Old 07-12-2026, 10:34 AM
steve25 steve25 is offline
Pontiacs do not have quirky timing issues, it’s just that some builders or there shop help do not understand that on a Pontiac the drivers side bank of cylinders is in front of the passenger side bank, and also that the rotor spins the other way from a SBC or BBC motor.
Please note that for future reference that 180 degrees out means that number 6 will be at TDC, not number 8 as you posted.
This can save you a lot of troubleshooting woes possibly!
To double check that your at or very near to number 1 TDC you do not really need any tools, just your eyes.
When 1 is at TDC on the compression stroke the exh valve on number 6 will be open some depending on the Cam , so that exh rocker will have no slop to it.
  #62
Old 07-14-2026, 05:43 PM
ThreeNuts ThreeNuts is offline
OK, bumped up the timing to +3-degrees. Runs a hell of a lot better and the hot-start weird tiny knock is gone.
The Following 2 Users Say Thank You to ThreeNuts For This Useful Post:
