Old 02-11-2012, 09:56 AM
Nicks67GTO Nicks67GTO is offline
I cleaned up some old M/T valve covers and the stock HO air cleaner. I think im going to use these, they look pretty sharp.
  #82
Old 02-11-2012, 09:58 AM
Someone is getting excited to go for a ride this spring!
  #83
Old 02-14-2012, 11:19 AM
old66tiger's Avatar
old66tiger old66tiger is offline
I know the feeling. My car is still at the body shop. It will be sprint to the finish.
Skinned knuckles and empty wallet! Could I be any happier?
66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front).
2002 Ram Air WS.6 convertible Trans Am. Wife's car.
  #84
Old 02-14-2012, 11:29 AM
That motor looks fantastic. Looks like someone just laid it in its bed. Perfect!
  #85
Old 02-14-2012, 11:47 AM
old66tiger's Avatar
Saw you are running the Richmond transmission. How does the shifter come out in comparison to stock? I considered using them but no one could give me a straight answer as to how far the shifted would be off. I think Richmond is missing out in this market by not making a tranny that is a direct fit for our cars.
  #86
Old 02-14-2012, 12:42 PM
It fell in the tunnel. No mods necessary. Not even a ding in the floor. I'm running the old street 5 speed with the 1:1 5th gear. It has a Long H pattern shifter. I ended up cutting the tunnel hump top out and replacing it with something thicker for a better and much more tap able shifter boot mounting surface. I think i had to move the hole back 4" center to center from stock. I still have the original piece i cut out. If i get a chance ill measure and let you know exactly. I also had to lower the tranny crossmember mounting surface about a 1/2" That took a little bit of time there.
  #87
Old 02-19-2012, 10:52 AM
Mounted up my tach and gauges. I just stuck with the old autometer sport comp stuff. I wanted to do the new/old Stewart Warner Green Line stuff but WOW they don't give them away. I also dont like the look of the flat gauge panel everyone uses so i opted for some cups for the temp/oil pressure gauges below I also angled them a bit tward the driver seat. I think it turned out well. I mounted the tach where i did so it didnt block the view of the speedometer or gas gauge. Its just blocking a couple idiot lights and you cant even tell i have a tach in the car from outside. Semi-stealth. I'm not in love with it but its probably my best option.
  #88
Old 03-17-2012, 01:12 AM
Well I haven't posted anything on here in a bit. I figured id update. I got My HEI dropped in and plug wires ran. I squared away a bunch of torn up factory wiring thanks to some gentlemen on this board. I fired it off today. If you click the sideways video you can watch a quick minute of it. I also have a couple shots of the plug wire separators i used. R&M specialties from Summit. for 48 bucks these look great, are very reasonably priced, made in the USA, and are high quality IMO. I posted both of these in the street section but i figured id do it here since this is my project thread.
  #89
Old 03-17-2012, 01:15 AM
I also have to plug M&H for their superior customer service and products. I got an engine harness from those guys to eliminate my external regulator and add and HEI. It is top notch product. They have a customer for life.
  #90
Old 03-18-2012, 10:22 PM
Another video walk around and some shots after I gave it a bath today!
  #91
Old 03-18-2012, 10:23 PM
click on the top picture for a video
  #92
Old 03-18-2012, 10:46 PM
fyrffytr1's Avatar
It sounds as good as it looks and it looks great!
  #93
Old 03-19-2012, 11:23 AM
Thanks!
  #94
Old 03-19-2012, 01:22 PM
Question: What did you do with the small heater hose coming from the water pump? I see clamp but no hose.
  #95
Old 03-19-2012, 04:50 PM
I rubber capped it and used a radiator clamp to secure it. I did the same on the rear passenger side cylinder head nipple. Im not hooking my heater up for a while so i didnt see a need to run it. I'm not going to hurt anything am I?
  #96
Old 03-19-2012, 06:32 PM
Well I dont know but I have mine running to the back of the motor. I dont have it going to the firewall because I dont need heat. I never used it and the heater core went out.
Maybe someone can chime in? Id love to do what Nick did and get rid of that hose.
  #97
Old 03-19-2012, 06:45 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
No worries... You're perfectly fine by capping both of those fittings. You won't hurt a thing. I've done it many times over the years for similar reasons.
Of course I do have my heaters all hooked up these days, but that's 'cause I have that thin Arizona blood!
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
  #98
Old 03-19-2012, 07:03 PM
Mine is only capped until i install vintage air
  #99
Old 03-19-2012, 08:02 PM
F ROCK's Avatar
F ROCK F ROCK is offline
cool thread!
realy cool car and story!
  #100
Old 03-19-2012, 10:09 PM
lust4speed's Avatar
Only thing I would recommend is to not use those lousy rubber caps. I've seen them go bad on the shelf at the auto parts store - the top of the cap rots off. Better to cut a 3" or so piece of heater hose and clamp it to the nipple and find a solid plug for the other end of the hose and clamp the hose around it. A very short piece of 5/8" and 3/4" inch rod work good.
Also agree that there is no harm in blocking them off. If there was a problem, the drivers side of our engines would have self destructed years ago.
Mick Batson
