I would open up the booster holes, and open up slot restrictor to .075 if it were mine and send it
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
So I drilled the 0.56 to .075 and then I drilled out the booster from 182 to 192.
My Half AN Injun..... |
The Terminology here needs to be clarified lol, so the above is your boosters, and u drilled the holes from 0.56 to .075? what did u drill out to .192? what is loose? The banjos that boosters press into?
The red arrow is transfer slot restrictors n blue is your booster pins
The booster was drilled from .182 to .192 which your saying is the banjo. My transfer slots are .098..
I found out that 2 of the booster are loose . Anyone know of a tool they make to tighten them up?
The booster/ banjo was loose. I never messed with a 4500 booster before . so im learning ive done many 4150's in the past so its different for sure ..
But i got the pin out and loc-tighted it back in . It seems ok but im going to get some new ones .
Blue arrow is the banjo , it’s what the booster presses into
yes i understand now . That was drilled to .192
Straight methanol is about double.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
Yes, wow u are using some big pins, mine are only drilled to about .183 on my 1200
Ive been looking for a set being mine aren't in good shape. Are you using E85 or gas? I don't remember you saying .
They get sketchy to drill after about .185 real thin, unless u go to that bigger pin and the drill out the banjo for it, Are you drilling it out after installed in body? They shrink back down a tad if u drill them beforehand and need to ream them back out some after installed i have found, .180 Is fine for you no need to go bigger on pin. I'm on E85 now
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's Last edited by grandville455; 10-26-2022 at 03:17 PM. |
What it was , was i converted over to E85, so i drilled them in place to see if that worked out first . When i saw one was loose i took it apart and found the pin was like you said very thin and fell apart at the end . So for now i just put it back together with some loc-tight . The pins before i drilled them were 160's. So now i will probably get the .170's and drill them . I was thinking a bout getting the big ones and try them .. Not sure yet on what i will do. If having the bigger ones in there wont hurt maybe ill just get them . At least ill have growing room for the future. For now i want to test the car and see if the changes i made make any difference. So far i got the car running and it sounds and idles real good. Today is a wet one so i have to wait. On a positive note, The holes i drilled in the metering blocks and main body for the pump-shot feed seem to have made things better on the bog i was having ...
Tested the car today and its still the same at WOT. At this point im not sure on what else to try. Anyone have any suggestions ? I just want to say that i really appreciate everyone's input so far ..
One good thing is that the bog is 90% gone now . So i have to work on that a bit more . But the lack of fuel problem at WOT really has me stumped .. I guess ill try a different carburetor because i feel like ive tried everything with this one ..
What AFR are you at @ WOT ? Whats your target that you shoot for ?
I’m using my fast afr meter which was for gas, n it’s hard to read cause it’s used but it looks like it’s around 12.0? I have the A1000 pump .
I know what you mean . I have mine mounted on the dash right in front of me and its still hard to read .
