Old 03-26-2022, 04:15 PM
max 93 max 93 is offline
Wires cut to length and use this style
  #802
Old 03-26-2022, 05:42 PM
HWYSTR455's Avatar
HWYSTR455 HWYSTR455 is online now
Originally Posted by 64speed View Post
What are you guys using for plug wire looms?
The only way to get wires that fit right, especially with looms, is you have to cut to fit, period.
Buy the tool, it's inexpensive, and you will be surprised how much it pays for iteself:
https://www.amazon.com/Stripping-Pro...s%2C86&sr=8-32
I use Moroso looms, and a couple of the plastic separators to keep the wires off the top of the covers. Unfortunately, you may have to buy additional plastic holders, depending on your setup.
I think this is one I generally use, but have also used a chevy one, and bought a pair of straight stands too:
https://www.moroso.com/small-block-f...ck-7-9mm72133/
EDIT: I use multi-angle boots on the wires
The Following 2 Users Say Thank You to HWYSTR455 For This Useful Post:
  #803
Old 03-26-2022, 07:47 PM
tom s tom s is offline
You could always do the “Road Kill” wire holders!Tom
ID:	587195   Click image for larger version
The Following User Says Thank You to tom s For This Useful Post:
  #804
Old 03-26-2022, 08:14 PM
Sirrotica's Avatar
Ya beat me to it Tom.........
Finnegan just talked about those last night on the show.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #805
Old 03-26-2022, 08:52 PM
just make sure that 5 and 7 don't run parallel to each other.
  #806
Old 03-27-2022, 03:29 PM
64speed's Avatar
64speed 64speed is offline
Here you go for those that wanted to hear it rev!
https://youtube.com/shorts/M74lNxvtztw?feature=share
  #807
Old 03-27-2022, 03:47 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Sounds mean! Is that a little belt squeal (not trying to be mean)?
  #808
Old 03-27-2022, 04:05 PM
64speed's Avatar
Yes it is. I gotta tighten the PS belt but with the CVF racing V belt setup the alternator has to come off to get to the tensioner and I have had too many other things.
  #809
Old 03-27-2022, 04:29 PM
Murf Murf is offline
On my wife’s car I can get at it from underneath the car but it is a PIA. I agree, it’s easier to swing the alternator out of the way.
Cars lookin good!
Murg
  #810
Old 03-27-2022, 05:50 PM
64speed's Avatar
Got the belt squeal stopped
  #811
Old 03-29-2022, 12:29 AM
68WarDog's Avatar
68WarDog 68WarDog is offline
I think I saw your Tempest on YouTube. Sounds great. What Mufflers?
  #812
Old 03-29-2022, 11:32 AM
64speed's Avatar
Well I am changing the order of doing things to minimize downtime. The upholstery shop is being slow so I am taking the car to the exhaust shop Tuesday to get the exhaust done then dropping it off to have the heat and AC installed. That way all that’s done when the seat does come back and I don’t have to wait for all that stuff to be done to drive it.
  #813
Old 03-29-2022, 11:33 AM
64speed's Avatar
No mufflers right now you just can’t tell how loud it is in the video. Mufflers are black widow though
  #814
Old 03-29-2022, 10:32 PM
64speed's Avatar
Does anyone think I will have to rejet the carb because I am using the TORKER II but only for street use? I watched an Engine Masters episode tonight that was on this very topic. Their opinion was street cars need dual planes because of reduced signal to the carb. Other than black smoke from the exhaust what else do I need to look for?
  #815
Old 03-29-2022, 11:01 PM
Maybe Loss of some low end and some low rpm weird AFRs
  #816
Old 03-30-2022, 10:23 AM
David,
Don't think with your cubes and gearing that the T2 will be a problem.
Cubic inches and intake volume determines how fast vacuum signal builds. Correct that with the right strength power valve.
Clay
PS edit Need to get exhaust hooked up before you start tweaking the carb. Cam overlap and any exhaust restriction at all can have major changes to the carbs vacuum signal. That's other than a plain old flooding problem.
  #817
Old 03-30-2022, 10:54 AM
grivera's Avatar
grivera grivera is offline
Does the passenger side fender have to be removed for AC install?
Will Rivera
  #818
Old 03-30-2022, 12:37 PM
64speed's Avatar
No it does not, I installed the block off before assembly
The Following User Says Thank You to 64speed For This Useful Post:
  #819
Old 03-30-2022, 08:00 PM
64speed's Avatar
Has anyone had an aftermarket air system installed and if so how much did you pay?
  #820
Old 03-30-2022, 09:49 PM
grivera's Avatar
I haven’t but read somewhere it is 20-25 hours labor. If no interior maybe less hours. Have you considered doing yourself? I’m doing mine - so far pretty straight forward.
Will Rivera
