Old 02-12-2026, 10:38 PM
charlie66's Avatar
Default Hydraulic roller cam with solid lifters
So, I'm being told that I can use solid lifters on my hydraulic roller cam. Is anyone doing this here that can say if it's true and what their results have been. I am hearing that all you do is lash it to .008-.010 depending on if the block is iron or aluminum and it will be fine. I've been told that solid lifters are stronger and last longer than hydraulic. Is this true? It's sounds like it could be something good to consider if it was durable over time.
Can anyone explain more on this?
My Half AN Injun.....
Old 02-12-2026, 11:37 PM
tom s tom s is online now
You will loose about 8 degrees of duration and some lift depending on what you set the lash at and rocker ratio.Better off just buying a tight lash solid roller cam and lifters .Also you will need to increase the spring pressure as it now a solid roller cam.Comp told me 200 on the seats.Its has been done with many for many years.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
Old 02-13-2026, 12:28 AM
Jay S's Avatar
Jay S Jay S is offline
I frequently run solid lifters on bigger HR cams. But I zero lash the solid lifters cold and let the hot expansion be the lash. There is light friction on the pushrods, i don’t use a feeler guage when I do it. The cam does not loose much duration doing it that way over HR lifters. Engine master did a test like that a few years ago and gained 8HP thru the entire power band over a side by side test with a HR lifters. I have ran lash, but it is easier to do and overall works best with no lash set cold. We use the same valve springs as the cam would with a HR lifter. I do add some extra seat pressure though depending on the set up. The engines I have done are 6500 to 7000 RPM street and strip engines and .640 ish lift 240 to 260 @.050”. There are not many mechanical roller profiles that I know of that can do the same thing without another 100 lbs of spring. Which is my reasoning when doing it.. When it needs SR springs I run a SR profile. I have never been back into reset the lash, they run pretty quite. Some are quite enough you can tell they have roller cams.
More lash equals less duration at the vale, same as any mechanical cam.
The Following 2 Users Say Thank You to Jay S For This Useful Post:
Old 02-13-2026, 12:57 AM
charlie66's Avatar
Originally Posted by Jay S View Post
I frequently run solid lifters on bigger HR cams. But I zero lash the solid lifters cold and let the hot expansion be the lash. There is light friction on the pushrods, i don’t use a feeler guage when I do it. The cam does not loose much duration doing it that way over HR lifters. Engine master did a test like that a few years ago and gained 8HP thru the entire power band over a side by side test with a HR lifters. I have ran lash, but it is easier to do and overall works best with no lash. We use the same valve springs as the cam would with a HR lifter. I do add some extra seat pressure though depending on the set up. The engines I have done are 6500 to 7000 RPM street and strip engines and .640 ish lift 240 to 260 @.050”. There are not many mechanical roller profiles that I know of that can do the same thing without another 100 lbs of spring. Which is my reasoning when doing it.. When it needs SR springs I run a SR profiles. I have never been back into one of the the readjust the lash, it doesn’t seem to move.
Do you think I could do it with the cam I just bought from Butler? The springs I have right now have 140lbs on the seat I think 325 open at .550. with 1.810 installed height so there is room to shim. I wanted to do it, but I was worried about failure just because I have no experience at all doing this and it's not my motor. Is there any risks in your opinion? I just don't know if the solid lifter will hold up over time as the hydraulic lifter will. I didn't go solid cam because I was told that the size I wanted was too small for a true solid cam profile. So, he told me I needed to go hydraulic with solid lifter. But I never heard of doing this before so I felt uncomfortable trying it.
Old 02-13-2026, 10:32 AM
Jay S's Avatar
After thinking about this. I wouldn’t use that Butler profile with Solid roller lifters on a Pontiac with Aluminum heads. Even zero lashed cold the hot lash window is to tight. It is the wrong HR profile. That’s needs an HR lifter like an Evolution HR, Gaterman, or Johnson PR lifter. I could show you want the profile should look like if you’re interested in running SR lifters on a HR profile. But I could pick a full SR profile out also. That Butler cam isn’t a good choice for this.
Old 02-13-2026, 11:29 AM
charlie66's Avatar
Ok, I will take your word for it. Looks like I need to go Hydraulic then. What do you feel would be the best Hydraulic lifter for this cam? Butler talks about measuring the base circle to the oil hole in the block with the cam installed. So, I guess I'll have to do that and then find the best one that fit those needs. What do you think is the best/strongest lifter out there that you would use? After all the axle and wheel sizes you were talking about, I'm figuring you may know what the best choice will be. Is there a brand that you like best. I don't have much experience with hydraulic; I usually only use solid. But this motor is just a mild streetcar for a friend. In the past ive used comp Crower and recently Bam. But I don't think Bam makes Hydraulic lifters or I would buy them. Back in 2004 I had some bad luck with a set of Comp rollers. The caps for the axles were walking out of them. I'm lucky I caught it. That was the last time that I used Hydraulic.
