Old 07-19-2013, 09:15 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Just a heads up to all you other McCarty RA-V owners, you might want to check to make sure that none of the accessory bolt holes were drilled too deep. I have 1 hole in each head leaking water. Looking back at pictures taken on 3/9/2012 when the engine was unloaded from the delivery truck, it seems odd that when received from BES one hole was used for the water pump ground and the other didn’t have a bolt in it.
ID:	330266   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #782
Old 07-19-2013, 11:03 PM
Stan Weiss's Avatar
Or maybe during their visual inspection of the head they saw that it was not a blind hole and put a little sealer on the bolt threads and just continued on.
Stan
Pontiac Pump Gas List
  #783
Old 07-19-2013, 11:22 PM
RAIV-Z's Avatar
Stan
Maybe for the hole on the passenger side front, what about the driver’s side rear? This would have leaked when it was run on the dyno at BES.
Some sort of note indicating these 2 holes were drilled into the water jacket would have been appreciated.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #784
Old 07-20-2013, 12:13 AM
Stan Weiss's Avatar
If you took the engine from the crate and ran it you have a point.
But you took it a part to redo it. So now you need to inspect every part and that means every bolt hole. If something is missed now it falls on you the builder / assembler.
Stan
  #785
Old 07-20-2013, 06:57 AM
RAIV-Z's Avatar
Stan
The issue was found and resolved while pressure testing the engine on the stand. Whether I took the engine apart or not I’m still allowed to ponder why there wasn’t something sealing the hole when it was received.
The point was to inform other guys who might have purchased heads.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #786
Old 07-20-2013, 08:07 AM
mgarblik mgarblik is offline
Your point about bolt holes drilled through or too deep is a good one. Very common on any aftermarket head or block. I have seen this on Tiger heads, IA 1 Blocks, early E heads and many brand X parts. I generally fix this with a short set screw and lots of pipe sealer with teflon on the threads. Put it in the hole first, then your regular fastener in next. Problem solved. Usually, after they make a run or two of the parts, these type of issues are solved in the machining program. Good luck on the dyno!.
  #787
Old 07-20-2013, 05:16 PM
Tom Vaught's Avatar
Boost Engineer
Short Set Screws epoxied into the hole to where they just seal should still give you more than enough thread engagement for any accesory drive component, (especially if you are fixing only one hole) and you can still run a normal fastener (slightly shortened) with no water leaks from then on. As Mike says, more common that you would think, More of a normal checkout process on the heads.
Tom Vaught
  #788
Old 07-20-2013, 10:42 PM
RAIV-Z's Avatar
For the dyno, a couple of spare header bolts and some tape dope will cover it.
Anyone like to guess at what it might make after fixing a few things and changing the cam?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #789
Old 07-20-2013, 10:54 PM
Tom Vaught's Avatar
Boost Engineer
More than it did before, I hope!
Tom Vaught
  #790
Old 07-22-2013, 07:43 PM
cgeise's Avatar
cgeise cgeise is offline
1150 hp at 12 lb
  #791
Old 07-22-2013, 08:08 PM
RAIV-Z's Avatar
Going to run it NA with a carb to break it in again, won't see EFI and turbo numbers until the engine is in the car.
Most of the fixes centered around the valve train, springs, cam, pushrods, rockers, timing chain, etc..
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #792
Old 07-22-2013, 10:32 PM
Travis Q Travis Q is offline
Originally Posted by cgeise View Post
1150 hp at 12 lb
I'd say that's a dead nuts estimate.
  #793
Old 07-23-2013, 09:02 PM
pastry_chef's Avatar
Does the new cam have extra duration or lift Ed?
  #794
Old 07-23-2013, 09:17 PM
rodneybutler's Avatar
rodneybutler rodneybutler is offline
Sounds like TQ might have done this before. Lol!
  #795
Old 07-23-2013, 10:08 PM
RAIV-Z's Avatar
The cam on the bottom is currently installed, same 1.65 rocker ratio, head gaskets are .020 thicker.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #796
Old 07-23-2013, 11:21 PM
Stan Weiss's Avatar
That added about 5 cc's to your total volume. How much did it reduce your CR?
Stan
  #797
Old 07-24-2013, 07:17 AM
RAIV-Z's Avatar
Stan
~.29
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #798
Old 07-24-2013, 12:12 PM
Stan Weiss's Avatar
Was this done to increase PTV clearance because of the new cam's greater lift, or you wanted to increase squish clearance to reduce max squish velocity, or some other reason?
If I read the cam cards you also did the firing order switch.
Stan
  #799
Old 07-24-2013, 12:22 PM
cgeise's Avatar
In my best Elvis voice -- Thank you - thank you very much
  #800
Old 07-24-2013, 02:54 PM
RAIV-Z's Avatar
Stan
0.080 was the recommended thickness to support double O-rings with a solid copper gasket.
Firing order was changed. The first cam was also supposed to have that as well, got a song and dance instead.
We'll be using the turbo headers connected to 3" pipes on the dyno.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
