| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
#61
A word on amc 20 axles is since they are 2 piece axles make sure you keep the axle nut tight. I think spec is 250 lbs.
66 Lemans build https://forums.maxperformanceinc.com...d.php?t=876235 |
#62
Ken, really like your Big Bad Orange Javelin and the low buck quick restoration to get it on the road again ,great job.
Rich Johns Owner/Operator of Pure Stock Auto Restorations Inc. www.purestockauto.com 1969 GTO Judge Ram Air IV M21 4 speed 3:90 1970 GTO Judge Ram Air III M21 4 speed 3:90 Oshawa Built 1970 GSX Stage 1 M21 4 Speed 3.64 # 67 of 678 Original Paint 1970 GSX Stage 1 Auto 3.64 # 603 of 678 [email protected] mph 2011 Buick GS Nats Pure Stock, [email protected] mph PSMCDR 2011 1970 GS Stage 1 Convertible Auto 3:64 [email protected] mph PSMCDR 2009 1970 GS 455 M21 4 Speed 3.42 1987 GN Astro Roof |
#63
In addition to that I pulled my AMC 20 axles and had them broached for a second key.
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
| The Following User Says Thank You to VCho455 For This Useful Post: | ||
#64
Inching closer. Got the remainder of the parts needed to finish up the engine this afternoon wrapped it up this evening. I even made a new decal for the Mallory coil. I had to go with the old school yellow Accel wires to go with the Mallory and Offenhauser gear. This car is so the opposite of my GTO.
Once I get the engine bay tidied up a bit and give it a quick fresh coat of Big Bad Orange, we'll drop the engine back in. The intake is sitting on top for now. I'll install it after we drop it in.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
| The Following 7 Users Say Thank You to Verdoro 68 For This Useful Post: | ||
#65
Why not install the intake before dropping the engine in?
Did the coil replace a lifting hook? |
#66
If so just use a carb plate
1972 GTO |
#67
Went to a Ford swap since it was the only thing to do, glad I went, lots of AMC stuff there, and memorabilia, and the Ford guys were really friendly compared to the GM swaps.
#68
Not sure about the coil and hook. That's where the coil was when we got the car. Do AMCs have factory lift hooks like Pontiacs?
#69
Ah - I do not know, you are now the resident PY guru on AMC's...
#70
If AMC went any higher with that oil fill tube you could have added oil without popping the hood. All kidding aside that’s a really nice looking color on engine.
#71
I know! I think it's the original tube, but it sure seems unnecessarily tall. It's not as in your face with the air cleaner on. The blue is kind of like if you mixed all the '64-'74 Pontiac engine colors together.
| The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
#72
I replaced the filler tube with a plug. Just too ugly. Oil fill through valve cover.
79 Trans Am WS6 71 Formula 72 Formula 71 Firebird 69 Firebird |
#73
Oldsmobiles were that way too - I liked the fill tubes as they were easy to use and no spillage, even back with cans. Just pop a couple holes and pour.
#74
I was hoping to have the engine back in by now, but we discovered that the car must have had an electrical fire at some point. The harness was obviously burnt with wires fused and bare in several spots. There were also some dubious repairs and junctions to critical areas. I'm sure this played a factor into why the car was parked so long ago. I'm honestly amazed it even cranked over.
Unlike a GM car, the harness is one piece so if the engine harness goes, you have to replace the wiring behind the dash. So, we pulled the dash and column which was probably for the best anyway since the car was covered with dirt inside. The driver's side kick panel was filled to the brim with sand and dirt. I don't know how it's not rusted out. With everything out of the car, I took the opportunity to freshen up the gauges, rebuild the steering column, replace the broken turn signal switch and give the engine bay a fresh coat of Big Bad Orange. I learned that several of the steering column parts are interchangeable with the '68 GTO and actually used some GTO parts I had laying around on the Javelin. The new M&H harness is awesome but eyewateringly expensive compared to a GM counterpart. New seat covers, carpet and door panels are en route. I'm still missing a headliner, which isn't reproduced, but my hope is things come together in a drivable state kind of quickly once I get the wiring and dash sorted.
#75
Nice work Verd
https://www.flickr.com/photos/197745168@N07/ "The biggest areas that have been a disaster moving from truth to subjectivity are academia (esp science), media, and law." |
#76
But not having to chase down broken wires, corroded connecters and the like is worth it. |
#77
My son is annoyed that I keep making everything nice. I can't take a part off without putting it back on in a better state. I want a decent interior and I like the underhood to look tidy. I told him we'll leave the exterior as is. I did get matching slotted mags for it though. The gauges and two tone dash are looking pretty cool. Here's a little before and after.
#78
Wow, that dash is impressive! Did you repair that tear in the vinyl or replace? If you repaired, your artist self is continuing to show off a little...
#79
That's just a spider web in the pic above, not a tear. The gauge bezel is hard plastic, like the dash shell. The shell had a good number of cracks that needed to be repaired, but the bezel was in decent shape. The soft crash pad on the other side needs a good bit of attention. I have some FiberFlex and filler from Polyvance on the way to try cleaning it myself after a $1600 quote from Just Dashes.
#80
Ahhh I see it now... well you still get an A+ for that.
![]() This all feels like martian dollars to me sometimes.. hope I die before I get old. |
