Old 07-23-2025, 12:24 PM
chiphead's Avatar
chiphead chiphead is offline
I ran the numbers through the diamondracing.net's calculator. I also looked up the CC of those 8-VR pistons.
Bore: 4.160 (40 over 400 bore)
Stroke: 3.75
.020 deck clearance (typical for rebuilder pistons)
14CC dish for the 8VR pistons (per several online sources)
100CC for 6X-8 heads
.039 gasket thickness
Compression Ratio: 7.5:1. as it sits
  #62
Old 07-23-2025, 04:08 PM
tooski tooski is offline
Stroke: 3.75
I measured my 8VR pistons at .039 in the hole on a stock (undecked) block. So CR would be even lower
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
  #63
Old 07-23-2025, 04:13 PM
Mikael, did you verify by casting/date number that the block is from 1973, or is that what the previous owner told you. I would double check.
Frank M.
75 Firebird
  #64
Old 07-24-2025, 02:29 AM
Mikael Nielsen Mikael Nielsen is offline
As per the previous owner..
I will double check tomorrow
  #65
Old 07-24-2025, 11:20 AM
I checked, and it's not from 73..
It's either from 74 og 75.
The small number from the code ends with a 4 I think, but theres a big 75 besides the distributor hole.
  #66
Old 07-24-2025, 11:44 AM
chiphead's Avatar
What is block casting number near bellhousing, behind passenger bank of cylinders? It will likely either be 481988 or 500557 cast into the rear of the block, facing upwards behind passenger bank.
The Following User Says Thank You to chiphead For This Useful Post:
  #67
Old 07-24-2025, 11:45 AM
It says 481988
The Following User Says Thank You to Mikael Nielsen For This Useful Post:
  #68
Old 07-24-2025, 11:50 AM
chiphead's Avatar
Good news, that's a thickwall block. Last of the good ones before the bean counters took 15-20lbs of cast iron out of the design.
  #69
Old 07-24-2025, 11:53 AM
Thank god.
Finally some good news 😅
Thanks for the help!
