Old 06-28-2021, 01:06 AM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
So I've had plans to install the stronger 8.5" 3.23 Posi in the GT ever since I pulled it from my 67 Wagon last year. But sometimes other projects keep jumping in front, don't they? Well, with the U-joint 'clank' getting louder by the mile (boy were they in bad shape when I pulled the shaft out!), I decided it was finally time to get the rear end swap done.
Also, knowing the Posi unit was working well in the wagon for years, I decided only a mild clean up of the housing, quick repaint of the cover and new fluid was all that was needed. The swap went pretty fast after that.
In my spare stash, I had another driveshaft that needed a home, and not wanting to cut up the original 72 shaft (in case I put the original rear back in at some point), I dropped the spare shaft at my local driveshaft shop with new measurements [Thanks OPH for the correct dimensions] Two u-joints, a new yoke, a little shortening and rebalance, and two days later, the shaft was ready to bolt in.
And yes, of course I had to operationally check my work afterwards.
Keep rollin', rollin', rollin'...
ID:	568926   Click image for larger version
ID:	568927   Click image for larger version
ID:	568928   Click image for larger version
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
  #82
Old 08-06-2021, 06:26 PM
hpp's Avatar
hpp hpp is offline
Great thread thought I’d share my 72’ Lemans Sport GT 400/400
ID:	570888   Click image for larger version
