Old 05-21-2022, 02:18 PM
64speed's Avatar
64speed 64speed is offline
I don’t think I’ve ever posted any HD pictures
ID:	591263   Click image for larger version
ID:	591264   Click image for larger version
ID:	591265   Click image for larger version
ID:	591266   Click image for larger version
The Following User Says Thank You to 64speed For This Useful Post:
  #902
Old 05-21-2022, 02:19 PM
64speed's Avatar
Here are the rest
ID:	591268   Click image for larger version
ID:	591269   Click image for larger version
  #903
Old 05-21-2022, 02:38 PM
SRR's Avatar
SRR SRR is offline
Beautiful!
― Calvin Coolidge
  #904
Old 05-23-2022, 02:38 PM
Va68goat's Avatar
Va68goat Va68goat is offline
David, your car looks great. My buddy just got his 64 Lemans on the road this past weekend. Has a 461 cubic inch, aftermarket suspension, Tremec 5 speed, Ford 9 inch rear, A/C blows cold! He's pretty happy with it. He still has to dial in the dual carbs and a few other things but it's coming along nice!
Great progress on your car. Congratulations!
ID:	591392   Click image for larger version
Name:	Steves 64- 2.jpg
The Following User Says Thank You to Va68goat For This Useful Post:
  #905
Old 05-23-2022, 02:58 PM
64speed's Avatar
Thank you
  #906
Old 05-23-2022, 02:59 PM
64speed's Avatar
His engine bay is a lot cleaner than mine
  #907
Old 05-23-2022, 05:37 PM
tom s tom s is offline
That is a perfect example of KISS!Tom
  #908
Old 05-24-2022, 05:25 PM
geeteeohguy's Avatar
Easy to do with proven reliable factory parts.
Jeff
  #909
Old 05-24-2022, 07:23 PM
64speed's Avatar
I will eventually clean mine up as I go. RIght now I am having too much fun cruising around.
  #910
Old 05-24-2022, 07:24 PM
64speed's Avatar
I love the poverty caps and redlines. Wanted to do that in an 18 inch wheel but the wife Vetoed it. She has had only a few things on the car she was adamant about so I caved on that one
  #911
Old 05-24-2022, 09:28 PM
Old Goat 67's Avatar
Smart wife!
  #912
Old 05-24-2022, 10:34 PM
Va68goat's Avatar
David, your car looks great. It's been cool watching you put it together. Great build!
- Joe
  #913
Old 05-25-2022, 12:22 AM
Looks great, happy for you! Great vanity plate for your Tempest.
  #914
Old 05-29-2022, 07:47 PM
64speed's Avatar
Funny story of the day. I had my speedometer rebuilt and reset to zero when I did the dash. I had it matched to the tire height etc so the speedometer was 100% accurate. I tracked it with my cell phone. Night before last I was riding with my wife and I commented to her on how accurate the speedometer was, about 20 seconds later the needle just went dead. The odometer stopped turning and that was that. There is a gauge restoration firm about 35 miles from here that I am taking it to the 13th but it just shows you dont ever brag.
  #915
Old 05-29-2022, 08:13 PM
Murf Murf is offline
Check out your cable & gears before you go tearing the dash out! 😁
Murf
  #916
Old 05-29-2022, 08:30 PM
64speed's Avatar
Yeah I uplugged the cable at both ends, it looks good. I had good engagement and nothing was loose. The guys at the gauge shop are super nice, if its something else they will tell me. I dont think they will just rebuild it and leave me to fend for myself. Like I said the cable looks good, How do I tell if its the trans gear?
  #917
Old 05-29-2022, 09:28 PM
gtospieg gtospieg is offline
You could probably hook up a drill to the trans end of the cable and give it a spin...if the speedo works then you know the problem is in the trans.
  #918
Old 05-30-2022, 05:46 PM
You could also put the vehicle on jackstands, disconnect the cable from the speedo, and see if the end (inner cable) rotates when you run the car in gear. If it does, your trans gear is fine.
Jeff
  #919
Old 05-30-2022, 06:27 PM
64speed's Avatar
I will try those tomorrow
  #920
Old 05-31-2022, 09:48 PM
64speed's Avatar
Haven’t gotten around to testing the speedo yet but I drove it by my estimate about 50 miles today and had no problems. Only thing I noticed is when it’s really warmed up sometimes I get some run on when I shut it off. Also when it’s cold (but not choke on) all I have to do is bump the key and it fires up. If I let it get hot it takes a little time to get it started again. Not bad just not as simple as short trip restarting. Is that probably timing? AC blows ice cold but it’s hard to overcome the 200 degree shifter hole in the floor. Hahaha
