#981
The crank pulley looks small thats offered in the aftermarket (6"). Why would anyone want to underdrive the waterpump and alternator?
#982
The billet crank pulley in my kit is 7-5/16", which is the same diameter as the OEM single-groove A/C crank pulley that would've been stacked behind an 8" 2-groove WP/Alt crank pulley. Wish they had just sized the thing up to 8" rather than size down to 7-5/16". Or better yet, machine the thing so it functions identically to the OEM setup and has two different diameters.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
#983
I have a cold case in the car right now. What is the absolute best radiator I can get?
#984
You need a severe duty fan and clutch. Going to be hard to keep that thing col with A/C. '64's just don't have much room for a big radiator.
#985
Also, did you ever put a timing light to it for idle/vacuum advance timing measurement?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#986
My timing light sucks and I can’t see it. Waiting on my nephew to come.
#987
The CVF pullies I have on my non-A/C GTO are both 6.2", (crank and WP), for a 1:1 ratio, (or 100%). The High-flow that CVF offers is the same 6.2 wp pulley with a 8" crank, for a 129% overdrive. I'm going to try a 8" wp pulley to underdrive it to 77.5% of crank speed. My engine idles at 1000, (manual trans), so the water pump will still be turning at 775 rpm. I run a flex fan with no cooling issues, but I don't like the fact that the fan is turning 6000 rpm at my shift points. By underdriving it 77.5%, at my 6000 rpm shift point, the fan will now be turning only 4650 rpm. Less stress on the fan blades and less drag.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto |
#988
[QUOTE=Singleton;6348546]Typically, Pontiac had their non-A/C engines underdriven by 8 to 15%.(water pump driven at 85-92% of crank speed).
Agreed, however Pontiac engineers weren't dealing with todays higher hp applications and performance standards. Also today's fuels don't provide the cooling and lubrication affect of the 60s and 70s. |
#989
its an airflow issue. At 220 my dash light comes on. As soon as I start moving I drop to 185 within 2 miles. I am gonna have to get an electric fan.
#990
I know yall are gonna think I am crazy but this mechanical fan really does not move any air. I expected a roar too and I dont have one. And before anyone asks yeah its on right LOL
#991
What clutch do you have. I have a heavy duty and a severe duty for my car. Significant difference between the two. NOTHING will pull more air than a severe duty clutch fan in my opinion.
#992
I have tried all of the above. Mechanical now. I am sending it back and putting electric
#993
Look at this POS I started with
#994
Some quick math. Pontiac AC pulleys were about 8" on the crank and 7" on the water pump in round numbers, and that produces a 114% overdrive ratio. One of the aluminum pulley kits that Butler sells has the bottom pulley about 7-1/2" and the top pulley about 6-1/2" for an overdrive ratio of 115% -- which is close enough to call the new kit's ratio even with the old stock AC setup. Have this pulley kit on the Catalina wagon with the 496 and it runs very cool. Should mention that everything has been done besides the pulleys including a beta test Cold Case Radiator for the '65 B-bodies, plate setup, SD fan clutch with 19.5" fan, shroud, etc...
Anyway, the overdriven aluminum pulley kit works good.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
#995
Make sure you choose an electric that moves enough cfm - like a Mark VII, otherwise you'll likely be worse off than now. Also it will have to be a type with a shroud not the sheet metal that's attached to radiator - those block airflow. Lots of info on this in cooling section.
#996
Cold case told you to get some miles on it before changing a bunch of parts if I'm not mistaken from a previous post? drive the car and see what happens as the engine breaks in, obviously if its getting up around 230 and puking water out make some changes then.
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt |
#997
So before I take the plunge does anyone have anything against electric fans?
#998
NEVER needed one in 60 years.Tom
| The Following User Says Thank You to tom s For This Useful Post: | ||
#999
" Darksiders Rule "
| The Following User Says Thank You to misterp266 For This Useful Post: | ||
#1000
Yes the light came on and it got to 230 today
