Old 11-25-2018, 01:54 PM
stevep's Avatar
stevep stevep is offline
Originally Posted by shaker455 View Post
you have one half of a grill?
I have 1 side NOS. I may have other used ones.
  #82
Old 11-25-2018, 03:57 PM
shaker455's Avatar
shaker455 shaker455 is online now
Used will be fine for this car especially as I am refinishing..thanks Steve
Carburetor building & modification services
Servicing the Pontiac community over 20 years
  #83
Old 11-26-2018, 10:33 AM
77 TRASHCAN's Avatar
I have the same background as you.
I can tell you about the time way back in the last century a Pontiac short block was given to me from under a porch that was locked up and rusted solid...freed up because I discovered and invented sandpaper!...lol
Into a 74' Grand Prix winter bomb!
I also did this brew to my 57' Studebaker Golden Hawk but it did not work.
I will put a long handle breaker bar to it but if it does not respond out it comes to be broken down when I have time to do my own stuff.
If it will not move most likely the rings are fused to the cylinder walls and will need to be replaced...
I have plenty of Pontiac parts
Oh, I have found that in the cyl's that are free, the "brew" will run through past the rings.
Shut it off
Shut it off
  #84
Old 11-26-2018, 10:36 AM
shaker455's Avatar
I'll check this week
  #85
Old 11-28-2018, 06:15 PM
shaker455's Avatar
I tired tonight...no dice!
I've had enough I'm pulling it out!
  #86
Old 11-29-2018, 10:46 PM
stevep's Avatar
Sorry, but I'm not really surprised based on what I saw.
  #87
Old 11-30-2018, 09:56 AM
shaker455's Avatar
No biggie, once I have the time I will pull it out and go thru it to make it operable.
Or put another running engine in for now.
  #88
Old 11-30-2018, 10:53 AM
Can't wait to see the 'innards of a classic 389, that's made it this far from 1967!!!
Shut it off
Shut it off
  #89
Old 11-30-2018, 11:48 AM
shaker455's Avatar
400 with 670 heads
  #90
Old 11-30-2018, 01:04 PM
shaker455's Avatar
Car has completely original driveline and appears to have never been apart.
Block is a "XH" 67' 400 and that was a 350 Hp engine.
  #91
Old 11-30-2018, 01:24 PM
400 with 670 heads
LOL, another duh for me...
Shut it off
Shut it off
  #92
Old 11-30-2018, 01:46 PM
shaker455's Avatar
No...lol..actually I'm taking your advice and I called in some big guns!
Going to try a 4 ft 3/4 drive breaker bar.
  #93
Old 11-30-2018, 03:37 PM
I have a couple of those. I buy them at the import tool store, about $35.00 would be probably $500.00 from Strap On.
Shut it off
Shut it off
  #94
Old 11-30-2018, 04:32 PM
shaker455's Avatar
After the motor being locked up I had to see what I really have for a car body.
I took out the seats , I knew the carpet was wet on drivers pan.
I'm pretty happy!
ID:	499074   Click image for larger version
ID:	499075   Click image for larger version
ID:	499076   Click image for larger version
  #95
Old 11-30-2018, 04:34 PM
shaker455's Avatar
More pics
Anyone have a decent Gold steering wheel?
ID:	499078   Click image for larger version
  #96
Old 11-30-2018, 07:01 PM
shaker455's Avatar
She Lives!
My buddy stopped over with his 4 foot bar and with a little drama and it turned over...spins smoothly & free now.
I'm going to treat the cylinders with PB Blaster and continue to spin.
Change the oil after I'm done treating cylinders and Fire it off Sunday!
I dried the front drivers floor then a quick wire wheel and what primer I had ( not much) to front floors.
ID:	499093   Click image for larger version
ID:	499094   Click image for larger version
  #97
Old 11-30-2018, 08:13 PM
Holy Sheepdip, I hope that rare upper radiator hose didn't succumb to the breakover!!!
Shut it off
Shut it off
  #98
Old 12-02-2018, 03:40 PM
shaker455's Avatar
I did try to fire her up.
Starter turned over too slow with plugs in to catch.
Next opportunity I'll clean all connections & grounds see if that helps.
If not I got 3 old starters and last ditch buy a mini.
Apparently Chevron stopped making Delo 400 LE 15-40 which had zinc and a CJ-4 rating
I got they're new stuff 400 SDE which has CK-4 rating and no idea on zinc.
Plus I got Shell Rotella T4 15-40 as a back up.
But I always add some lucas zinc break in oil cause you never know the real PPM in off the shelf stuff.
  #99
Old 12-02-2018, 04:29 PM
stevep's Avatar
The starter must have a ton of resistance built up. I would 24 volt it!
  #100
Old 12-02-2018, 04:35 PM
Preaching to the Choir......again
When you get old starter off, attach jumper cables to it, see how it spins off car...not a complete picture of starter condition, but may help in parts decision...
Shut it off
Shut it off
