Old 03-01-2017, 03:22 PM
abefromen's Avatar
abefromen abefromen is offline
My 1972 Olds 8.5 was original to the car, and when I tore into it, it had the sealed bearings in it. The original bearings and seals as a matter of fact, it had never been apart, except for brake service.
I thought 71-72 was the change over years for tapered bearings, and there was a service bulletin for 70s and before to use tapered bearings as a replacement? I could be wrong there.
I think it's possible too that a casting date of April made its way on to a 71 car, since 71s probably started shipping in Aug/Sept.
I deleted my post because I thought I was wrong and seeing things in his axle shaft pic.
I did an archive search for 9799100 and saw a 1969 8.2 that DID have tapered bearings on the shaft.
Weird. Maybe OPH can straighten me out.
Sorry for the thread hijack.......
  #82
Old 03-01-2017, 06:09 PM
Kurt L71S's Avatar
Kurt L71S Kurt L71S is offline
The 1970 radiator core support fit pretty well in the 71. Bolted right up! Will have to drill out the spot welds on the orginal core and remove the top. It will then weld onto the 70 Core...
Hopefully, it'll work like a charm!...
Dressed up the alternator with some chrome parts....
ID:	448528   Click image for larger version
ID:	448529   Click image for larger version
ID:	448530   Click image for larger version
ID:	448532   Click image for larger version
Kurt L71S....1971 LeMans Sport Coupe 350/TH350
  #83
Old 03-01-2017, 06:13 PM
Kurt L71S's Avatar
QA1 Motorsports coil over system is Oh-so-nice! Don Cross (Crossdog389) is to come over tomorrow and install the driver's side! Talk about a calk walk!! After installing both sides and getting the steering linkage on, I'll need to torque everything to spec..
With the wheels and tires on the car, we can then adjust the ride height of the front end by dialing in the springs and the ride will be controlled by the adjuster on the shock...
ID:	448534   Click image for larger version
ID:	448535   Click image for larger version
  #84
Old 03-03-2017, 11:18 AM
Kurt L71S's Avatar
Had a GREAT day yesterday! While in the shop Don Cross, Stan Holderly, Clint Minglin, Kris Smith and Clark Gick stopped by to check out things at 306 Earl Street! Talk about old times!! When we would do this sort of thing back in the 60-70s, everyone would show up! Thanks guys!...
Brought to you by....QA1 Motorsports and the talents of Don Cross installing the passenger side setup!
ID:	448655   Click image for larger version
ID:	448656   Click image for larger version
ID:	448657   Click image for larger version
ID:	448658   Click image for larger version
  #85
Old 03-04-2017, 06:46 PM
Crossdog389 Crossdog389 is offline
Smile 71 Lemans Sport
Yes was a great day getting the QA1 springs finished up and talking Pontiac
with friends
  #86
Old 03-04-2017, 10:45 PM
Kurt L71S's Avatar
I would say, "Great team effort" so far on our 1971 Pontiac LeMans Sport. QA1 Motorsports, Summit Racing and Pirate Jacks Hot Rod...
Want some red calipers? Pirate Jack Hot Rod Restoration has what you need and will stand behind their product all the way! Thanks Guys...
Pirate Jack Hot Rod Restoration and their 4 wheel disc brake conversion. They also have Slotted and Drilled Directional rotors that look Sweet!...
Name:	71 LeMans QA1 Suspension 005 combo.jpg
ID:	448781   Click image for larger version
Name:	71 LeMans QA1 Suspension 007.jpg
ID:	448782   Click image for larger version
Name:	71 LeMans QA1 Suspension 002.jpg
ID:	448783   Click image for larger version
Name:	71 LeMans QA1 Suspension 001.jpg
  #87
Old 03-05-2017, 11:10 AM
2002Z4CSS's Avatar
Nice looking Lemans. One day my GT-37 will look that nice.
1971 Pontiac GT-37
  #88
Old 03-06-2017, 11:53 AM
Kurt L71S's Avatar
Z4,
Thanks for looking at our thread! I have learned so much since starting this LeMans build....one thing that sticks in my mind is the importance of the GT-37. I found one the other day....might have to think about this one too....it's a 400 4 speed...with the hood pins installed....
That one of yours is "out of bounds cool"....keep us updated!
  #89
Old 03-07-2017, 10:47 AM
Kurt L71S's Avatar
She is taking shape! There is QA1 and Pirate Jack peeking out from under her. Loving the look of the factory colors...
