Old 03-21-2016, 06:19 AM
njsteve's Avatar
njsteve njsteve is offline
.030 Speedpros. Here's some shots of parts:
ID:	424128   Click image for larger version
ID:	424129   Click image for larger version
ID:	424130   Click image for larger version
ID:	424131   Click image for larger version
The Following User Says Thank You to njsteve For This Useful Post:
  #1002
Old 03-21-2016, 02:21 PM
SD455DJ SD455DJ is offline
Steve - what is the static compression ratio? Mine measures 8.2 to 1 and is 0.030 over CCP pistons on stock cast rods (unfortunately), so it was probably not decked and the heads cut minimally for flatness.
Dennis
  #1003
Old 03-21-2016, 02:28 PM
njsteve's Avatar
I didn't check the final comp ratio on that engine like we did with my Gramma Car's 455 engine build, so all I can do is assume it is around the factory spec since we did not have to resurface the heads at all and left the block surface as-is. She ran very strong (as Bob can attest to). :-)
  #1004
Old 03-24-2016, 08:06 PM
Bentwheelbob's Avatar
So, some copper plated cotter pins were needed for the Black Cars front steering gear, but no one sells them. Thus, me and Mini Me had a science experiment in the garage tonight and made some. They came out pretty well, and the whole experiment was really cool. It only took about 10 minutes in the solution. I'm going to experiment some more. I want to bead blast the cotter pins first and use a better copper source than cheap pipe. Here's the pictures.
  #1005
Old 03-24-2016, 08:11 PM
Pepi's Avatar
Pepi Pepi is offline
That's cool, looks like they turned out pretty good.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #1006
Old 04-09-2016, 07:17 PM
Well a few things have gotten done lately. Spring Break and a bum knee have slowed things down a little, but we are still moving forward. I sent some stuff off to Colorado Plating (formerly Aero Propeller) and got it back the other day. This included the cowl vent frame that one of the best restoration guys in the biz told me was originally gold cad. The vent is now all back together and looks pretty good. The driveshaft has been media blasted and is taped off for striping as well. I am not going to paint the tube itself or the yokes, I am going to treat them with Rust Prevention Magic once the stripes are painted. The jack shaft also is back from cad plating and looks great. I think I'll coat it with some satin clear for protection. Lastly, I've been looking for some small parts and pieces storage and got this great cabinet setup from Fastenal. It has twelve removable drawer cases, and there are 4 different drawer configurations. Here's a few pictures.
  #1007
Old 04-10-2016, 01:05 PM
Formulabruce's Avatar
Sent you an email Bob on the yellow vapor hose clamp below the Booster. Does this car have any yellow spring clamps? ( the ones you are hoarding now? :P)
Name:	clips front 2.jpg
" Long may we DRIVE !"
  #1008
Old 04-10-2016, 03:29 PM
Bruce _ There were no yellow spring clamps. There was the yellow two line bracket you show that caught the vapor line and rear brake. Are you thinking that maybe fuel lines had red pinch clamps and vapor lines had yellow pinch clamps?
  #1009
Old 04-10-2016, 04:54 PM
Yes I am Bob , this one was right at the rubber section, and another was by the radiator where it goes to the "restricted" tube under the radiator and attached to the core support. The cansiter side I am not sure of. I need to also look at the vent line at the rear. This clamp has never been off this car, note edges .. Bruce
  #1010
Old 04-10-2016, 05:35 PM
Go to post #2 on the attached link and note that Greg (165th) used yellow pinch clamps on his EVAP line going from the charcoal canister to the hard line at the core support. I'm sure Greg researched this and it tends to support your theory.
http://www.forums.maxperformanceinc....highlight=EVAP
The Following User Says Thank You to Bentwheelbob For This Useful Post:
  #1011
Old 04-10-2016, 05:57 PM
Great!, Thanks for the link, and info !
  #1012
Old 04-13-2016, 10:14 PM
So, I didn't want the Black Car to feel totally neglected. Tom has been at work on it and has it totally stripped down and should be close to having it mounted on the rotisserie. The blaster is next and I think we are both cringing at what he will find. Those pictures may never see print. Here at the garage I got the driveshaft stripes finished up. I followed 165th's guide and started them 13.5" from the front of the tube, made them approximately 3/4" in width, and spaced them 1/4" apart. I used Quantas marking paint it looks pretty good. I am not going to paint the driveshaft itself. It will be left bare steel and treated with RPM. I look forward to seeing the appeance of it with no paint.
  #1013
Old 04-14-2016, 06:41 AM
The Boss's Avatar
The Boss The Boss is offline
Did you tape those off Bob or did you just hold the brush & rotate the shaft? What is the proper technique?
And go racin' in the street.
  #1014
Old 04-14-2016, 06:57 AM
I wish I was that good. No, I taped it off using 3m 471 1/4" fine line vinyl tape. It is great tape that leaves a very clean line and is the perfect width for the stripe spacing. Sprayed several coats of etching primer after taping and then applied the Quantas paint with an artist brush. I put the paint on somewhat heavy a section at a time around the circumference and then would rotate the shaft several times while lightly holding the brush to the surface to smooth it out. It took three coats. The gun cleaning cradle worked perfect.
Here's a link to the tape.
http://www.ebay.com/itm/3M-Vinyl-Tap...912146&vxp=mtr
  #1015
Old 04-14-2016, 12:35 PM
"The blaster is next and I think we are both cringing at what he will find..."
Bob, I sure can relate to that comment! I sure hope you get a nice surprise and not a mission creep special.
DJ
  #1016
Old 04-14-2016, 01:06 PM
Judge273's Avatar
Judge273 Judge273 is offline
Tom, will share the pix...BTW
Mike/Illinois
  #1017
Old 04-14-2016, 06:16 PM
njsteve's Avatar
DJ
I really think he should pull those "formerly" NOS quarters that were installed in the 1980's and replace the inner and outer wheel houses (which weren't available back in the day and instead were just badly patched). They were installed by the alleged restorer in the 1980's using brazing rod and not by electric welding.
Do it once, right and you'll never regret it.
This way it will be 100% perfect when you sell it back to me. ;-)
  #1018
Old 04-25-2016, 07:28 PM
So the Black Car is stripped, on a rotisserie and headed for the blaster on Wednesday. Tom is taking it to a commercial blasts instead of having a driveway job done which is smart. We've talked, and depending on what we find the car may go to the AMD Installation facility in Atlanta if it needs substantial metal work. Meanwhile Tom has plenty to keep him busy with the front and rear suspension, and front sheetmetal. Sometime in the last week the engine also got painted and is now ready to get a few parts installed, and a few more mocked up if for no reason other than trying to remember how everything goes back together. The paint is the Tiemans formulation.
...and the picture of Anna, well that's just because.
  #1019
Old 04-26-2016, 06:52 AM
The Boss's Avatar
Nervous Bob?
  #1020
Old 04-26-2016, 07:07 AM
Yep, more nervous about what this will reveal than I am about my knee surgery.
