporates in the lifter body. Just an alternate option to consider. Good luck on the rebuild. |
| The Following User Says Thank You to JEC3039 For This Useful Post: | ||
Tim Corcoran |
If the pin is pinched then the ring lands are off kilter also.
Even if the pin hole could be honed your not going to be able to do anything about the ring lands.
That would be nice.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
I would think Butler Performance would certainly have some clout with Ross. But, I had to order 4 pistons to get one and a L O N G lead time too.
Tim Corcoran |
I set these heads up myself so I was pretty sure spring pressures and coil bind were good. I just double checked one intake and one exhaust valve. PAC Beehive Springs, spring pressure were set up per Johnson's recommendations.
Lunati Cam dur @ .050 219/227 lift at .050 .515/.530 Intake seat 190 open 384 coil bind .152 Exhaust seat 190 open 392 coil bind .133
Tim Corcoran Last edited by Tim Corcoran; 05-01-2025 at 02:10 PM. |
190# seat? Is that typing error?
Should be 135# ish with a beehive and that cam |
Just coming full circle on this, I exchanged emails with Bill Gaterman yesterday and he confirms there are no Pontiac/Olds GP1008 lifters in the inventory system at the moment (all sold out). Will have some in roughly two months.
Obviously he's not high-volume with these. Harley-Davidson and Chevrolet and Ford will always get first attention I suppose. |
Was looking at that as well. My heads were setup for .593 lift with Johnson ST's 145 on the seat and around 360 open. Pac 1903's.
I'm reading that as 190 open???
No where close to enough |
I got mine through PBM/Erson Cams in Louisville. (800) 588-9608. Contact there was Gary. Paid $430 for each set (plus Michigan sales tax), one year ago.
I'm seeing it as 190 seat 384/392 open.... But we all went to different schools
| The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
