#81
Factory heater delete? Heck ive never even heard of that???
My 67' Is a hardtop, HO,AT, PS, PB, AC, rear antenna car. Thats not rare compared to alot of this stuff...... |
#82
race cars...hardcore racecars were ordered with factory heater delete
And some cars in warm climates, evidently
Clay Marsh 1967 GTO convertible Twin Turbo 5spd project http://forums.performanceyears.com/f...d.php?t=618281 http://www.youtube.com/watch?v=eJ9KworCMRE |
#83
Some even deleted sound deadener and seam sealer.
Greg Reid Palmetto, Georgia |
#84
I know its not main stream, but how about a 66 Lemans Sprint, with factory A/C, Reclining Pass Bucket seat, with head rests, tinted glass, 2 speaker AM radio, & Automatic. Added incorrect 67 Rally II's (hub cap car) Aftermarket 6 cylinder tach, and hazzard light switch, & duel master cylinder (after one of the original front brake hosed burst!!!!)
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
#85
My first 66 GTO had the shoulder belts up over the doors. The attachment points were where the map lights would be. The catalogs show the clips that held them up along the top of the door, but show them for the 68-72. But they show 4 clips for 68-72, my 66 only had one on each side. So you had 2 separate belts for seat and shoulder, and 2 latch belts next to the console fastened with one bolt. Anyone else have this option installed?
I sure wish I'd taken pictures of that car's interior. (We need a kick my a** smilie). The strange thing with that car too was the wood grain vinyl on the console top where the black paint normally is on all the others.... between the chrome strips too. I can only think that someone must have added it to match the wood dash. I even had the rear defroster in the package tray with one rear speaker (semi stereo LOL).
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
#86
67gteeoh, My 65 Lemans was also a Hawaii car with a heater delete 584 option.At some point a heater was installed.Would like to return back to original. My question is how did they block off the water pump and block? Thanks Saltman
1965 Lemans Vert 1968 Shelby GT 500 KR |
#87
Here is my friend Rick Holladay's old 65' Drag car.
It was ordered with several deleted items and factory painted Chevy Forrest Green. He also stated that he had the car ordered stripped of all seam seal &/or sound padding. He bought it for one purpose only ![]() http://www.mecum.com/auctions/lot_de...D=SC0509-79418 She just sold again for $152.500.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
#88
I'm not sure what the factory used in 67 but when I bought the car it had rubber caps clamped to the water pump and at the Rt cyl head location to block off the heater hose connections. I found that Advanced Auto ( and have seen then at Auto Zone) carries a "Bypass Kit" which consists of several different sizes of rubber caps. They are usually located in the section that carries Fix-it parts such as door window cranks, master cyl gaskets, grommets, etc. They are not re-inforced so I check them often for bulging and cracking and replace them frequently. I usually carry an extra set in the center console "just in case" one decides to go south on me. You can see the cap on the attached pic at the water pump housing. The same is at the cyl head. Wayne |
#89
Wayne, Thanks for the info. Bought mine from the second owner who got it from his brother who was stationed there. Who knows maybe our cars crossed paths there. All I know it sure is a long way for a couple Pontiac's to travel to be owned by two Southerners. And the tip on the caps,will put them in the console next to my "just in case" points & condenser.By the way engine looks great love those pancake air cleaners. Thanks again Saltman
#90
First off,sorry I don't have any pictures to post.
My 67 Sport Coupe has 30 factory options.All are still on the car with 48,xxx original miles. My PHS reproduced window sticker has a total of $1492.90 in options for a total of $4436.64. TH-400 AM Radio Push Button Rear Speaker Rear Defogger Door Edge Guards Vanity Mirror Remote O/S Mirror Luggage Lamp Roof Rail and Reading Light Underhood Lamp Ignition Switch Lamp Custom Seat Belts Front,Rear Cruise Control Deluxe Wheel Discs Console Elec. Clock Exhaust Extensions Remote Control Deck Lid Power Steering Power Front Disc Brakes Soft-Ray Glass All Windows Power Windows Reclining Seat (Passenger) A/C Closed Circut Crank Case Vent Ride and Handling Package Floor Throw Mats-Front Floor Throw Mats Rear CD Ignition Safe-T-Track Diff. |
#91
So it was black with texture in lieu of wood grain? The only ones I have seen are wood grain. I would kill for one of those for my 67 Tempest drag car, already have the radio delete in black texture. |
#92
Humm,Ill have to look and see if I have some old photos.
#93
Since the original thread was 66-67.I have a NOS Compass for 67.One year design only.Mounts under the dash.Also,a NOS Spare Tire Locking Set-66-67 option-dealer.Although,62-67 it was available.Not the Corvette lock which some guys use.Both are rare options. bigpop Larry B.
Mr. President, you can't say Dallas doesn't love you " |
#94
Seems like that was the way to go if ordering a car in Hawaii....who needs a heater!! Before you proceed with returning your 65 to original heater delete condition, you may want to check on availability of the heater delete plate. I don't believe that any aftermarket company reproduces them any longer. You do have the option of fabricating one. Wayne |
#95
Wayne, Don't need a heater down here to often but wish it had A/C. Ames has a block off kit for the engine compartment. Dont know accurate it is. But have never seen a heater delete in person. So who knows.Think I can fabricate a dash panel for it.But it is an odd option saved 73.00 bucks according to the PHS on my car.Thanks Saltman
#96
There's a small problem with your option count. TH400 included the console. A column shifted auto would therefor be a "delete". Soft-Ray glass (all windows) was standard with A/C.
Even though you didn't mention headrests, they're a perfect example. The reclining seat came with headrests, but you cannot count it as two options even if it clearly trumps the "lesser" option. Nice option list though...
#97
I think not on the soft ray on all glass.
Have a factory a/c post car with only a tinted shaded windshield. I see if I can dig up the info on a 66 Sprint that was a zone promo car. I believe it had more that 30 options. |
#98
I had a low option '74 T/A, non AC car. It was the only car I've ever owned that did not have that tint at the top of the glass. That's when I learned about the optional upper tint.
#99
At least in 66 Only the windshield came tinted with A/C, the side and back glass was extra, I have a 67 Sprint Lemans that has clear glass, that is the only car I have ever owned without tinted glass.
#100
Heres info on the 66 Sprint:
332 Sprint 342 AM radio 377 foam cushion,spare tire cover,rear defroster 382 door edge guards 397 Visor mirror,inside tilt mirror,OSRV mirror 407 Trunk lamp,glovebox lamp,roof rail lamp 421 underhood lamp 431 custom seat belts 444 electric clock 454 rally wheels 464 decor mouldings 482 exhaust splitters 507 Power steering,power brakes,tilt wheel 522 red plastic fender liners 531 tinted glass 551 power windows 561 power bench seat 582 air conditioning 621 ride and handling package 633 front/rear floor mats CB 775x14 WSW tires 74G 323 rear axle ratio ZE 4 bbl OHC-6 77L Sprint option /auto trans 782 auto trans All this info was compiled by Fred before there was PHS. We both agreed that we have never seen a more highly optioned 66. This car was a Jacksonville zone company car. |
