Old 04-06-2021, 04:05 PM
shermanator2 shermanator2 is offline
The Pontiac version has the Iron Duke engine instead of the POS aluminum Vega engine.
  #8702
Old 04-06-2021, 05:53 PM
burd burd is offline
You need to post a pic from the ad, they are always ended or deleted and you see nothing.
  #8703
Old 04-06-2021, 06:15 PM
Originally Posted by Will View Post
Don't see those every day!
I dunno how solid it is, though. Check out the upper left part of this picture, and just imagine what the floor pans and rear frame rails might look like...
The rust is where the battery tray should be, very common for an H-Body to rot out under the battery. I would only be concerned if it had spread to the frame rail under where the battery tray should be.
Looks like it is at least reasonably priced, unlike the 73 Lemans recently posted.
  #8704
Stuart's Avatar
Stuart Stuart is offline
Here's the Astre. According to the air cleaner it's a Formula.
ID:	564217   Click image for larger version
ID:	564218   Click image for larger version
  #8705
Old 04-06-2021, 06:23 PM
242177P's Avatar
242177P 242177P is offline
FWIW, I've never seen a Vega battery tray area that didn't look like that.
Vert-A-Pack.
  #8706
Old 04-06-2021, 10:46 PM
Drag Star Le Mans's Avatar
Saw this and got excited, read the fine print. Chebby 350? The owners name is Dick, totally makes sense. Easy fix though!
https://modesto.craigslist.org/cto/d...300920819.html
DragStarLeMans
  #8707
Old 04-07-2021, 09:07 AM
For some reason every Iron Duke put in a Astre in 1977 had the Chrome Valve cover, and the Formula sticker on the air filter plastic cover.
That is a very base model car, the only options I see are Power Steering, A/C (with removed compressor) the body stripe, tinted glass & auto transmission.
I think I see a Radial Tuned Suspension emblem on the dash, heck it even has the base interior with the Vega style seats. But I do see it also has the optional Custom Cushion Steering Wheel. The car makes my 77 Formula look like a Luxery car!
  #8708
Old 04-07-2021, 10:11 AM
proximity_alrt's Avatar
proximity_alrt proximity_alrt is offline
What other options might there have been? I can't imagine much, other than maybe an auto vs. stick, maybe glass defrosters or something.
  #8709
Old 04-07-2021, 04:55 PM
They could order a delux interior that got you base Firebird Bucket seats, better door panels than the hard plastic ones this one has, power brakes, Tilt Column, formula steering wheel, rally gauges, rally or snow flake wheels, rear window defrost, Power brakes, Long Center console, intermittent wipers, off the top of my head.
  #8710
Old 04-08-2021, 03:04 AM
Major contradiction here???
https://seattle.craigslist.org/sno/c...303460546.html
DragStarLeMans
  #8711
Old 04-08-2021, 11:47 AM
Originally Posted by Drag Star Le Mans View Post
That description needs saved.
"DOES NOT RUN. Will crank but won’t turn over."
  #8712
Old 04-08-2021, 01:02 PM
242177P's Avatar
Cranks just means the starter still works. But 'turn over'... Why me head do hurt?
So motor and transmission? It's begging for a V8, and there's even a clutch pedal.
  #8713
Old 04-08-2021, 01:58 PM
77 Love Bug?
https://easttexas.craigslist.org/cto...302541154.html
"Love Bug, four cylinder Internal Combustion Engine, Possibly from a Renault. This vehicle may be the result of a Tornado going through a wrecking yard,....Just a thought! "
  #8714
Old 04-08-2021, 06:10 PM
Chris65LeMans's Avatar
$750 sounds like a good price. Looks good enough to throw the drivetrain away and start over. For a price that low, I suspect something else is wrong. (No title because it’s stolen, etc.)
  #8715
Old 04-08-2021, 07:44 PM
FrankieT/A's Avatar
Says clean title...
  #8716
Old 04-09-2021, 11:00 AM
Verdoro 68's Avatar
Manual with automatic gauges?
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #8717
Old 04-09-2021, 12:32 PM
What makes the gauges auto? I have a manual Tacoma and it has nothing but a speed-o, fuel gauge and idiot lamps. First manual I've ever owned without a tach.
I notice that a lot of the import car forum people or people kind of new to wrenching confuse 'turn over' 'crank' and 'start'. Makes it really tough to decipher when they post a question like, 'Car cranks but won't turn over'.
Old 04-09-2021, 12:37 PM
77 Love Bug?
Might make a neat little farm vehicle...but I'm thinking more like $300 or so, if it runs.
vertigto's Avatar
vertigto vertigto is offline
What makes the gauges auto?.
I think he means the the gearshift selector (i.e. P R N O D 2 1), although it does have a tach.
  #8720
Old 04-09-2021, 01:44 PM
jamesq's Avatar
jamesq jamesq is offline
Default Love bugs
77 Love Bug?
Love bugs are a particularly nasty insect we get twice a year (spring and fall) in the deep south.
The only purpose they serve (that I am aware of) is to mate and splat themselves on the front of your car. If not removed promptly, the carcass will eat through your paint! They appear to be drawn to exhaust emissions and tall grass,
I don't think they have made it much further north than I-20.
James Q
James Quayhagen
