Old 07-01-2008, 04:20 PM
Brewster's Avatar
Brewster Brewster is offline
Default Picture of original plug:
Here is another picture since someone pulled my previous one using Photobucket???????
Notice the paint residue left from years of use!
Brew
  #1002
Old 07-01-2008, 07:10 PM
Brewster's Avatar
Yeah Bob, I think after all these conversations/replies we'd get something to help us keep organized? come one people let us get updated!
B
  #1003
Old 07-01-2008, 07:14 PM
ramair3formula's Avatar
ramair3formula ramair3formula is offline
Bob, I'm with you. I will not be duplicating the over spray on the bottom of my cars.
1972 Trans Am white with blue deluxe interior
1974 SD Trans Am white with tuxedo interior, earliest known 74 SD vin#
1976 50th Anniversary Trans Am
1970 Judge ra3 4 speed pepper green
  #1004
Old 07-02-2008, 08:45 PM
FloridaFirebird FloridaFirebird is offline
Okay SD gurus.......... Does the pcv valve on the SDs work well given the fact that it basically lays horizontal as opposed to the standard Pointiac fare where it sits vertical in the grommet in the valley pan? Or is the PCV valve a differenct part number. It seems to me that laying flat the PCV has no resistance either way when lying flat.
THanks in advance
FF
  #1005
Old 07-07-2008, 11:34 AM
Brewster's Avatar
FF,
I can't speak for the 1974 cars but I do now they work in the horizontal position on the 73 cars. I have noticed no carry over when pulling the line off the carb and I figure its due to low vacuum or not enough air born material to be conveyed.
The 73 version is re-poped by someone on epay who charges 250.00 each for the oil cap assembly.
  #1006
Old 07-07-2008, 12:56 PM
toomanybirds toomanybirds is offline
The PCV valve functions the same, vertical or horizontal.
Engine vacuum pulls the inner part of the valve closed, letting a restricted amount of crankcase vapor enter the intake manifold. When vacuum drops, the valve opens allowing a higher, unrestricted volume of vapors to pass through the valve. All Pontiac PCV valves are connected with a hose to a fitting on the intake manifold, not the carburetor
73 and 74 SD-455 PCV valves are the same, with the valve connected to the rocker cover cap by a curved hose. This was an attempt to reduce oil consumption in the SD engines.
The SD-455 PCV valve was a late change in production SD engines. All SD cars came with the same PCV valve, but the cap, the curved hose, and the plug in the valley cover were never listed in any parts book, and replacements were not available.
Original rocker cover caps and valley cover plugs for the SD-455 are hard to find, but repros have been made.
  #1007
Old 07-07-2008, 01:28 PM
Brewster's Avatar
Yeap, Yeap, Yeap, Yeap, Yeap!
It does connect to the intake to an 90 degree elbow fitting an inch before the carb. Been a while since I've played in that area and talked before I thought, Hmmmmmm, imagine that!
Thanks for the clarification on it toomanybirds,
Brew
  #1008
Old 07-08-2008, 09:37 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Default Please check my "wanted" ad . . .
http://forums.maxperformanceinc.com/...d.php?t=567160
Thanks, guys!
Regards,
"455HO" Lloyd
  #1009
Old 07-11-2008, 11:04 AM
Brewster's Avatar
Hello Lloyd,
I'm sure Mike must know that these cars have tripled (if not more) in value and hope he doesn't get stick shock!
Well put the word out on the streets and see if we can get something for him to review.
Cheers,
Brew
  #1010
Old 07-11-2008, 11:59 AM
Lloyd-TX's Avatar
Originally Posted by Brewster View Post
Hello Lloyd,
Cheers,
Brew
Thanks, Brew.
Regards,
"455HO" Lloyd
  #1011
Old 07-12-2008, 12:25 AM
Shift'n Gears's Avatar
Shift'n Gears Shift'n Gears is offline
Lloyd,
I am not sure if it is still for sale but I saw it a while back... 73 SD455. They had both a 73 and 74 Buc Red Auto cars for sale. Hope it works out
#'s match, factory A/C, totally restored
www.loriaselectmotors.com
(407)834-6100 Florida
Regards,
John
Oh and if you ever hear of a 73 Buc Red, 4 sp Basket case... I'm interested. (dreamer wanting a 4sp sd)
1978 Y84 4sp
1979 T/A 400 4sp Blue/Oyster (special order)
2000 T/A WS6 6sp Black/Black
  #1012
Old 07-12-2008, 06:33 AM
1stgenbird's Avatar
1stgenbird 1stgenbird is offline
Stopped by the shop that did the paint job on my car and this was parked out front.
ID:	136054   Click image for larger version
  #1013
Old 07-12-2008, 11:52 AM
Larry Navarro's Avatar
1stgen, the grill/nose area looks to be of the '70-'72 variety.
  #1014
Old 07-12-2008, 12:52 PM
1stgenbird's Avatar
Huh. So, either someone changed the grill or dropped a SD 455 in an earlier ta.
  #1015
Old 07-12-2008, 02:53 PM
x-bird2 x-bird2 is offline
or put a sticker on the shaker.
  #1016
Old 07-12-2008, 03:01 PM
Norwood's Avatar
Norwood Norwood is offline
My thoughts......Its cheaper
  #1017
Old 07-13-2008, 09:12 AM
1stgenbird's Avatar
I'll find out the real story.
  #1018
Old 07-14-2008, 12:58 AM
chuckies76ta's Avatar
Default Who has this car?
Who has this SD CAR?
Charles
http://www.sd455registry.com/cgi-bin/sd1.cgi
1974 Trans Am 167355 THM 400 3.42 Blue Blue cust
FMSt F R Bird PW Tint
Montreal Quebec 59000 Defrost - Moldings 4-2008
Edit/Delete Message
  #1019
Old 07-14-2008, 10:01 AM
spb350 spb350 is offline
Anybody interested in this setup: 70 YH block .030 over TRW forged pistons(10.85 comp) 16 SD heads, SD rods, RA IV dist, RA IV pushrods and guide plates, RA IV Crane cam, Rhoads lifters, brand new unused Richmond 5 spd, Mcleod 30# steel flywheel, new Hurst shifter, etc etc.... Also comes with SD exhaust manifolds, modified driveshaft and cross member. This setup is all new and has never been run, ready to drop into a 70's TA. Looking around $11k I'm thinking about putting it in my 73 TA but? email me
73 Trans Am Red/White #'s match 4spd...... sold
69 Firebird 400 conv #'s match AT Blue wht/wht
06 Vette conv Red/Red/Blk
  #1020
Old 07-14-2008, 03:31 PM
takid455 takid455 is offline
Send a message via AIM to takid455
when was the last SD produced? my 74 has a build date of 6/74. this seems to near the end of 74 production.
