Old 11-30-2013, 06:32 PM
arbys's Avatar
arbys arbys is offline
Red drums only in '66. That said, I used Rustoleum Red on my '67 back in '11, and the drums still look great.
Are you allowed to do that ? LOL
The Following User Says Thank You to arbys For This Useful Post:
  #82
Old 12-01-2013, 04:09 PM
Norwood's Avatar
Norwood Norwood is offline
Paul, CONGRATULATIONS my friend. Looks better than described. A few probs but you will get it straightened out. I am close if you need something.
  #83
Old 12-02-2013, 05:23 PM
Thanks Craig. I may take you up on that over the winter.
  #84
Old 12-02-2013, 05:26 PM
Default Shift plate
How is it SUPPOSED to be attached the console bezel? Right now its glued on.
And how do I get the shift knob off? I felt like I wanted to turn it but didint want to break it. I may have a better console. This one sucks.
  #85
Old 12-02-2013, 05:32 PM
GT182's Avatar
GT182 GT182 is offline
Not sure Paul but I'd guess the bezel would be attached with screws from the underside. That's how the 4 speed bezel attaches to the console. Sorry but I can't help ya with the shift knob.
I do know Charles [OG 67] can tell ya.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #86
Old 12-02-2013, 06:41 PM
Satyr1966's Avatar
Satyr1966 Satyr1966 is offline
Paul, the little silver part of the knob unscrews first & then the big black part unscrews next. The whole console will come off once the knob & screws are off.
By diligent effort I seem to be prolonging my adolescence to total absurdity. John D. MacDonald
  #87
Old 12-02-2013, 06:45 PM
Thank you. And what about the plate? Its glued on. How is it supposed to be attached?
  #88
Old 12-02-2013, 07:22 PM
Jeff Hamlin's Avatar
Shifter Plate;
There were tangs on the bottom and it would just pop/snap into place.
Over time they can break off as is in your case.
Shifter knob;
Removal procedure,
Page 7D-19 of YOUR factory service manual.
  #89
Old 12-02-2013, 07:44 PM
Originally Posted by Jeff Hamlin View Post
Shifter Plate;
Shifter knob;
Removal procedure,
Guess I need to get one of those huh?
Were the tangs part of the plate or the bezel? I don't have any of them.
  #90
Old 12-02-2013, 08:33 PM
barrierblue66's Avatar
barrierblue66 barrierblue66 is offline
They are small spring clips, sort of U-shaped and fit into the square shaped holes in the console. They have a hole in the end that attaches to the shifter plate pressed on to what looked like a rivit that was part of the cast. Had a problem with one of mine coming loose for years. Finally found a small enough screw, drilled a hole and used JB Weld in the threads. So far so good.
'63 Catalina Safari, Silverleaf Green / Cameo Ivory, nice options, 4 speed
'66 Grand Prix, Marina Turquoise, 421 HO, many options, 4 speed
My Garage
Tarheel Tigers Pontiac Club of Raleigh, NC
  #91
Old 12-02-2013, 08:50 PM
Andre's Avatar
Andre Andre is offline
Seems like plates that are pitted have nice spring clips, and nice ones have missing clips. I fixed the one in my '64 the way that Barrierblue outlines.
  #92
Old 12-02-2013, 08:58 PM
You can see the clip here, and what it looks like when it's missing!
http://www.ebay.com/itm/1969-Pontiac...c46536&vxp=mtr
My Garage
  #93
Old 12-02-2013, 09:33 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is online now
I can't see the speedo but correct me if I'm wrong but those gauges aren't from a '66, looks like a '64 tach in the right hand pod.
Just saw your other thread. Been off the board a bit lately.
  #94
Old 12-02-2013, 10:20 PM
You are right about the tach. I took it out this morning. The rest are from 66 as they are the same ones that were in my LEmans. I'd like to replace the tach with just a clock for now.
  #95
Old 12-02-2013, 10:21 PM
Exactly what I needed. Thank you. Now I know what they are supposed to look like
  #96
Old 12-02-2013, 11:52 PM
This says fits full size but it sure looks the same. Someone can chime in on the possibility of a cross-fit.
http://www.ebay.com/itm/NOS-PONTIAC-...6228cb&vxp=mtr
My Garage
  #97
Old 12-03-2013, 12:45 AM
Mine is painted black. Is it supposed to be that way? All the ones that Ive seen available are not painted.
  #98
Old 12-03-2013, 02:43 AM
Nicks67GTO Nicks67GTO is offline
Since that 389 isnt running well, has a 2 barrel and looks pretty scraggly, I think I would look for a good running pull out 400,428 or 455. They are around if you keep a close eye on craigs list. I picked up a rebuilt 455 from carb to pan and fan to flexplate for $800 In St Louis a couple of years ago. Then clean it up, stick some new gaskets in it, paint it, stick it in and sell the 389. It could probably be done pretty cheap if you got a couple hundred out of your running 389. Just take some video of the 389 running with a temp and oil pressure gauge readings before you pull it. Just a thought.
Nice GTO BTW
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies
- Build Thread
http://forums.maxperformanceinc.com/...615847&page=23
  #99
Old 12-03-2013, 08:57 AM
Yes, should be black, not gloss, a satin type finish, just as the console is done.
My Garage
  #100
Old 12-03-2013, 09:38 AM
Nice GTO BTW
It's a 4bbl.
