Old 10-01-2014, 08:08 PM
mike leech's Avatar
mike leech mike leech is offline
looks great!
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #942
Old 10-01-2014, 11:06 PM
Progress is good!!! Maybe we'll see you out in 2015? Hope so, the setback with the motor really messed up your timeline. Glad to see you persevere and hope to see this car fly soon.
  #943
Old 10-02-2014, 09:21 AM
dci dci is offline
Ed,
That thing looks BAD A$$$. What color are you going to paint the car? You may have mentioned it, but I don't remember.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!!
  #944
Old 10-02-2014, 01:39 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Thanks guys, I really appreciate the support, both moral and technical
Early spring is the target, the local track closes at the end of October here in NH. The 69 Bird is going to be black.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #945
Old 10-04-2014, 06:39 AM
shaker455's Avatar
shaker455 shaker455 is offline
Carburetor building & modification services
Servicing the Pontiac community over 25 years
  #946
Old 10-17-2014, 09:01 PM
RAIV-Z's Avatar
Little more work left todo on the front end in order to drop the oil pan without pulling the engine.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #947
Old 10-17-2014, 10:46 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Talking
Tic tock....
First Pontiac powered street car in the 7's
[email protected]. 3460#s
  #948
Old 10-18-2014, 07:41 AM
RAIV-Z's Avatar
Originally Posted by LiL Jack View Post
Tic tock....
I hear ya Jack, they never come together fast enough. How are your updates coming along?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #949
Old 10-19-2014, 08:33 AM
Rob B's Avatar
Rob B Rob B is offline
Using a Smith Racecraft Rack and pinion set up I see.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
  #950
Old 10-19-2014, 10:52 AM
Tom Vaught's Avatar
Boost Engineer
Have your guy put some addition weld on the seams of that subframe, Ed, as it will see a lot of stress (as a drag car) even with the "J-Tubes" welded on.
Tom V.
  #951
Old 10-24-2014, 07:44 PM
RAIV-Z's Avatar
Yep, the front end is all SmithRacecraft.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #952
Old 10-25-2014, 08:31 AM
Rob B's Avatar
My rack and a-arms are theirs also. Really happy with all of it and makes for a nice, clean install. After everything was aligned, car drives great with no bump steer issues even with a decent wheelie. I didn't like the way the TMZ rack setup was for F-X body subframes. I also cut the center crossmember,capped both ends, and added a pieces of 1 5/8" tubing to reconnect the 2 sides to make it easy to get to a diaper and for header clearances. It all worked out perfectly.
  #953
Old 10-26-2014, 06:41 PM
RAIV-Z's Avatar
Tom V.
Hey Tom,
Got it, some of that was done last week.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #954
Old 10-27-2014, 08:29 PM
janderson's Avatar
janderson janderson is offline
[QUOTE=RAIV-Z;5289232]Little more work left todo on the front end in order to drop the oil pan without pulling the engine. /QUOTE]
Believe this is similar to what Rob B mentioned.
What we did on the '78 T/A - center section fabbed with 2 tubes (DOM), and also a forged eyebolt in center for tow hook up. Also cut down the upper side(s) of the crossmember to create more header clearance.
Name:	78 TA engine 3.jpg
Old 12-03-2014, 08:03 PM
67'7F6'Bird's Avatar
Update below. Click on Picture.
  #956
Old 12-03-2014, 11:33 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Lookin good Ed!!! You should pit next to us at Norwalk next year (2015).
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
  #957
Old 12-04-2014, 09:37 PM
RAIV-Z's Avatar
Thanks Brian,
If you have space, I’ll take it. My crew is very quiet, don't drink much and usually go to bed really early
How’s your bird doing?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #958
Old 12-04-2014, 09:45 PM
wreckmastr's Avatar
Thanks Brian,
LOL ......... So is ours
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
  #959
Old 12-05-2014, 02:31 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
RAIV, I see your heads/intake package in the classified section. What are you going to use?
  #960
Old 12-05-2014, 01:12 PM
Hmm....Click Picture.
