Old 11-13-2010, 03:05 AM
PONTIAC-ONE's Avatar
PONTIAC-ONE PONTIAC-ONE is offline
Originally Posted by ry57pont View Post
i finally figured out how to scan, here are my dyno runs with the xe274
....and at 5200 RPM down it goes.
2 sons, 2 Firebirds. 1971 Formula 455, 1972/w 455 HO added.
1974 Formula 400 "retired", parts car now.
  #82
Old 11-13-2010, 01:22 PM
Region Warrior's Avatar
Originally Posted by Brent Flynn View Post
I dont agree with this statement wholeheartedly.... HYdraulic roller cams(the right one, of course) can make more power and torque at or less than 6000rpms... if i had the money, i'd try a set up like that. On the other hand, this XE cam sounds like a doorstop to me....my cams are 100% streetable and will run deep into the 11's all day with a decent set of heads, iron intake and qjet... im already at 11.57/114.05(ran 114.95 with taller tires) and im shifting at 5300rpm. When i gear back to 3.73, i will go 116-117. I dont have any ''trick'' stuff. The closest thing i have on my bird to that is 1.5 Harland Sharps... it would run just the same with stock rockers. Im gonna flog the crap outta this combo... im seein 11.30s before its all over... and i dont have ported heads or intake. Basically, torque is what we're after... thats what gets the car moving... horsepower is for guys that have big heads, bigs gears and big cams/intakes.... just sayin
Brent, did you notice i posted "other then roller cams"?
  #83
Old 11-13-2010, 05:03 PM
Chupa's Avatar
Chupa Chupa is offline
I went low elevens 11.30s I think even a couple 11-teens with a 284XE - 3300lbs 3.73 JBP 6X heads . 9.5 comp.
It did alright for me - I would have like to compare it against a 290b - I know the 290b would have won out...
  #84
Old 11-15-2010, 05:38 PM
Raven Blayde's Avatar
Raven Blayde Raven Blayde is offline
I'm certainly having some MAJOR issues with my XE274H cam. I've got it in my 9.5:1 400 and since switching to this cam, the engine runs terrible and overheats in just a few minutes. The engine ran fine with the 290B solid cam, but I felt it lacked bottom end and the cam was simply too big for my 9.5:1 400. So, I switched to the smaller XE274H with hopes of picking up some lowend torque. That's when all heck broke loose. I've been through everything on this car (radiator, flushed the engine block, hoses, valvetrain adjustments, waterpump, timing, and have even installed a new distributer). Results- Nothings working. The car runs hot and detonates really bad after just a few minutes of run time. I even contacted Comp Cams tech people to try to get an answer and the reply I recieved today was that they've been bouncing this issue around the office for days now and nobody can come up with an answer. I've got the engine back apart now and can find nothing wrong with anything!!! Timing dots are lighned up perfectly, but it acts like it's WAY too advanced when running. Even at 32 degrees total, it detonates and overheats. So far, I really HATE this cam.
  #85
Old 11-15-2010, 05:56 PM
aktattoo's Avatar
aktattoo aktattoo is offline
dot to dot? did you degree the cam to see if its correct?
1970 Bonneville Convertible
  #86
Old 11-15-2010, 06:45 PM
Mr. P-Body Mr. P-Body is offline
Bobby,
I was thinking the same thing. It's advanced too far. The cam (in and of itself) won't cause all that.
Jim
  #87
Old 11-15-2010, 07:00 PM
chiphead's Avatar
chiphead chiphead is offline
Raven, You still don't have it fixed? Degree it already, LOL!
  #88
Old 11-16-2010, 04:59 PM
I know, I know, degree it!! lol... I've been checking into it and it looks complicated (and it's something I've never atempted before either). After seeing all of the bad feedback on this cam, I'm not sure it's worth the aggervation. From what I'm gathering from this thread, even if I degree it and get it correct, it's still not gonna run like I'm wanting. It would be like trying to polish a turd. lol... I'm kind of in a spot now where I'm trying to decided what to do next. I could degree the cam and HOPE it will fix the issue and run decent enough to make me happy. I could put my 290B solid back in and live with the lack of bottom end, OR get another cam (again). I'm telling ya guys, I'm SO sick of working on this car (and especially sick of replacing cams). At the moment, it's all apart and sitting in the garage, so it's whatever I wanna do I guess. Right now, I wanna set it on fire and watch it burn.
  #89
Old 11-16-2010, 05:26 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Put a Crower #60310 solid in it,and I'll bet money you'll be happy in all those areas.
But do please degree it.
It's really not that hard at all,it just requires some specific tools to do.
All cam installs should be degreed.
FWIW
Bret P.
This space for rent...
In the meantime,check out the cars HERE.