Just had to do this....I kind of like the look of the Rallys....Corvette 15x8... I like this look as well...I know, run the Rallys on one side and the Torque Thrust on the other side....
Name:	71 LeMans Front End install QA1 006.jpg
ID:	448994   Click image for larger version
Name:	71 LeMans Front End install QA1 007.jpg
ID:	448995   Click image for larger version
Name:	71 LeMans Front End install QA1 010.jpg
ID:	448996   Click image for larger version
ID:	448997   Click image for larger version
  #90
Old 03-07-2017, 02:21 PM
gtospieg gtospieg is offline
Your car is really coming along...but I can't recommend Chevy wheels on a Pontiac...it may have an identity crisis...lol
  #91
Old 03-09-2017, 01:40 PM
Kurt L71S's Avatar
Free Shipping you say? But I don't have $99 worth.....Got THAT taken care of...
Need a new Tach with a white face to compliment the white interior...
"Where there is a will, there is a way".....NEVER underestimate a "Car Guy" with needs....
Name:	71 LeMans Tach & A Arm Bumpers 004.jpg
  #92
Old 03-22-2017, 09:35 AM
Kurt L71S's Avatar
Need to be very careful and mark each bow and it's location and color...
Interior is now stripped to the bone!..
Found what is left of the build sheet....this car it was under the driver's side floor shield. Can only make out a couple of items...
ID:	450400   Click image for larger version
ID:	450401   Click image for larger version
ID:	450402   Click image for larger version
ID:	450403   Click image for larger version
  #93
Old 03-23-2017, 07:47 PM
Kurt L71S's Avatar
Happened to get all the interior out including the headliner along with all the tack strips...they are now cleaned and reinstalled..All the bows still had all their colors left....
ID:	450519   Click image for larger version
ID:	450520   Click image for larger version
  #94
Old 03-23-2017, 07:55 PM
Kurt L71S's Avatar
Spent this afternoon at Chucks Engines checking on the Poncho 350..
She is looking great and for just wanting a tune up, it will now turn some heads for sure....
New slugs and the cam look impressive....280 duration/418 lift....
Should give her some thumpin' power....
Name:	71 Lemans_Chucks Engines 001.jpg
ID:	450522   Click image for larger version
Name:	71 Lemans_Chucks Engines 012.jpg
ID:	450523   Click image for larger version
Name:	71 Lemans_Chucks Engines 018.jpg
ID:	450524   Click image for larger version
Name:	71 Lemans_Chucks Engines 016.jpg
ID:	450525   Click image for larger version
Name:	71 Lemans_Chucks Engines 032.jpg
  #95
Old 03-29-2017, 05:01 PM
West Coast GTO's Avatar
West Coast GTO West Coast GTO is offline
Remarkable work on your car 71!
Did you purchase a 70 core support form our host to make that work for your 71?
My 71 is rusty below the battery tray at bolt area and may need to do that to my car.
Thanks.
  #96
Old 03-30-2017, 01:37 PM
Kurt L71S's Avatar
Thanks.
West Coast,
Thanks for looking and your comments!
Yes I did buy a new core, but not from our host. This one fit right in and I will be adding the top from my old one.
I urge you to not throw away your old one. I am planning on repairing mine and put it up for sale. There are folks that want and only want original.....
  #97
Old 03-30-2017, 08:38 PM
2002Z4CSS's Avatar
I wished I had your time and energy!
1971 Pontiac GT-37
  #98
Old 04-14-2017, 07:11 AM
Kurt L71S's Avatar
2002,
I finally made it back to the shop yesterday.....just did not have the drive to get anything done!....
Removed the driver's side door in order to replace the hinge pins and bushings. Clark Gick came over to make some repairs on the interior. Getting close to getting the engine/trans home... STOKED AGAIN!!...
ID:	452061   Click image for larger version
ID:	452062   Click image for larger version
ID:	452063   Click image for larger version
ID:	452064   Click image for larger version
  #99
Old 04-14-2017, 11:57 AM
Kurt,
Are you going to use a spot weld drill bit to remove the top from the 70 support or another method?
West Coast,
  #100
Old 04-14-2017, 06:14 PM
Kurt L71S's Avatar
Kurt,
West Coast,
Yes that is the plan. I now have the old one removed and we will spot weld it on the new core....should work like a charm....
