Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 06-02-2005, 10:30 PM
Mike Davis's Avatar
I installed one of these in my motor last month. Real quality piece! Didn't have time to dyno test it like I wanted but pulled it apart last week after about 20 runs on it just to check and all looks good. The cam shaft endplay came within .0008 of where Scott set it at-I highly reccomend it-
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
  #82
Old 06-03-2005, 12:30 AM
BVR421's Avatar
BVR421 BVR421 is offline
just pulled cam after about 20 passes no street time due to 3 flat lobes. cam was installed with a _NEW_ cam plate, it has about 060 wear already. coincidently, the new timing chain which was nice and snug during install, now has about a 1/2" slop on one side. This stuff wears out quickly. The roller setup is looking better for next years motor.
  #83
Old 06-03-2005, 07:26 AM
Junkyard Dog's Avatar
BVR, you aren't talking about this product, are you?
Badder than old King Kong
-Jim Croce
  #84
Old 06-03-2005, 08:15 AM
Held for Ransom's Avatar
JunkYard Dog, from what I read, he has the plain cam plate (only it was new). And he will be changing to the roller bearing style next.
So long, farewell.
  #85
Old 06-03-2005, 09:11 PM
BVR421's Avatar
Ive never had to pull a cam with so little time on it before so I was astonished to find this much wear on new parts. I really couldnt see the roller bearing plate worth the $$$ until this revelation LOL New motor will hopefully have a SIM roller setup.
  #86
Old 06-03-2005, 09:23 PM
Brian '74's Avatar
Bringing the pics to the top for Scott
  #87
Old 06-04-2005, 06:50 AM
60man's Avatar
60man 60man is offline
Just did a cam change when I installed my KRE heads. Wish I had got one of Scott's kits...Duh too late now. Will go in this winter on new combo..It's a great looking piece and it ought to relieve some stress on distributor gear to boot..no engineer but JMO.?
ECM member.
MANDRA
  #88
Old 06-06-2005, 03:59 PM
simsb52 simsb52 is offline
Bvr421.....You started to have me worried with that one post about .060 wear. yiiks!
Update.....Tho ole dirt track car is starting to get some attention at the race track lately... especially since I pass the feature winner from the previous week like he was sitin still. Tech inspectors had to ask what kind of engine was in the car? oh really...thats a pontiac? huh? rotflmao heheheh
Scott
Scott Sims
Sims Performance Machining LLC
P.O. Box 184
Elizabethtown, Indiana
47232
phone... 812-350-8637
[email protected]
  #89
Old 06-06-2005, 04:58 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Hey Scott:
I've been following this thread from the beginning - you have designed one fine piece there!
I'm finally getting started on another HO engine for my GTO, and my question is - how much lead time do you need to machine a kit and ship it out? The reason I ask is that I'll be align honing my block and won't have a way of knowing how much "shorter" I'll need my timing set to be.
I'll be buying one of your awesome oil pump driveshafts as well.
Many thanks in advance!
Regards,
"455HO" Lloyd
  #90
Old 06-07-2005, 08:59 AM
Herb Hagan's Avatar
Herb Hagan Herb Hagan is offline
I am also using Scott's roller thrust bearing setup and I am very happy with this piece, top quality work.
Lloyd,
Scott's customer service is great. I sent my billet timing chain kit to Scott, he machined everything to my exact specs and had it back to me within a week, including emailing installation instructions at time of shipment.
Thanks again Scott and you will be hearing from me at the next motor build.
Herb
74 Ventura 462/#13 heads/3350#
10.38 @ 128.89 MPH, N/A, Stock suspension, 275/60 Radial, Street legal, Tagged & Insured
  #91
Old 06-07-2005, 11:33 AM
superdutybob's Avatar
superdutybob superdutybob is offline
Lloyd:
I have installed two of Scott's kits so far and both have been perfect. This is a high quality product and his turn around time was about a week. I would never build another Pontiac without this piece in it.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #92
Old 06-07-2005, 12:28 PM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
Haven't pulled it apart to inspect (nor do I intend to), but I just got home from the Hot Rod Power Tour last night. We came home after Indianapolis. Anyway, I used the Sims Performance Cam Plate while freshening the 350 in the old Lemans and logged 1050 trouble free miles over the weekend. 1050 miles, 70 gallons of gas, and 11 cases of beer...WOOHOO, finally did part of the Power Tour!
P.O.S.I - It's not just a club...it's an addiction!
  #93
Old 07-08-2005, 05:20 PM
455Dave's Avatar
455Dave 455Dave is offline
I contacted Scott last week about a bearing package and told him I already have a Rollmaster timing set .004 under due to line boring the block and I'm in a time crunch to get the engine together. He told me to send the timing gear for machining and I heard tonight everything will be here early next week. Scott is a great guy to deal with and even went over the installation procedure on the phone. Thanks for all the help Scott.
  #94
Old 07-09-2005, 07:56 AM
Nine Ninety's Avatar
Nine Ninety Nine Ninety is offline
I just installed a Sims rollerized cam plate on my roadster. Installation was easy and the kit came with good instructions.
This kit should prevent what I found on my stock plate. See picture below. Engine has 85 passes on it and cam plate was new (and flat) when installed.
Note the wear pattern on the cam plate. It is bowed in the middle. Bolts were found tight. Put the plate on a piece of glass to see if it was flat.......it wasn't.
  #95
Old 07-09-2005, 07:28 PM
Ron's Avatar
Ron Ron is offline
Tell Mr. Bill!
Due to the current economic conditions...the light at the end of the tunnel has been turned off.
Meet you at the finish line.....don't be late!
  #96
Old 07-09-2005, 09:37 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Ron:
Tell Mr. Bill! </div></BLOCKQUOTE>
I would if he ran timing chains on the GTO or digger. Both have BOP belt drives, so he has no worries.
  #97
Old 07-10-2005, 08:40 PM
Ron's Avatar
Ron Ron is offline
But he does have customers that don't run a belt drive......ME!
  #98
Old 07-11-2005, 09:53 PM
dragrcr dragrcr is offline
GOATMAN If you go to pontiac zone they have a post with dyno results showing the torque and horse power gains from this new product.
  #99
Old 07-13-2005, 07:32 AM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
to both Rons ,i don't think hes aware this item available yet .
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
  #100
Old 08-09-2005, 11:37 AM
Copied from another post .
Pitch 400
Senior Member Join Date: Nov 2004
Just recieved my timing gear bearing kit from Scott Sims. Very nice set-up to locate cam position. 7 day turn around time too. His E-mail address is [email protected].
