Old 07-15-2010, 08:07 PM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
Originally Posted by ho428 View Post
I'd like something like that as well.
As my Road Race car gets more and more radical I'm leaning toward installing a 440 with Lynns heads.
This guy running a Hemi had an issue with fuel slosh under braking and cornering and had to get away from Holleys.
I think something like this on a set of Aluminum V heads would be killer.
Looks like an easy deal to do to me.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
www.ChemicalManagementIndiana.com
317-260-3486
  #82
Old 07-15-2010, 08:10 PM
Default picture
intake without top
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
  #83
Old 07-15-2010, 08:16 PM
goatasaurus rex's Avatar
goatasaurus rex goatasaurus rex is offline
BAD AZZ!!!
69 GTO 11:[email protected] all balls no bottle
406 d-port iron heads 3700lbs all steel
  #84
Old 07-15-2010, 11:04 PM
R 70 Judge's Avatar
V stuff is so freaking cool!
James
1970 Trans Am
  #85
Old 07-16-2010, 06:55 AM
60man's Avatar
60man 60man is offline
That's one hell of a "Bathtub".!!
More like a watering tank for livestock !
ECM member.
MANDRA
  #86
Old 07-16-2010, 03:04 PM
Remember....it is made large for big motors. Tony said up to 700 cu in? Where have we heard that number before? A smaller motor you simply mill the top to decrease plenum size. This idea cam from Adger Smith 5 years ago, love the concept. Thanks to my tooling guy for making it a reality. Took too long as my rocking chair is upon me.
It is 2-3 inches taller than the stock intake set up.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
  #87
Old 07-16-2010, 03:11 PM
This intake with a flat top should be close to the stock height. I will publish numbers as soon as I can.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
  #88
Old 07-16-2010, 03:38 PM
428RA4's Avatar
428RA4 428RA4 is offline
cool -
Im game if a few more folks jump in and want it.
  #89
Old 07-16-2010, 04:25 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Originally Posted by 455-4+1 View Post
Please excuse my ignorance, we dont see much exotic Ponty stuff down here LOL
Do the RAV not use a bolt to the head outboard of the rear runners ??
Just looking at the TR picture
By the way, awesome effort on getting this deal together
Working on going faster (and now staying dry at the same time !!)
  #90
Old 07-16-2010, 04:27 PM
428RA4's Avatar
He was referring to the lack of bolt holes to mount the intake to the heads.
Old 07-17-2010, 01:18 PM
Yeah we need watering for all those horses!!!!!!
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
  #92
Old 07-18-2010, 02:51 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
... Do the RAV not use a bolt to the head outboard of the rear runners ??...
Can't some of you RAV guys be polite enough to answer the question?
  #93
Old 07-18-2010, 08:21 AM
tom s tom s is offline
factory intakes use 5 bolts each side to hold them down.Tom
  #94
Old 07-18-2010, 10:01 AM
spartazoo's Avatar
spartazoo spartazoo is offline
I was wondering the same thing.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
  #95
Old 07-18-2010, 10:10 AM
Tom Vaught's Avatar
Boost Engineer
http://www.bopengineering.com/rav_du...bottom_b.shtml
Tom Vaught
ps Most would never say that I was Polite, (like polar)
  #96
Old 07-18-2010, 05:07 PM
455-4+1's Avatar
Thanks Tom and others
So these obviously dont use a Std RAV bolt pattern for the intake then as there looks to be no material in the flange for an outboard bolt at either end ??
Hmmmmmm........
This picture of the head shows what looks like additional bolts as well as the outboard factory locations
Maybe this is how the TR intake bolts up using these and not the outer factory location
  #97
Old 07-20-2010, 07:04 PM
All these intakes will have the stock Pontiac bolt pattern. We are doing the front water neck cross over separately since all our RA-Vs will have reverse cooling. We will also have the ability to use regular flow cooling. More pictures soon.
I took the intake to BES and Tony likes it! We are starting to finish up the first RA-V crate motor in the next couple of weeks.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
  #98
Old 07-21-2010, 01:57 AM
455-4+1's Avatar
I still dont see how it can use the "stock Pontiac bolt pattern" outside of the rear runner
Separate water crossover I am OK with and having a "short flange" outboard of the front runners.
From what I have seen with stock RAV intakes 3 of the holes are above the lines of the port with the two outboard ones slightly lower
From the tunnel ram pics it looks like there is no flange in that location. Hence my query about the two extra "non Pontiac" holes lower toward the deck inboard of the outer runners ? These must be redundent or for some other purpose as they arnt in the "stock location" Possibly for a future blower mainifold ??
I would have thought that the TR would have required a longer flange at the rear to pick up the rear factory bolt location (This would typicaly be the same offset from the outer runner at the front to allow heads to be swapped from side to side)
Hopefully I am missing some thing simple here
  #99
Old 07-21-2010, 06:41 AM
Lynn, nice article on your 'Crate Engines' in Pontiac Enthusiast magazine.
  #100
Old 07-21-2010, 09:30 AM
Brian Baker's Avatar
The mounting holes aren't cast-in, so with enough meat in the head, they can be drilled and tapped anywhere you want them...just a matter of changing the program on the machine.
