Pontiacs have been running SBC roller lifters for 50 years or more.If someone had a in at Morel you might be able to get them to make a set of the tool steel lifters and just changing the link bars?Tom
The 4/7 swap moves the heat load of the 5/7 cylinder pairing from the rear of the block (hottest part) to the front of the block (coolest part--right next to the water pump). A proper 4/7 & 2/3 swap like the LS firing order, removes load from the overloaded #4 main bearing, and puts it on #2 which would otherwise be under-loaded. In fact, that was why the LS engine uses that firing order--to even-out main bearing loading. When it was me, on an Olds 455, I had Lunati take care of it. Way back then, I think it was an additional $110. It about doubled the cost of a flat-tappet cam. No doubt it's far more, now. Thanks, F. Joe Biden. |
| The Following User Says Thank You to Schurkey For This Useful Post: | ||
Morel could definetly do that, certainly not a cheap option. But they rebox their lifters for a lot of companies, would think it would not take much for a company to get that done. Morels billet bodies are easy to spot, they have open bodies around the wheels. They are rated for over 500 lbs springs pressure and 7K RPMs, they are the direct competitors for the Isky HPx made by Johnson.
Looks like I need to change the title of this thread to a lifter discussion or unsubscribe, You guys are blowing me up here LOL
The More People I Meet, The More I Love My Dogs! |
![]() Seasons Greetings to you and your family! |
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
Merry Christmas to you and yours as well.
| The Following User Says Thank You to ponchjoe For This Useful Post: | ||
You can always call or text me if you find yourself in a corner with a question. I enjoy power terrain stuff.. If I don’t know the answer I may at least know someone that does. |
I will definitely take you up on that Jay.
There are plenty of nay-sayers, as well as success and failure stories, for either option (roller or flat tappet).
For whatever my opinion is worth, I prefer a roller. Solid or hydraulic. For solid roller, Maintenance is simple, and probably not needed much. The biggest downside to a roller (imo) is the expense. But If your budget allows for it, that’s the route I would go. I ran a solid roller in a street car (400 stroker buuld), and it was great. I currently have a HFT (2802) in my street 400 (because we built it for dad, and he wanted to keep it “cheap”), and there’s an annoying ticking sound in the valve train on the passenger side (even-numbered cylinders) of the block. I fear it’s a lobe wearing, but haven’t dug into it yet so maybe not. Have tried adjusting it out but no luck. Runs fine so letting it ride for a while. When I have to replace it, I’ll go with a roller.
Matt 70 GTO 400 4-speed "Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge |
| The Following User Says Thank You to PontiacMatt72 For This Useful Post: | ||
