Old 04-24-2008, 05:28 PM
Father&Son73T/A Father&Son73T/A is offline
Originally Posted by Larry Navarro
cool
Is black correct on that master cylinder?
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
  #902
Old 04-24-2008, 07:00 PM
SD73's Avatar
SD73 SD73 is offline
Question for you '73 Duty-Dudes...whatcha using for a battery? I don't think the repro's cover us.
  #903
Old 04-25-2008, 07:57 AM
Brewster's Avatar
Brewster Brewster is offline
Black is correct and a good battery with a repop cover works great and has the look of an original.
  #904
Old 04-25-2008, 10:56 AM
SD73's Avatar
Were these the sealed maintenance free style? Eye or no eye? BTW, paperwork calls for the C89 battery.
  #905
Old 04-25-2008, 11:40 AM
Brewster's Avatar
Its been a while but I'm thinking its a R89W with an eye in one of the caps. I'll check my notes upon getting home later today to confirm!
Otherwise if someone else wants to pipe in feel free?
  #906
Old 04-25-2008, 12:05 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Checking my MPC for battery apps I found that for both the '73 and '74 455SD the standard equipment battery was an R89S. If equipped with the HD battery option the R89W is correct.
Crappy pics, but these are what I found from Antique Auto Battery.
Name:	R89S Delco Battery.gif
ID:	130479   Click image for larger version
Name:	R89W Delco Battery.gif
Regards,
"455HO" Lloyd
  #907
Old 04-25-2008, 02:14 PM
SD73's Avatar
Thanks!
  #908
Old 04-25-2008, 05:07 PM
SD73's Avatar
Okay, it turns out Antique Auto Battery lost the mold for the R89W in a fire and won't have them reproduced for 6months. I can get the do-it-yourself acid types now, but I'd rather get one of these maintenance free types. Anywone know of any other suppliers that may have 'em in stock?
  #909
Old 04-25-2008, 05:25 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
might try these guys:
http://www.londonbattery.com/#/gmbatteries/4517375337
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #910
Old 04-25-2008, 05:39 PM
SD73's Avatar
Thanks Rick. I'll check with them but they seem a lot more expensive and I'll bet the shipping from Canada is a killer.
  #911
Old 04-25-2008, 05:45 PM
RicksGTO's Avatar
true, I didn't notice they are in the great white north!
  #912
Old 04-25-2008, 06:33 PM
SD73's Avatar
It's the thought that counts!
  #913
Old 04-26-2008, 10:00 AM
RicksGTO's Avatar
http://www.classicindustries.com/pdf...ies-wiring.pdf
just got their new catalog, they show the R89S and R89W maint. free (though who knows if they are in stock with Classic) and have a showroom south of LA
  #914
Old 04-26-2008, 10:05 AM
Brewster's Avatar
These covers are nice since it gives you the freedom of replacing batteries as needed without the big expense of those repop's. They look great and you'll save $ over the long run period!
http://cgi.ebay.com/ebaymotors/1969-...spagenameZWDVW
  #915
Old 04-26-2008, 11:15 AM
SD73's Avatar
Thanks Rick I'll check them out again. I called yesterday and they did have it in stock, but I didn't verify it was the sealed non acid type. The catalog picture of it shows the 950 CCA like the ones that are the non-acid types so that looks positive.
I'll check that out too, Brew.
I also just checked my paperwork. It calls for a TP1 MT/FR Battery. I'm thinking this is actually neither of these R89 batteries and an early version of the sealed battery with the eye on it. Thoughts?
  #916
Old 04-27-2008, 09:14 PM
Brewster's Avatar
What car, date/month mfg is this for and whats does the phs (options)call out? also what paper work are you referring to?
Give us a few more clues!
  #917
Old 04-27-2008, 09:31 PM
SD73's Avatar
It's my SD. June 73. The "TP1 MT/FR Battery" is from the Build Sheet line items. In the upper little blocked section of the build sheet it does call for a C89.
I have another sheet (not sure what it's called) from my PHS documentation calling for a "Bat - Delco X" with a Code "TP1."
Make any sense Prof. Brew?
  #918
Old 04-28-2008, 07:51 AM
superdutybob's Avatar
superdutybob superdutybob is offline
MT/FR stands for Maintenance Free! Yes, it will be the sealed battery with the little eye.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #919
Old 04-28-2008, 08:39 AM
Brewster's Avatar
What you want is the HD battery due to the sd package which today would call out R 89 W delco eye cap side post battery. There isnt anything else since the R88X is not reproduced nor is C89(yet)?
There wasn't real anything maintenance free about any batteries back then since they where a vented system and still needed to be checked and filled.
What is the production date in June on that car? is it a brother or sister to my cars?
  #920
Old 04-28-2008, 10:49 AM
SD73's Avatar
Thanks fellas!
I had an original "eye" in a '79 T/A. It was vented as you describe Brew, but there was still no way to add water. It was totally sealed.
For the production date, from the top left corner of my build sheet is a box with "Schedule and Date" in it. There it says 06-12. On what I think is the Invoice has a "Date of Execution" of 6-19.
