#81
Hi George! Most people have an opinion but not everyone. Some opinions are based off of working in the industry for more than thirty years, porting and setting up over a thousand cylinder heads. Some opinions are based off of having a personal "man crush" on a certain Pontiac vendor.
#82
The shop you buy the heads from should be happy to supply you with the part number you're seeking. What's wrong with the valves the Edelbrock heads come with? Which valves are better? Why are they better?
#83
I think he wants them bare because he's gonna do his on valve job and put the springs from comp that match whichever came I choose etc. I am paying with them with a summit credit card so I won't be getting them from a mom and pop
#84
......some opinions are based on over 40 of racing experience and buying race car parts! GTO George Last edited by GTOGEORGE; 07-18-2017 at 10:49 PM. |
#85
Quality of some of the Pontiac specific vendors is getting bad that's all I'm going to say I have 33 yrs racing and building Pontiac s I have seen a lot some good some bad
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
#86
Whichever head u choose get somebody good to build them
#87
GTO George |
#88
This is a good start. |
#89
http://www.edelbrock.com/automotive/...erformer.shtml
http://www.edelbrock.com/automotive/...heads/pontiac/ .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 07-19-2017 at 09:20 AM. |
#90
Nothing wrong with Summit. They should be happy to provide you with the part number you're seeking.
#91
I just returned from Kauffman, I have an entire long block with their 310 KRE D ports, customer service is TOP NOTCH.. I could not get a hold of Dave at SD, apparently TOO busy to return a PM or email....I guess he doesn't need my business.
Kauffman is the way to go!!!!!!!!!!!!!!!!
https://www.facebook.com/KauffmanRac...6873234225938/ KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9". 552HP 594 TQ |
#92
If you use Summit,ask for Scott Esterly,he is a pontiac racer.Tom
#93
OK, here's my situation: 1965 GTO with a 389 I built in 1981. It now has 50,000 miles on it and runs like a champ----on race gas. Good compression, not leaking oil (unbelievable, I know), dependable, but with the compression at 11:1 (milled 77 heads and flat top pistons..64cc) it doesn't like today's gas. Running an old Sig Erson Hi Flow 1 cam with a tight 106 or 108 center , single pattern cam, 4 speed, trips, hedman headers and a 3.36 gear. Car is a solid #3 car I've had forever. But hardly drive due to its exotic fuel requirements. If I were to install aluminum heads to alleviate the detonation problem, which ones would I want? I use the car for road trips out of town, and street driving. No racing. What would be the turn-key, go-to, easy head to buy and install for a moderate street 389-400? What aluminum head would allow me to once again run pump gas?
Jeff |
#94
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
#95
KRE is getting 545 out of as cast d-ports. This particular combo had fast EFI.
#98
.030 over 455 As cast KRE D's 85 CC chamber (roughly 10.25:1) Jeff K spec'd comp roller 232/238 on 112 with XFI lobes / Lunati roller lifters I received them setup from Kauffman, bolted them on and have been driving ever since. Like you, I used to have an 11:1 iron headed engine and had to run 100 octane through it at significant cost and limited supply.
#99
personally if i won the lottery,, i would go with KRE, they are real pontiac guys, not just another big speed parts company.. but the biggest reason is KRE is NOT located in the Demokratic state of Kalifornia !!!
CAROLYN JONES(1930-1983 Actress)may she never be forgotten!! |
#100
I'd go Edelbrock round port simply because header installation is so much easier, they're available with modern chambers now.
Let's keep Ca political comments out of this please.
