Old 01-09-2019, 08:01 PM
slowbird's Avatar
slowbird slowbird is offline
Picked up my Scat crank today,nice piece.I just did a quick check on the dims,checked the snout,one main and one J and called a machinist and they are good.One thing I found out is they will do a custom forged cranks,a lot more than off the shelf but they bring in raw forgings.I also found out they do custom billet cranks.Their metal comes from either Canada or UK.Did not ask price but they did say its about 14 week lead time.FWIW,Tom
I had a Scat billet crank, it wasn't bad, didn't have center counter weights though.
  #82
Old 01-09-2019, 08:48 PM
tom s tom s is offline
I guess if you want it you HAVE to put it on the order?Tom
  #83
Old 01-09-2019, 09:35 PM
Mike Kasparian,Sr.'s Avatar
Mike Kasparian,Sr. Mike Kasparian,Sr. is offline
When I ordered my Bryant crank about 10 years ago I remember discussing center counter weights but they felt it wasn't necessary . It was only the second pontiac crank that they made , Jon Kasse got the first . Wish I could change that but it is what it is .
505 CID, 3560 lbs,Tiger heads, NA.
[email protected] mph, 1.29 60', stock suspension
  #84
Old 01-09-2019, 10:05 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Originally Posted by Jack Ferris View Post
Great information Jeff.
I have a new SG 4.500 crank that came from AP but I’ve not heard a lot of feedback on them so I’m hesitant to use it. I do have a 4.250 SCAT crank so your post has been a plus.
We have used a lot of SGI cranks and never had a problem with one. Occasionally we will find the journals a tad on the large side and have to use X bearings or a combination of standard and X to get clearances right but they are good cranks. I feel they are every bit as good as SCAT.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
  #85
Old 01-21-2019, 02:17 PM
Tom McQueen Tom McQueen is offline
This is a Bryant billet I had made for the twin turbo.
4.125" stroke.
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
  #86
Old 01-22-2019, 12:39 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Originally Posted by Jeff Kinsler View Post
Yes sir.
thank you guys
  #87
Old 01-22-2019, 04:04 PM
GTOGEORGE's Avatar
A nice $3,250 crankshaft from Moldex!
GTO George
  #88
Old 01-27-2019, 03:19 AM
blueghoast's Avatar
Some nice eye candy in here tonight guy's.
GT.
