Old 02-26-2021, 10:55 PM
Doug Doug is offline
May be wrong place to ask but since it's about cc's: How did the 421 SD engines bump up the compression when they went from405 to 410HP rating?
  #82
Old 02-26-2021, 11:27 PM
tom s tom s is offline
12 to 1 CR.Small dome.Tom
  #83
Old 03-03-2021, 07:46 AM
SD455DJ SD455DJ is offline
Thanks much for the added CC info on the 12s and 16s!
We Whistler'd the RAIII in the '70 Formula 400 whose engine is still 100% factory original with 47,000 miles, and never been apart, except for a new timing chain/gears/cover and fuel pump. It measured 10.0 SCR cold (60 degrees) and 10.5 SCR warm (150 degrees). A compression test yielded 175 psi average (170-180). It has the original 068 cam & lifters, jamb nuts on the rockers, etc. down to the factory jetting and beefy advance springs in the distributor.
These readings sure give credence to the #12 heads 68 cc chamber sizes from the factory and we have no good reason to not believe them on the RA engines.
Dennis
Name:	RAIII SCR Cold.jpg
ID:	561943   Click image for larger version
Name:	RAIII SCR Warm.jpg
ID:	561944   Click image for larger version
Name:	Nylon Timing Gear 1.jpg
ID:	561945   Click image for larger version
Name:	YZ 400 Ready.jpg
