Old 10-22-2008, 09:04 PM
wwilder9's Avatar
wwilder9 wwilder9 is offline
Here is pictures of my rocker, might need some repair also.
ID:	146259   Click image for larger version
ID:	146260   Click image for larger version
ID:	146261   Click image for larger version
ID:	146262   Click image for larger version
68 Firebird Coupe 350/Auto/Air
70 RA III Formula/Auto/Air
71 T/A 455HO/Standard/Air
73 T/A 455/Auto/Air
  #82
Old 10-22-2008, 09:08 PM
wwilder9's Avatar
Here I cut off rest of LH quarter panel off. Need to blast now.
ID:	146265   Click image for larger version
ID:	146266   Click image for larger version
ID:	146267   Click image for larger version
ID:	146268   Click image for larger version
73 T/A 455/Auto/Air
  #83
Old 10-23-2008, 08:04 PM
That car is lucky it found you. Don't think many others would have taken that on...!
  #84
Old 10-23-2008, 09:58 PM
wwilder9's Avatar
I always wanted a early 1970-1973 TA, They are just so hard to find, It took me about a month of searching to find this 1973 TA with original motor,trans, and rear end. Every one I looked at, the seller either wanted 35K and up for it, or it was really a clone, or not a original motor car.
73 T/A 455/Auto/Air
  #85
Old 11-06-2008, 08:58 PM
wwilder9's Avatar
Latest pictures after blasting and cleaning undercoating out of inner wheel house.
ID:	147718   Click image for larger version
ID:	147719   Click image for larger version
ID:	147720   Click image for larger version
ID:	147721   Click image for larger version
73 T/A 455/Auto/Air
  #86
Old 11-06-2008, 09:02 PM
wwilder9's Avatar
Anyone know what this stamped number is in the wheel house on first picture? I've seen it on other cars also, But always on driver side.
ID:	147723   Click image for larger version
ID:	147724   Click image for larger version
ID:	147725   Click image for larger version
ID:	147726   Click image for larger version
73 T/A 455/Auto/Air
  #87
Old 11-06-2008, 09:10 PM
wwilder9's Avatar
Here are pictures of the rocker all welded up. Getting close to putting on quarter panel. Question for everyone, my NOS quarter has a tab that bends back on top of the rocker panel, and looks like originally it went under that support beam the striker bolts to, Do I have to break that support beam lose from the rocker panel to install new quarter panel? For anyone who has done NOS quarter panels they should be able to answer this question. thanks everyone in advance.
ID:	147728   Click image for larger version
ID:	147729   Click image for larger version
ID:	147730   Click image for larger version
73 T/A 455/Auto/Air
  #88
Old 11-07-2008, 01:04 AM
x-bird2 x-bird2 is offline
there's really no good way to get at that particular spot. yes, the tab on the quarter goes between the door support and the rocker. problem is, how do you weld the three layers back together? if you can find a way to get at that weld point, lmk! i used structural automotive urethane adhesive on mine. the "old" way of doing it was to trim the tab back, leave the support in place--and any rust between it and the rocker-- and then weld the base of the quarter to the rocker following by grinding a groove in it to look factory. that area always made me curious as to what kind of resistance welding rig they used to put that area together.
  #89
Old 12-30-2008, 12:36 AM
wwilder9's Avatar
Default More Progress
Hello Everyone and Happy Holidays,
Well it was warmer yesterday and today, so I got some work done on the car, Have to remind myself to buy that heater for the garage, But anyways, I tacked my outer wheelhouse into place and wanted to test fit my NOS quarter panel and my NOS tail panel. Took me about 3 hours to get every thing lined up. Too bad I have to take it all apart to finish welding my outer wheelhouse on and make a bunch of holes in my quarter panel and tail panel so I can weld them into place, But At least I know everything fits correctly and all my body lines and gaps look correct. I compare the gaps to my other car and using it for reference.
ID:	152866   Click image for larger version
ID:	152867   Click image for larger version
ID:	152868   Click image for larger version
ID:	152869   Click image for larger version
73 T/A 455/Auto/Air
  #90
Old 12-30-2008, 12:40 AM
wwilder9's Avatar
Default Few more pics
More Pics!
