Old 01-06-2010, 11:00 PM
SD421's Avatar
SD421 SD421 is offline
Les, no worries about the top photo. The pics you took tell the story. Thank you so much.
I had a friend back in the 80's who did what you are doing but he ran the 5/16" tubes down along the inner wheel wells then attached rubber hoses and then ran them through the upper trunk part so that the hoses came out above the rear axle.
Ive never seen it so your pics now give me a better idea on how to do my 66 Goat.
Thanks for your trouble,
Don
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
  #82
Old 01-07-2010, 01:28 AM
The car is standing tall Les. Nice work!
  #83
Old 01-07-2010, 08:19 AM
Old Goat 67's Avatar
Thanks Les, I appreciate your effort.
I will build my new one's today.
Charles
  #84
Old 01-07-2010, 09:48 AM
gearbanger's Avatar
gearbanger gearbanger is offline
I am planning to do this trick to my 67, but I was going to weld in a short nipple in the side panel, which would be the part of the quarter panel that wraps around to the window well. I was going to use 5/16 or 3/8 tube and attach a hose on it above the wheel tub and run it forward into the quarter window compartment. Plenty of water in that area already so no worries about a little more.
  #85
Old 01-07-2010, 09:50 AM
gearbanger's Avatar
There is one more area that I am going to try some trickery on and that is the rear tail panel above the trunk key hole. I am planning to make a small "gutter" into the weatherstrip channel to dewater that area. Seems like alot of cars rust out there due to it holding water in that low point.
  #86
Old 01-07-2010, 11:53 AM
wheelspin's Avatar
Arrow Other areas that retain water.......
I was fortunate that my GTO was built in Fremont and never left sunny SoCal; the rear window gutter was the only badly rusted area, save some surface rust in the trunk (probably caused by the rubber mat) and the driver's footwell. Actually, the leaking rear window and the rusty orange patina on the rear deck and tops of the fenders is what triggered this resto since the old survivor car looked pretty sweet otherwise, @ least in pics .
Les
ID:	193168   Click image for larger version
ID:	193169   Click image for larger version
ID:	193170   Click image for larger version
ID:	193171   Click image for larger version
Les Iden
  #87
Old 01-07-2010, 08:42 PM
GT182's Avatar
GT182 GT182 is offline
Looks great Les, I love the color. They did a great job.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #88
Old 01-07-2010, 11:02 PM
wheelspin's Avatar
Cool Thanks.........
Thanks for all of the comps, guys , I really appreciate it.
Les
Les Iden
  #89
Old 01-08-2010, 07:49 PM
SupergasDil's Avatar
Very nice job Les. That is one great looking 66, but then again, it's hard to go wrong with the best looking year GTO that Pontiac made. That's for Mick B
  #90
Old 01-08-2010, 08:13 PM
rexus31's Avatar
rexus31 rexus31 is offline
I just got back from checking out Les' '66 and it looks phenominal. The pics don't do it justice. I can't wait to see it finished.
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
2015 Jaguar F-Type 340hp Convertible, Polaris White/Ebony Interior
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red/Black Interior
1965 Chrysler 300 Convertible, 383/727TF, Factory Air, Spanish Red/Red Interior/White Top
  #91
Old 01-08-2010, 08:20 PM
lust4speed's Avatar
To my Okie friend sitting in 5° weather while his old home town is 70°
Only way to make it finished is to turn it into a '67.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
  #92
Old 01-08-2010, 09:09 PM
GT182's Avatar
Hey Les, now get the parking lights to come on and stay on with the head lights, and add sequential turnsignal kit to the rear. It'll look extra sharp.
Gary
  #93
Old 01-08-2010, 09:55 PM
GearJammer's Avatar
GearJammer GearJammer is offline
Congrats on the nice build and thanks a bunch for posting those drain images!
  #94
Old 01-11-2010, 09:43 PM
wheelspin's Avatar
Cool Back on the job...........
Made a lot of progress since bringing the GTO home last week. Installed the new grill along w/ new park light lenses and re-chromed bezels, and finished up the rear w/ polished & re-chromed parts. Tomorrow I'll tackle the rat's nest of wires under the dash, install some quality sound deadner, and trial fit the carpet. Note the bitchin' hood hinges, restored by good friend and master craftsman Roland Hall, who advertises his services in the Smokes. I need to find some special huts for my long rear wheel studs, which are necessary for my thick Weld wheels that I race with.
Les
ID:	193502   Click image for larger version
ID:	193503   Click image for larger version
ID:	193504   Click image for larger version
ID:	193505   Click image for larger version
Les Iden
  #95
Old 01-11-2010, 10:08 PM
wheelspin's Avatar
Thumbs up New interior..........
Began by thoroughly cleaning the floor and then surgically removing a ton of old alarm wiring and relays for the door locks from under the dash. Then I applied the Raam mat (silver foil up) to most of the open areas, followed by the thin black closed cell foam applied over the the mat and held in place by spray adhesive. Once the sound deadner was completed I trial fitted the new carpet after first measuring for the shifter location and then cutting a suitable groove in order to clear it. Tomorrow: final fit carpet, door panel water shields, door panels, kick panels, trunk divider, package shelf & rear speaker, seats, and console. That's the plan anyway .
ID:	193516   Click image for larger version
ID:	193517   Click image for larger version
ID:	193518   Click image for larger version
ID:	193520   Click image for larger version
Les Iden
  #96
Old 01-11-2010, 10:16 PM
This kind of perfection is nothing unusual for Les, all of his stuff is top-notch.
I've been watching and checking out your progress, just another winner from Wheelspin's Garage.
Bart
  #97
Old 01-11-2010, 10:17 PM
wheelspin's Avatar
Talking New carpet, @ last.......
Many thanks, Bart .
Test fitted the carpet, a little final fitting/trimming and then new sill plates, I'm digging it .
QUESTION, IIRC the factory cut the carpet to in order provide small flaps that served to cover up the bucket seat mounting brackets fasteners. Anyone have a pic of a survivor car's carpet illustrating how they did it @ the factory?
Thanks, Les
ID:	193523   Click image for larger version
ID:	193524   Click image for larger version
Les Iden
  #98
Old 01-11-2010, 10:34 PM
rexus31's Avatar
Looking good, man. You'll be back on the road before you know it.
  #99
Old 01-11-2010, 10:39 PM
wheelspin's Avatar
Arrow
Hey Scott,
Thanks for your help with sourcing the sound deadner. Do you suggest using the Raam mat on my insulated trunk divider?
Thanks, Les
Les Iden
  #100
Old 01-11-2010, 11:39 PM
rexus31's Avatar
With it being insulated, you may not need to. I recommend calling the manufacturer and getting their input.
