Appears to have one cylinder not hitting with the same amount of punch as the others.
The idle mixture screw over #1 and #3 will be a balancing act at best with the PCV hooked like it is. Make #1 hit strong and #3 will be rich. Make #3 hit strong and #1 will be lean. Look back at one of the old videos with the 870 carburetor. The engine ran a little smoother. https://www.youtube.com/watch?v=LeOqYtY0Dng Clay |
Sun Tuned,
Hahaha. No diesel. (93 Octane pump gas). This picture was taken when the motor had around 150 miles drive time and a bunch of idle time while we were diagnosing the knocking noise. |
Those cylinder head pics are from pretty early in your diagnosis, not presently, correct?
The timeline of this is VERY long and confusing to follow without researching this book! Who pulled/installed the heads? What was checked and by whom? I highly agree, looks like it's on a high petro diet.Valve seats are likely just as laden with deposits at that time. _Currently Where was the intake vacuum leak, at which cylinder, pairs, and /or multiple locations? The discovery and introduction of new base engine problems in the build/rebuild heavily taint this deal, beginning with the original, previously undisclosed, original dyno failure when trying to diagnose the noise. Bottom line, the engine lost oil pressure on the dyno at birth... from an assembly failure. It just seems to be patch jobs from that point. I'm deeply disappointed in this deal. I've been on Paul/Jeff's end.It not a easy pill to swallow, Menn take responsibility for their mistakes, and good business men make things right. With that I'm impressed with Jeff's current appropriate actions. The rest of this deal is a train wreck. With that, I think I'll just watch from the sidelines from here out. |
We've pulled one plug at a time several times throughout the last two years. The knocking noise never changed and was always present.
The motor was on the dyno 4 times and the knocking noise wasn't heard because there were no mufflers on it. I dont have access to an engine stand. We've done about 165 hours of diagnosis on this motor but we've never totally disassembled it. Sent from my SM-G955U using Tapatalk |
Ok..this has probably been answered..but is the cam a roller/hydraulic roller? If so what valley pan is on the motor. Like I said, Probaby answered already. But I cant read the whole thread to check
Hydraulic Roller cam/lifters, Tomahawk valley pan
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
Cool. When was the last time the oil filter was checked for metal? If recent and there is no bearing material in the filter my guess is the lifters ( 1 or more ) making contact with the valley pan. I know it was probably checked when the motor was assembled, but I just read that the valley pan was pulled to fix an oil leak. Was a gasket used or just sealant? If no gasket then that would nake the pan a little closer to the lifters.
455GRIN,
I appreciate that. I'm hopeful that the right thing will be done to get this motor right. I have no doubt this motor will need to be torn down. Jeff's guy is pretty damn good and hopefully it will get resolved. As I said before, I guarantee Jeff and Paul want this nightmare to end just as much as I do but I don't think any customer would accept the motor as is. |
455GRIN,
I'm a pretty patient guy and I know I'm new to messing around with these old cars but I think with over 165 hours of instructed diagnosis of this motor given by the builder, I think it's time to stop looking for a mistake that we "could" have done hooking up the motor and start worrying about whats going on inside the motor. We've spent a lot of time, energy and money doing test after test looking for a faulty part or a install mistake and not enough energy is being spent looking for a mistake on the build. Considering this motor had a catastrophic failure on the dyno, I'm willing to bet that is the root of this problem. I thought about looking for another motor to throw in there but thats just more money and not what I paid for. One way or another...This motor will get right. It's just a shame that we're spinning our wheels looking for a mistake on our end when 165 hours has proven it's not on this end! Last edited by Va68goat; 08-17-2019 at 11:25 AM. |
Long shot throwing it out there, have you tried spraying a liquid like WD-40 or starting fluid something like that around the intake gasket while it is running, if there is a vacuum leak the idle will change /
I can’t believe how expensive oil filter cutters are. I mean I bought one for my engine obviously but Jesus it’s just a large tubing cutting. The cheapest one I found was from speedway motors with free shipping on amazon. Still 51 dollars. That’s ridiculous
$43 at Summit, I though you were a Summit Man? LOL. I bought one at a swap meet, $10.. Its a must have tool!
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. Last edited by TedRamAirII; 08-17-2019 at 07:21 AM. |
But you gotta pay shipping. Shipping is free from JEGS if you buy thru amazon
Well, not too much to update. Last week the tech finished diagnosing the engine and it was determined to be internal / mechanical. I've been texting with Jeff and I'm just waiting to see what the next step is. I don't think it's a good idea to send the engine back to Arizona so Jeff said he may fly Paul out here. I would hate for Paul to lose time away from the shop to fly out here because time is money. There is a local shop (C&C auto performance) that I'm confident that could do this job for the same amount of money or less as it would be for Paul to fly out here, replace gaskets, oil, parts if needed, time away from the shop etc. The tech that diagnosed my engine has known the guys from C&C for decades. Jeff said he's going to be speaking to C&C (the same shop that inspected the heads). Hope this happens soon!
TedRamAirII,
Yeah..the engine is going to be pulled real soon. It's not going back to Arizona though. We are working something out to keep the motor here in Virginia. I'm trying to work out a plan with Jeff and we're still working out the details. I hope it's something simple but after close to 180 hours of diagnosis time and two years without driving this car, who knows what it could be. |
Take an oil sample and send it in. The results will tell you more about if something is rubbing than most other things. cost is likely under $30. Make sure to take mid stream
From Blackstone Labs how oil analysis can show a problem before it becomes a larger problem: Quote:
Link to Blackstone Labs in Fort Wayne Indiana: https://www.blackstone-labs.com/ For roughly $30 it can be a very good diagnostic tool in this case.
Brad Yost 1973 T/A (SOLD) 2005 GTO 1984 Grand Prix 100% Pontiacs in my driveway!!! What's in your driveway? If you don't take some of the RACETRACK home with you, Ya got cheated ![]() ![]() ![]()
Another lost driving season, you need to found a cheap replacement motor off craigslist so you can start enjoying that beautiful GTO.
A 3rd party needs to open it and get it figured out. The engine builder had 2 chances, and it cost you time and more money. Does anybody have a spare motor that could get our Pontiac buddy rolling again? |
VA68goat, I agree that's not what you paid, you desire a strong running motor. But that motor has a bad knock, needs to come out, put on a test stand, if noise is still there, motor has to come apart. Not sure who or how at this point, hope Jeff's guy gets figured out.
Lifes too short, someone has a motor to get you going for the short term. It appears that motor will be down for awhile. Good luck we are hoping for the best |
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' |
| Closed Thread |