ID:	152871   Click image for larger version
ID:	152872   Click image for larger version
ID:	152873   Click image for larger version
ID:	152874   Click image for larger version
73 T/A 455/Auto/Air
  #91
Old 12-30-2008, 08:22 AM
keepat's Avatar
keepat keepat is offline
1st class job! looks Awesome!
Pat
  #92
Old 12-30-2008, 10:10 AM
looking good. reminds me of what i did to mine. just curious if you decided on a method for the quarter to rocker?
  #93
Old 12-30-2008, 08:11 PM
wwilder9's Avatar
How I did my quarter panel to rocker was to first to spot weld and reinforce the inner bracing so the quater panel slides underneath like the original, I then using the thinnest cut off wheel I could find and cut a slit between the rocker panel and the inner bracing so the new quarter could just slide right into place. I will also put a couple of tacks on the outside just to be on the safe side, Will also put at least one tack on inside through vent above stricker after quarter panel is installed. Here are a couple of pics of described areas.
ID:	152957   Click image for larger version
ID:	152958   Click image for larger version
73 T/A 455/Auto/Air
  #94
Old 12-30-2008, 08:20 PM
wwilder9's Avatar
I worked on the car again today, Its great being on vacation, Get to work on car at a faster pace. Here are some pics, I removed the tail pan and quarter panel so I could finish welding outer wheel house into place, I then painted everything, put weld through primer on areas that get welded, Also painted new NOS quarter panel on inside.
ID:	152964   Click image for larger version
ID:	152965   Click image for larger version
ID:	152966   Click image for larger version
ID:	152967   Click image for larger version
73 T/A 455/Auto/Air
  #95
Old 12-30-2008, 08:26 PM
wwilder9's Avatar
More pics.
ID:	152971   Click image for larger version
ID:	152972   Click image for larger version
ID:	152973   Click image for larger version
ID:	152975   Click image for larger version
73 T/A 455/Auto/Air
  #96
Old 02-15-2009, 09:19 PM
Father&Son73T/A Father&Son73T/A is offline
Thumbs up
Wilder9,all I can say is SWEET LORD JESUS
I'm glad we didn't have to go thru what you are doing......................
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
  #97
Old 02-16-2009, 10:46 AM
nice work. your car has rear spoiler, right? if so, make sure you fit the end caps before you weld it up. kind of interesting that your rocker was so rotted but your inner door support was fine. mine was gone halfway up and i had to fully remove it and refabricate most of the bottom of it, but the rocker was fine, the galvanizing held up very well. i'd recommend that when you do weld the quarter on, that you fully weld the seam shut. helps keeps the top corner of the door from cracking out.
  #98
Old 03-24-2009, 09:53 PM
wwilder9's Avatar
Hello Everyone,
Finished welding up driverside 1/4 panel a few weeks back. Here are some pics.
ID:	162897   Click image for larger version
ID:	162898   Click image for larger version
ID:	162899   Click image for larger version
ID:	162900   Click image for larger version
73 T/A 455/Auto/Air
  #99
Old 03-24-2009, 10:03 PM
wwilder9's Avatar
Does anyone ever re-lead these factory seams any more, I searched the web and most people use stuff called ALL Metal, I guess its like an aluminium filler, also read somewhere that it also has talc in it, and talc absorbs water? Any suggestions would be welcome, Someone told me to buy the lead kit from Eastwood, I have not decided what to do yet. Also here are More pics.
ID:	162902   Click image for larger version
ID:	162903   Click image for larger version
ID:	162904   Click image for larger version
ID:	162905   Click image for larger version
73 T/A 455/Auto/Air
  #100
Old 03-24-2009, 10:08 PM
wwilder9's Avatar
Also started on the other side 1/4 panel today, Did some paint stripping and blasting. This side was not as bad as the driver side, but still needs repaired, or replaced.
ID:	162907   Click image for larger version
ID:	162908   Click image for larger version
ID:	162909   Click image for larger version
ID:	162910   Click image for larger version
73 T/A 455/Auto/Air
