#81
Not sure what you mean? I’ve been working on this car 10 years. I haven’t abandoned anything
#82
You can buy a bracket kit for your Sanden compressor from Vintage Air for like $125 that will work with factory brackets & accessories. This is the set-up I run in one of my cars and no issues with squeals even with a 150amp alternator. It was a new build (535ci) and used a complete bracket and pulley set-up from a 71 400 that I bought from a member here. I had to experiment a little with belts, but easy to sort out and worth the effort. I had considered a serpentine set-up so I could run a type 2 PS pump, which I thought would work better with rack and pinion steering in the car, but the saginaw type 1 pump seems to work fine.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
| The Following User Says Thank You to Gator67 For This Useful Post: | ||
#83
Uhm, 3/8 V-belts and Pulleys that match are a blessing. Otherwise you got to look at what ya gots for Pulley V-groove, and the stinkin Belt girth to fit without bottoming-out in them pulley grooves.
Serpentine belts require careful observation for same bottom-out deal. Ha, the pulleys wear our so new serpentine belts will squeal. Ha, not playing that game. |
