THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
#81
I think the beams go all the way to the edge of the wall, but not the sheathing I didnt put any low because I didnt want to mess with the stucco so far I have recorded about a 2 degree temperature difference in the living room without the AC running with the new vents Im pretty happy with that, should get even better when I put the elastomeric reflective coating on the roof
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
#82
Locations such as Burmuda commonly use light color roofs (required there) to maximize radiant solar heat reflection. Although often cost prohibitive initially, long term energy savings are a payoff and justification of elastomeric use. IIRC - elastomeric roofing repairs often performed with specific patch materials, adhesives, and heat devices (sealing heat guns). To minimize penetrations...just keep MECHANICAL and ELECTRICAL Contractors rooftop sharp objects, tools and dropped screws clean off of the roof. |
#83
I crunched the numbers and if I buy the one with the highest reflective rate, it will be around 900 bucks, which is steep if you just look at initial cost (which my wife did and made this face ) but I think it will help energy cost and help the roof last longer, so its like a 1 stone 2 birds thing After looking around, I bought this stuff http://henry.com/roofing/coolroofcoa...iteroofcoating On my roof there are areas where the AC ducts routing pop up higher than the roof, and I think these littel roof sections will benefit me the most by coating them
#84
So this weekend I got up on the roof, cleaned it (scrubbed, pressure washed and used chemicals in some areas) and prepped it to put down the elastomeric coating.
I got the thickest nap roller I could and I carried the 5 gallon buckets up on the roof (that was hard enough) So the first coat I put down was in the north-south direction. I decided to first put a thick coat on the portion of the parapet wall that was vertical and curved down to the flat part of the roof. Then I attacked the flat part. What I did was apply the coating first to the part of the roof furthest away from where I got on the roof, then worked my way in. I had calculated that I would need 10.8 gallons for this portion of the roof. I think I was right above 10. If you want to do this, make sure to get good quality rollers and handles. I thought I was going to reuse the ones that I bought to paint the inside of the house, baaaaad choice, those lasted maybe an hour and they broke. So I went to home depot and got mid-grade wood ones with metal thread inserts. bad choice again the metal thread insert started loosening and didnt want to stay on the wood, then the extension handle snapped in half. I finally got the first coat down after about 5-6 hours, I let it dry for a few hours and the first part I had applied it to wasnt tacky anymore so I started on those. The second coat went on way faster. At first I wasnt using enought of the coating, so I had to go back and redo some of the stuff I had first done, but after I figured that out (about one dip per roll) it went super fast and I was done the same afternoon. Rough way to spend a Saturday
#85
Replaced the "tree ring" in the front yard last week. Tools needed? Wheelbarrow. Shovel. Short level. Skil saw with a diamond concrete blade. Concrete chisel and 3lb hammer.etc etc etc. I have all that stuff. I also recommend a good back and and 2 good arms. I have a bad back and one arm recovering from a little muscular mishap. Before/after.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
#86
haha my wife would kill to have grass and trees, but the water bill would kill us here in the desert, nice work David
#87
Very nicely updated David!
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#88
So Im thinking about redoing the kitchen countertops and the backsplash, I had been wanting to do it for a while, but I think the possibility of leaving NM has moved this to the forefront as I think it would help with sale
Here is pretty much how the kitchen looks as of right now (I installed the over the range microwave a little after we moved in) what do you guys think? I think the cabinet color really limits our options, my wife would like to refinish them in a darker color, and we could since they are fully oak and no particleboard, but I think the countertops and the backsplash will give it enough of an updated look
#89
Need some kitchen remodel opinions
Basically this is how my kitchen looks now: What do you guys think of these options: 1) Cabinets refinished to "Rustic" color and Olive Rust quartz countertops 2) Cabinets refinished to "Chocolate" color and Olive Rust quartz countertops 3) Cabinets refinished to "Espresso" color and Seleno quartz countertops
#90
love the last one. and ive done probably 25 kitchens
The Following User Says Thank You to 72pontiac For This Useful Post: | ||
#91
1st consult your wife 2nd if you're planning on placing your home on the market in the near future I'd suggest you consult with a highly recommended local Successful Real Estate Agent who specializes in your area. The RE Agent could be the best to advise you what will "sell" and is "in fashion" in the current market. |
#92
My honey do list is NO WHERE near to completion. The tile layers STILL haven't finished either bath which means I can't paint them, install the new baseboard and trim, ........
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
#93
I agree with you about changing the backsplash and counter tops only. I also agree with Alvin about consulting a Realtor.
You could spend a lot of money changing the cabinte color and not increase the asking price at all. The cabinets you have look to be in very good shape.
1969 Firebird 350 convertible, t-5, Carousel Red 2008 Solstice GXP 5speed manual, Sly 2008 Grand Prix, Ink Slate, Winter daily driver 2009 G8, Switchblade Silver, summer daily driver |
#94
yea my wife is on board with the remodel plans and actually the one that has been pushing 2nd, our realtor is probably the best in town and I havent had a chance to meet up with her because she is battling some serious medical problems. I will probably meet up with her assistant this weekend to see if it will be profitable The hard part is trying to match the regions taste (who wants a stucco flat roof house that is mono-chromatically brown/tan anyways...) Quote:
they are in good shape, but the previous owner didnt take care of the house at all and the places where you open the doors/drawers are much lighter than the rest of the cabinet and oil hasnt fixed it (also the first picture isnt a photograph its just the 3d model made to match my kitchen colors/materials)
#95
My wife has been wanting to get the 20+ year old carpeting out of our master bedroom.
Work has been a little slow so what better time then now. I didn't think of taking the before pictures until the project was already underway. Here is the room with most of the furniture out. Home Depot had the best match of the hardwood in the rest of the house and with the 10% vets discount the price was pretty good. Three days later here is the finished job. I know, I know, how may f****** pillows do you need on your bed. But if that is my only complaint I guess I don't have it too bad.
The Following User Says Thank You to FirebirdHank For This Useful Post: | ||
#96
Looks great!
#97
looks really good, amazing how flooring can really change a room
#98
So this weekend I pulled the trigger on the granite countertops.
I got a 10% discount if they installed it, I got a 320$ granite sink free, and 6 months same as cash, feels pretty good man Here is what we chose on top of the current floor tile
#99
are you going to undermount that sink
#100
David, I did the same for the front of my house 2 years ago. Had the same wood rails as you which were all rotted out. Those stone wall pavers make a big difference on how everything else around looks too. Looks great.
