Old 03-15-2018, 11:37 PM
Dave M's Avatar
Dave M Dave M is offline
Originally Posted by PunchT37 View Post
Chambers are advertised at 72. Gotta figure ****ty head gaskets unless he goes Cometic.
Which I would. Need as good a quench and compression as possible, especially on the 350.
I have a set of 670’s that we cc’d. Mine are exactly 72cc.
  #82
Old 03-16-2018, 01:06 AM
Originally Posted by Lee View Post
No, IH used 348 and 392 inch V-8's, gasoline, in buses and dump trucks. Shaft rocker arms, forged cranks and rods. They used the EXACT same engines in Travelalls, Travelers and Scouts. The cams all had smaller exhaust duration than intake duration, and power curves were DONE by 4,000rpm, but they could pull massive loads off-idle with a manual transmission. HP ratings were crap, but they could pull - pull nearly anything.
Sorry, but I’ve machined way too many 549s that came out of buses and dump trucks. Incidentally, the gas 549 was the basis for the 9.0 liter IH Diesel engine found in buses and dump trucks until the advent of the DT series engines( far superior). 348? Try 345...
Dr. Thomas Sowell
  #83
Old 03-16-2018, 08:07 AM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
72 Luxury, thanks for the simulations. How's Eunice? I'm from Opelousas. I moved out of there 28 years ago.
Steve Prudhomme
67 Firebird 3440 lbs, Pump gas 537 IA2, tiger heads, 4.86 rear, 32 x 17.5's, full interior, 4 mufflers, street shape 1.36 60', [email protected] 1/8 mi. 5.67@123 on small shot.
  #84
Old 03-16-2018, 10:03 AM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
Then I guessed correctly. I went back and calculated using 72cc chambers, 8cc valve reliefs on flat tops, cometic head gasket .030" thick with a 4" bore and zero decked. I raised the compression from 9.50psi to 9.54psi.
Karl
  #85
Old 03-16-2018, 10:09 AM
Steve Prudhomme
Eunice doesn't change much I'd imagine. I've only been here ten years but I like living here. I'm from Lafayette originally. I lived in Opelousas from '94-'96 while going to T.H. Harris for Electronics and would never go back......It's in worse shape than it's ever been.
How often do people ask you if you are related to Paul?
Karl
  #86
Old 03-16-2018, 04:53 PM
p4msi1's Avatar
I've only been to Eunice a couple times but been to Lawtell plenty.
I miss the food for sure and yes I am related to Chef Paul Prudhomme, he was my uncle.
  #87
Old 03-16-2018, 05:21 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
So, I guess you`re not freaked out over the 455 sauce posted in the lobby?
  #88
Old 03-16-2018, 09:21 PM
p4msi1's Avatar
Don't come here that much anymore and did not know about this 455 Sauce till now. I wish Barbacuban all the luck in the world. The only thing that freaks me out is not being able to eat cajun food when I want.
Steve
  #89
Old 03-22-2018, 02:12 PM
Steve,
Have you decided on the cam yet?
Karl
