Edit: well I guess the other cylinder valves would have to be closed too so that probably won't work. Edit #2: If you removed the rockers that would close the valves.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share Last edited by jhein; 12-26-2024 at 07:13 PM. |
I think I’ve narrowed the issue down on 5 and 7 to the exhaust valves in particular. The air compressor will barely hold the them in place. Maybe they’re burnt? Oddly, the intake valves weren’t as bad to hold in place.
I tried to do a leak down test when I had several of the cylinders at the top and the valves closed, but I’m not sure I’m doing it correctly. #7 in particular showed around 70%.The other cylinders I tested were around 20-25% which seemed too good to be true. Either way, this engine seems pretty tired.. I got through 13 of the valve stem seals. I couldn’t get #6 intake and #8 because the a/c suitcase prevents removing the pushrods which I need to do to compress the spring. I think this was a futile effort anyway. I could feel and see the play in a few of the valve guides, but maybe he’ll get a little more run time out of it before we decide to tear it down.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST Last edited by Verdoro 68; 12-26-2024 at 10:48 PM. |
I put the Firebird back together after it sucked the carb stud down the intake. Got the head back from the machine shop after repair. Seems fine. Ran a little rough at first start but quickly settled down. Probably just started rough because its 30 degrees out.
I have to retorque the head now that its heat cycled, but so far it seems like its okay.
Put the car cover on the 73 Formula, lifted the cover on the 64, set a beer on the 62 and dreamed about racing it on the salt flats.
DragStarLeMans |
Ignored the fact that we have engine issues to deal with and spent some time polishing up the Ventura. Started with a Comet wash to knock off the rust and stains and followed up with whatever I had around for polishing- a couple medium/heavy pads and some Chemical Guys C4. Really surprised with how much it came back.
While I was doing this, Cole installed new rear 1/4 window seals and we removed the interior panels for cleaning and painting.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
Isn't it amazing what a little or a lot of elbow grease can do LOL
I've done that to a lot of my own vehicals so I don't have to paint them. Everyone thinks because I'm a bodyman that I should paint every car I own. If I did that I wouldn't have time to drive them. LMAO Car looks great. GT |
| The Following User Says Thank You to blueghoast For This Useful Post: | ||
Nice outcome.
Ignore the little bumps, bruises and chips and just enjoy it. Chasing perfection just takes away from your time behind the wheel. If something happens to it it won’t hurt so badly.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
Took in one Last C&C for 2024
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
| The Following 4 Users Say Thank You to Jeff Hamlin For This Useful Post: | ||
Northwest Indiana
Hecho en China is not good for U.S. |
| The Following 5 Users Say Thank You to JacintasHot For This Useful Post: | ||
It was about 30 degrees earlier this afternoon, about 20 degrees warmer than what it was for the last few days, so I started up the 70 GP and backed it out of the garage to let it idle and warm up. Running on E85 it will barely reach 180 degrees sitting there idling for 15 minutes, but it got warm enough to burn out the condensation, and it sounded good sitting there idling so it was good for both the car and I.
You California guys really have it rough...
Repainted the grilles GTO-style, touched up a few of the more egregious scratches. Took the car the get some gas last night and a wheel alignment this morning, then went for a long shakedown drive.
Cole had a goal of driving it to work tomorrow to show it off to coworkers and I wanted to make sure it was good to go. I swear this car gets more attention than my GTO, but I guess Fernmist Green is a lot harder to miss than Verdoro. The oil smoke is largely gone, plugs are reading clean. It ain't gonna win any races, but it starts easy, drives straight, stops well and idles smooth. I'm deeming it roadworthy.
I’d start using this new Valvoline in it, it works to clean up the gunk in the ring lands and should seal up the cylinders better.
| The Following User Says Thank You to b-man For This Useful Post: | ||
I'll have to check that out. It's got some thick Driven 15-50 in it now. I almost picked up a can of SeaFoam when I was at the parts store earlier today. A few weeks ago we fired it up and had a ticking lifter. It went away after it warmed up and has been quiet since.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST Last edited by Verdoro 68; 12-31-2024 at 09:17 PM. |
Our households goods finally arrived today; 4+ months after they were picked up in ABQ. Amongst the items were an extra hood, bumper and bumper braces for the 71.
Now for Portuguese customs to clear the car... |
| The Following User Says Thank You to Scarebird For This Useful Post: | ||
Looked at them.
Then closed the garage door.
Bought this contraption (monster adapter plate setup) so I can somehow someday get my Tempest project sorted out.
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
I made these.
| The Following 8 Users Say Thank You to Stan65 For This Useful Post: | ||
