#81
The chosen cam, specs, springs, lifters and install methods (the rooster).
#82
The attached photo shows a parts quality issue. This is what causes lobe failures. This lifter failed because it was soft, the reason the lifter was destroyed is because it was used on a quality cam core. You can lube everything until the parts will slip through Hell and you"re still going to have an issue if the parts aren't right.... No "break in" procedure, no EDM oiling hole, and no amount of zinc or quality oil is going to prevent this.
After many years of blaming the oil and the break in procedure, the truth is finally out. It's been piss poor quality parts. In addition to a non-existent quality lifter choices, we now have to be concerned about the quality of the cam cores. The "good" guys aren't supplying the cam cores anymore. Last edited by PAUL K; 09-08-2022 at 09:36 AM. |
The Following 3 Users Say Thank You to PAUL K For This Useful Post: | ||
#83
I have a machinist/engine builder friend that has been complaint about soft cam and lifters this last year. He was so frustrated he has started look for old NOS parts before he ordered new. Rockwell down below 40s on lifters, and well below that on some cams. Last edited by Jay S; 09-08-2022 at 08:58 AM. |
#84
With those 2 things done I only see the life of the cam and lifters extended and it's a little piece of mind for the always tense break in session. I figure if you take all those precautions and you still have a flat cam issue, then you have to be doing something else drastically wrong. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
#85
Very well could be. That's sometimes the issue you run into when you source a cam from someone else, complete heads from another person, and then yet another shop that does the machine work and assembly. No telling who or if the spring pressures were checked, and highly unlikely the machinist contacted Paul to ask what kind of spring pressure he uses with that particular cam and lobe profile. Butler is primarily a Comp dealer, so he is obviously more familiar with what he likes to use for springs on his cam grinds. What that is would be anyone's guess unless those springs are removed and checked. But the chances are better than average it's probably not what Paul C has found to be needed with his custom cam grind. Then you couple that with the OP over revving the engine to 7000 rpm and valvetrain control becomes a serious problem. Parts start crashing together and eventually something gives. |
#86
I've had one lifter/lobe failure, only. The number 7 exhaust lobe started going down at about 60,000 on my original TA 400 engine. It's still on a stand, as it came out of my Mar, in 1992. Replaced the 400 with a 1970 350.
#87
I had a conversation in regards to lifter failure with (arguably) the number one person on the planet when it comes to flat tappet lifters. We were discussing a box of failed lifters I sent back for inspection. When discussing different manufacturers, he said one of his competitors makes a decent lifter but they will have a hard time surviving thirty thousand miles. Considering I couldn't get his lifters to make it off the test stand we immediately switched to his "competitors" lifters and never had an issue. I hope you are feeling better! |
The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
#88
So are the Hylift-Johnson lifters sold by Butler the be all end all or is there something else I should be looking at?
#89
Paul, thanks!
Doing and feeling much better. Tomorrow will be my last day in the hospital!!! I wonder how many folks that have experienced failed lifters, have had a n O. E. lifter on a stock cam go bad??? Looking forward to working on some of the parts I've bought from you, and others, in the near future (might be around Thanksgiving when that happens, BUT I will be thankful when that day comes!!!
The Following User Says Thank You to 77 TRASHCAN For This Useful Post: | ||
#90
The Rhoads lifters are American made, not a re-boxed anything from anywhere. I've been running the V-Max lifters for years and I love them.
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
The Following User Says Thank You to Johnny406 For This Useful Post: | ||
#91
If there's something better, I'm listening!! Everyone keep in mind, there IS another company named Johnson lifters, NOT related to Hylift Johnson.
#92
I remember Chevrolet had a cam/lobe issue in the late 70's. I never noticed any issues on the late seventies Pontiac engines I took apart back in the day. A lot of sludge issues though. I'm curious if any of your exhaust valves had a noticeable crack starting at the edge and going straight towards the stem? I borrowed a friend's 77 TA to take my drivers test. When we pulled the heads off that car it had atleast two valves that were cracked that way. |
#93
Have a 65 327/300 hp here that is completely original and unopened that has lost a few lobes on the camshaft. Mileage unknown but was running and driving for a while in one of the cars here when it started popping through the carb one day. That happened around 1980 or so long before all the oil quality discussions, long before we even had computers or the internet, lol.
It could have simply been a lot of miles and maybe it had served it's usefulness. They were never designed to last forever. |
#94
I've read that claim numerous times on this forum. |
#95
When I tore town my original YS 400 with about 110,000 miles it had one lifter dished to the point that it had a pin hole in the face, cam lobe had a matching profile It actually still ran decent and didn't make any lifter noise.
I'm World's Best Hyperbolist !! |
#96
Or does it look anything like the attached picture? |
#97
My opinion: Rhoads used highest quality Lifter cores.
My other opinion: i have seen the soft-metal lifter wear down like the prior post showed. Oh one more: Seen OE OHC-6 cam lobe wipe out seen a few times. 68 350 lobe wipe &-lifter dish out. |
#98
I also do all my break ins with the springs I install on engines I build. In fact, I just delivered 3 in August all equipped with HFT cams and no failures. |
The Following User Says Thank You to racegto65 For This Useful Post: | ||
#99
There is also papers written that too much zinc in oil is as damaging as not enough. Just know there is such a thing as, too much of a good thing. There is a PPM general spec that should be adhered to.
I tend to believe what Paul K says, that there a lot of inferior parts in the pipeline, that don't have the correct alloys, or hardness specifications. No oils, or additives will help inferior parts live. |
The Following 3 Users Say Thank You to Sirrotica For This Useful Post: | ||
#100
Just to throw in another comment I have heard, that if you let the vehicle idle lots it's hard on camshaft and lifters due to
lack of lube getting tossed around? Just something I have heard.
64 Lemans hardtop 4spd, buckets |
The Following User Says Thank You to Lemans64 For This Useful Post: | ||
