Old 03-02-2015, 10:14 PM
chuckies76ta's Avatar
Great info Don. Waiting to set these heads on a running engine..
Charles
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
  #822
Old 03-04-2015, 09:39 PM
RAMAIR RICK RAMAIR RICK is offline
Hello Charles, I am getting excited as you are about hearing Don's engine with his heads and intake on it. I am currently building my engine with Don's heads and intake on it. What size engine are you planning on building or updating with Don's Ram Air V heads and intake?
  #823
Old 03-05-2015, 12:50 AM
Just putting together a 468 at the moment.. Waiting to see how these V heads are going to perform. I would like to do an MR1 block with these heads and intake..
Charles
950 Quickfuel.
  #824
Old 03-05-2015, 12:44 PM
Charles, it sounds like your 468 ci engine will like them. You mentioned you want to build up an MR-1 Block, funny that is what I am using, an MR-1A (aluminum) block, and making a 93 octane Pump Gas engine.
  #825
Old 03-05-2015, 02:11 PM
TTOP350 TTOP350 is offline
Been following along silently here and on FB. Looking good and I'd like to use this setup soon!
http://www.fquick.com/garages/viewga...ewimg&id=74990
"You people have stood in my way long enough. I'm going to clown college."
-Homer Simpson
  #826
Old 03-05-2015, 08:22 PM
Well that sounds great. Hopefully you will keep us posted..
Charles
950 Quickfuel.
  #827
Old 03-05-2015, 09:00 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Don, done any r&d on a dry LS type intake for FI? I am interested in doing a setup like this.
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
  #828
Old 03-06-2015, 10:33 AM
dci dci is offline
Nothing yet JC, but my brain is twisting with different idea's though LOL. I have several different platforms that I want to experiment with from a single throttle body in the center of the plenum to individual runners like a Kinsler FI set up. I really like the intake set up that Throttle performance used in the EMC. That platform can be tuned to any application and it looks really cool too.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #829
Old 03-07-2015, 09:07 AM
455firebird1969's Avatar
For comparison purposes only, my new stock block 467 with E-heads, T2 intake, 1" spacer and Holley 850 DP installed in my 1969 Firebird.
  #830
Old 03-07-2015, 09:16 AM
Dons DCI RA-5 heads and intake from a similar angle. Both look close and should clear with room for an air cleaner.
  #831
Old 03-07-2015, 09:43 PM
tom s tom s is offline
Time line,heads were cast and pics displayed 2-15-13,flo numbers published 10-3-13,intake pics posted 8-4-14.When are going to see ANY engine on a dyno?Inquiring minds NEED to know!Tom
  #832
Old 03-07-2015, 09:56 PM
J.C.you's Avatar
I have a built alum shortblock ready for some Vs. Could have a dyno sheet for all to see in a snap...if there is a guinea pig discount.
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
  #833
Old 03-07-2015, 10:09 PM
ho428's Avatar
ho428 ho428 is offline
I gotta 433 short block on the stand, should Don want to send me some "test parts" I'd be more than happy to put'r on the dyno and in the car, especially with the HSR "Mitty" coming up at Road Atlanta. I could use about 700 hp to run with those boys.
  #834
Old 03-07-2015, 11:01 PM
do these short blocks have a V cam in them?If not then they are NOT ready!Tom
  #835
Old 03-08-2015, 09:56 AM
J.C.you's Avatar
I have access to some v cores that are slightly used. or some that are ready to be cut.
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
  #836
Old 03-09-2015, 09:55 AM
dci dci is offline
A cam is not the problem I have several and can get one made in a week or less. So if someone has a short block that is ready to run I have cylinder heads just give me a call. The problem I have is time. I only have myself and one other full time guy here and my shop is very busy all the time. I only have so many hours in a day that I get to work on my projects if at all some days. So believe me!!! No one wants to see an engine run more than me with a set of my heads. On top of all the customer projects I am also doing all the R&D for my heads and intakes too. I am also developing another new cylinder head that's been on the drawing board now for over a year. I do like to eat and sleep once in awhile LOL. If I was smart (HMMM) maybe I should say the heck with developing new products for everyone else and worry about my own race program. Sorry about the rant, but until you have done this at the level I am doing it. You cannot even begin to understand the amount of time it takes to do it.
To give everyone a small glimpse and I mean small into what I am dealing with at every turn of this project. I mocked up my short block last week to check piston to valve and the valve reliefs are in the wrong locations. Now I don't know how that can be especially when I sent a cad file with a screen shot and locations clearly marked, but it happens. So now that little road block needs fixed before I can move on. When designing something from scratch every little detail needs to be scrutinized. Just ask GM, FORD, And Chrysler. They have several hundred if not several thousand people working on one cars design and it still takes years. So please have patients with this project. I could rush it all together and call it done and let everyone else do my R&D LOL.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #837
dci dci is offline
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #838
Old 03-09-2015, 12:09 PM
Thanks Don. I can't even imagine your work load.. Most people can't keep up with there personal life let alone a business..
Charles
950 Quickfuel.
  #839
Old 03-09-2015, 06:26 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Is this other head a Pontiac piece?
  #840
Old 03-09-2015, 09:53 PM
I wonder how many people here on Ames performance Engineering would actually buy Don's version of the factory Ram Air V head casting #44 if it performed as good as the factory as cast head flowed roughly 325 cfm? Seeing that Don has changed the valve angle to 10 degrees from the factory 14 degrees, and his street head as cast has a 2.20 intake valve and the factory had 2.19. My Ram Air V head from DCI, has a 2.32 intake valve, as an example of where some of you can go or larger, just ask Don. Also, the intake port approx. 1.5 inches, and exhaust port about .5 inches have been raised to help the flow in and out of the cylinder. That being said Don also has about .750 deck thickness as well. Really if you start to look at a the reasons to purchase a set of Don's Ram Air V heads, it is pretty obvious, that UNLESS you are looking for the performance of the Factory Ram Air V head and all of it's compromises, Don's DCI Ram Air V is the only logical choice. I for one have Chris Uratchko, designing and assembling my engine. That being said when he said that DCI's Ram Air V is Pontiac's version of a Ford Pro King head I was sold. Do I need to see if Don's engine performs well??? NO!! When you truly understand Valve size for a given engine requirements and also understand the cross sectional area that it takes to make the Horsepower, it is not about what one engine made, is about the casting and the design that when INTO it that really makes a great cylinder head. I will be very happy with the approx. 850 hp that my DCI headed pump gas Ram Air V engine will make and scare the hell out of me in my stock looking 1968 Ram Air GTO. So what kind of performance are you looking for before you purchase your own set of a modern version of the Fantasy Ram Air V heads????
