Old 08-23-2025, 03:27 PM
Formulas's Avatar
Formulas Formulas is offline
Looking at the lobes on the camshaft its a decent sized cam for a low compression 350 .... And your oil pressure? It probably has a 45LB pump in it so don't expect more than that
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
Old 08-25-2025, 04:07 PM
NateOld687 NateOld687 is offline
Thanks for the info! I am new to the car scene, I have been a motorcycle technician for almost ten years now so I appreciate any insights on the car stuff haha the engine is a 68' "WK" block with 68' #18 heads which if my memory serves me correct were not "low compression" and sat @ 10.5:1 I maybe mistaken though. I was running 15w-40 T4 but have since switched to 20w-50 VR1 and oil pressure sits around 40-45psi.
Old 08-25-2025, 04:15 PM
steve25 steve25 is offline
Nothing wrong with that, so your fine.
Old 08-25-2025, 04:26 PM
Formulas's Avatar
Yeah i didn't know you had a 1968 with #18 heads in it i figured it was same as car... So your in good shape there.
Old 10-17-2025, 10:04 AM
tempest1964's Avatar
Looks great! Congrats!
Old 10-17-2025, 03:33 PM
JLMounce JLMounce is offline
Congrats on getting the car to reliable fashion. I think the Rallye II's are gonna look great.
Black would be cool, but I think that color combination is pretty cool itself and cleaned up it looks pretty decent. Instead of the expense of a repaint, have you thought about having a detailer bring what's there back to life as far as it can be? It'll have some patina, but that's cool these days.
-Jason
1969 Pontiac Firebird
Old 10-17-2025, 08:31 PM
Yeah I like this idea, the current paint isn't too bad tbh and I do love the original patina look..
Old 05-11-2026, 03:07 PM
Looks like it's coming together! Reliable miles are the best miles!
-Jason
The Following User Says Thank You to JLMounce For This Useful Post:
Old 05-11-2026, 03:59 PM
Good to hear!
Old 05-12-2026, 07:30 AM
Half-Inch Stud's Avatar
Torker I worked well for me on 4.21" stroke, when the plenum-upper was opened to unshroud the carb bores and blend the runner ceilings, and port-match. Is a lot of grinding that other manifolds play as-good without the grind.
Ima favor the Dual-Plane manifold for Street-Strip now though because i sold all my intakes.