Old 02-13-2026, 01:24 PM
Jay S's Avatar
Both BAM and Gaterman are ran by people that came from Crane. They are separate companies, but Gaterman to me is the hydrualic roller counterpart to BAM. If Gaterman lifters are in stock they are my first pick. They have pin oiling and a better plunger feeding features than all the other HR lifters. I wish they had floating axles like most SR lifters, but Morel is the only ones that have that feature. Morel doesn’t have enough control on the bleed rates for that cam. You are not the first person to have the staked axles slide around.
If the Gatermans aren’t available a Comp Evolutions are my second choice unless the springs are extra heavy.
Old 02-13-2026, 02:12 AM
Jay S's Avatar
I am coming up with a 336 lb per inch spring rate with the numbers you mentioned. Is that a single flat tappet spring? Or is it a dual? A dual might work with a shim if that number was measure from a tester on the actual spring. I need more details on the springs. It sounds a little light unless I figured that wrong. I will double check my numbers.
I wouldn’t be concerned running that cam as a hybrid as long as you set the lash tight like I described. A nice lifter like a BAM with pin oiling would go as long as any HR lifter. They have bigger axles and larger .75” wheels, and are very rugged. All the HR lifters are .7” wheeled and have much smaller axles and bearings. Usually the Sat lifter are overkill unless you over spring it and run the lash loose. I have done $450 Doug Herbert (Morel) pin oiled lifters on hybrids and they have worked great for the money. Crower cutaways and Comps Endurex have been ok also. I think BAM is the top mechanical lifter though.
As far as what works as a hybrid, and what doesn’t, my general rule for mechanical lifters on hydrualic cams is to check where the tappet has 1* change in duration per .001” degree in lift on the closing side of the cam. On an Extreme energy Comp like yours that is about .006” tappet lift. If you multiply .006” tappet times the rocker ratio, that is the max ideal lash it should run when everything is expanded hot. The same pretty much holds true with a full mechanical cam. If the engine expansion creates to much lash and the lash is much beyond that hot lash it is adding to much acceleration to the valve terrain, and you really need as SR profile or a lazier HR profile. If you can set the lash tight enough cold that it can stay below that number hot after expansion, the solid lifters work well. If you don’t like it, it is a roller cam, you can swap any roller lifter back on it.
Old 02-13-2026, 02:23 PM
67Lemons 67Lemons is offline
Good luck, I occasionally check for the Gaterman GP-1008 on their website and can never find them in stock. The only place I’ve seen them is on the Schneider cams website and they aren’t cheap, I decided on the Comp Evolutions for about the same money.
https://www.schneidercams.com/HYDROLLERlifter5610.aspx
1972 GTO
Old 02-13-2026, 02:35 PM
grivera's Avatar
grivera grivera is offline
I have the evolutions on my 66 with the Old Faithful 1 cam, but very little run time on them. They do make a sewing machine sound at 800-850 rpm. https://www.youtube.com/watch?v=RP_s1wJKm_Y
Will Rivera
The Following 2 Users Say Thank You to grivera For This Useful Post:
Old 02-13-2026, 03:05 PM
Jay S's Avatar
Nice car 66!
For Gaterman’s call them directly. They can check who has them in stock or when the next batch is available.
The Following 5 Users Say Thank You to Jay S For This Useful Post:
Old 02-14-2026, 03:04 PM
scott70's Avatar
scott70 scott70 is offline
I thought the evolutions were quiet? I have a set ill be installing in the next month or 2.......or 3.
Old 02-14-2026, 05:08 PM
grivera's Avatar
Relatively speaking, they are. It’s a sewing machine noise, vs a ticking noise like other brands.
Will Rivera
Old 02-14-2026, 05:10 PM
I agree, I was under the impression that the Evolutions were quiet but I was also under the impression that tappet noise can also be a function of steep lobes so with a roller is that worse?
1972 GTO
Old 02-14-2026, 08:09 PM
scott70's Avatar
Yes,,,I actually thought of the aggressive lobe thing after I wrote it.
Old 02-13-2026, 06:09 PM
Dragncar Dragncar is offline
I like the idea of just running a smaller solid roller and DLC BAM lifters. Then run a stud girdle to help keep lash.
Too many horror stories with Hyd roller lifters for me.
These things are EXPENSIVE and take so much time and effort to get right to mess with them IMO.
Those lifters on a small cam would last just about forever. Many OEM cars run solid lifters. The wife's Volvo even has solids.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 02-13-2026, 07:41 PM
Region Warrior's Avatar
Why hydraulic anything? Solid been king since 50s.Go SFT dont look back! Have spare 255/263 on shelf for 20 some yrs jic one from 90s gos bad.Had relplace some lifters and springs. Thats easy!
Old 02-13-2026, 09:50 PM
I run 150 on the seats with the Evos.Tom
Old 02-14-2026, 12:55 AM
I have a all broken in Crower sft that will get over 500 HP just sitting on a shelf.
I would run it before any hyd roller.
Old 02-14-2026, 11:52 AM
AG's Avatar
AG AG is offline
I have Johnson's (not Hylift Johnson's) and decided to use them after speaking to them directly and being told they are 100% manufactured in the US. Have not used them yet, but I have used Comp Evolution and was happy with them.
The Following User Says Thank You to AG For This Useful Post:
