Old 04-13-2007, 03:01 PM
Venomous Type's Avatar
Venomous Type Venomous Type is offline
^ this one is lusty lady for sure..
  #82
Old 04-13-2007, 10:58 PM
blown, sharp car. i walked away from a htp that was a sister to yours several times, d/a that i am. by the time i had decided to make an offer on it someone had stripped it and it was too far gone.
mike
former." --Albert Einstein
- Winston Churchill
  #83
Old 08-02-2007, 10:34 PM
PITTSBURGH 64 PITTSBURGH 64 is offline
I like the chrome wheel but without the white wall.
  #84
Old 08-03-2007, 09:21 AM
Teej's Avatar
Teej Teej is offline
Originally Posted by 6T5 Cat
I have it on the lift now converting it to 4 wheel discs with a hydro boost unit; installing a new T400 with a Gear Vendors unit;
Bob
What's a hydro-boost unit? Is that the Power Brakes via power steering pump? Where did you get that setup?
Thad
1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver
1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!!
  #85
Old 08-04-2007, 12:15 AM
yes that's a hydroboost.
any mid 80's gm diesel will have one. they also came on 1 ton and hd trucks.
mike
- Winston Churchill
  #86
Old 08-15-2007, 11:51 PM
formula4disaster formula4disaster is offline
I'm late in the game but here's my 65 with Rally II's, 225/70/15's and yes they rub on the outside (on the fender skirt mount) in turns in the rear...
(looks better now that I've shined up the tires!)
I'd like to put some 17's and 255 wide tires on if I can manage it. Problem will be rubbing in the front on turns near full lock.
'65 Bonneville 2-dr HT
'77 Firebird Formula 4-speed
  #87
Old 08-16-2007, 11:15 AM
i'm glad to see someone else runs the rally's without the trim rings.
sharp car!
mike
- Winston Churchill
  #88
Old 08-16-2007, 11:40 AM
Stuart's Avatar
Stuart Stuart is offline
Good looking car! Wish I would have kept my '65 GP.... I like the Rallye wheels better without the trim rings as well.
  #89
Old 08-16-2007, 02:33 PM
I'll give it a third without the trim rings. The rallys look best on the 65-69 B bodies.
  #90
Old 03-20-2008, 04:00 PM
cjb2216's Avatar
cjb2216 cjb2216 is offline
heres my new center caps
ID:	126431   Click image for larger version
Name:	full car 2.jpg
  #91
Old 03-13-2009, 07:47 PM
Poncho60 Poncho60 is offline
Default Custom center caps revisited
I posted on here quite a while back. Just thought I'd update what I've done with the caps I was working on---they fit on the slotted "corvette" style wheels I have on my 60 Pontiac. They just seemed to be lacking something before, so I had some additional work done on them-----I think they look much better now. The pics kinda suck--hard to get a good shot with the glare off the polished aluminum.
ID:	161682   Click image for larger version
  #92
Old 03-16-2009, 02:50 AM
strato gto's Avatar
strato gto strato gto is offline
Rally 2's on a 64
ID:	161967   Click image for larger version
