Industry Stuff new repro's, updates, other info.
Old 04-15-2009, 11:09 AM
wrea3_98 wrea3_98 is offline
Default 69 Dash, 69 Hideaway Headlight Covers
Would love to see 69 GTO dash reproduced ( yeah right...) Also like to see
headlight covers without chrome trim molded in, like the originals. They make the smaller one but not the larger one.
  #1062
Old 04-28-2009, 03:48 PM
Squidward's Avatar
Default 67-69 firebird 400 hood scoops
Howz about 67-69 firebird 400 hood scoops that could be grafted onto/into an existing flat hood?
My flat 67 hood fits just fine, but I would like a low cost appearance upgrade that I could add on for lower cost and greatly reduced shipping than a full repop 400 hood.
Stamped steel preferable, would even consider fiberglass.
Might even be able to get these cut from factory rejects that get dented on the edges, etc.
Thanks!
  #1063
Old 04-29-2009, 01:13 PM
TinjunTribe's Avatar
TinjunTribe TinjunTribe is offline
Default 1969 GTO/LeMans Plastic Glove Box Door
Be nice to have a repro glove box door for the 69 dashs (70+ too), just the plastic portion with hinge that rivets to the metal back. One could drill out rivets, buy the repro piece and rivet on....then dye to match.
  #1064
Old 05-05-2009, 03:42 PM
65 Goat 65 Goat is offline
I'd like to see a decent dash pad for a 65
65goat
  #1065
Old 05-05-2009, 06:19 PM
mgoblue mgoblue is offline
I'd like to see the optional stainless rear license plate frame reproduced for my 69 Firebird. I believe this part is shared by several models / years.
  #1066
Old 05-11-2009, 12:48 AM
Widetracker Widetracker is offline
1969 Firebird "batwing" rubber cushon.
  #1067
Old 06-21-2009, 12:03 PM
gtopont gtopont is offline
Smile 65 gto dash pads
how about a 65 gto dash pad that DON'T cover the top of the gauges !the originals are great because you can see the whole dash bezel and its not blocked along the top..
  #1068
Old 06-26-2009, 01:36 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
1969 GTO wiper switch
  #1069
Old 06-28-2009, 12:13 PM
ERIC AULL ERIC AULL is offline
1967 GTO 1/4 PANELS THAT FIT !! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! !
  #1070
Old 07-05-2009, 07:53 PM
lucyblu71ta lucyblu71ta is offline
70-73 firebird/trans am tail panel!!!!!!!!!!!
  #1071
Old 07-13-2009, 09:43 PM
mybad66's Avatar
mybad66 mybad66 is offline
Default repro parts
How bout trim parts for a 66 post car. they are far and few between and i just happen to have one. biggest thing is the rear quarter belt line moldings(diff from HT) and the quarter glass chrome strip with white tab and channel it runs in mounted in the actual post. While i'm here, the upper rear quater glass run channel that runs all the way back into the quarter panel. Oh, and a rear bumper for the 66 would be nice too. Thanks for listening.
MYBAD66
  #1072
Old 07-23-2009, 02:09 PM
Bluethunder1975 Bluethunder1975 is offline
Navy Blue hobnail seat covers for the late second gen firebirds. They make a tan, red, black, and light blue already.
  #1073
Old 07-23-2009, 06:29 PM
lighthouseman's Avatar
lighthouseman lighthouseman is offline
How about the grill outside shell (Chrome) for 1971 - 1972 GTOs. The incerts are now repoped but not the other grill pieces. WOuld also be nice to have the GTO emblem for the 71 too (you can make other year's work, but not exactly the same).
Steve
  #1074
Old 07-28-2009, 10:33 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
How about the metal fuel/brake line brackets that are welded to the floor pans??
The one piece floor pan does not include these and I can't find anyone that makes them.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
  #1075
Old 08-03-2009, 08:19 PM
dinode dinode is offline
1973 lemans/GTO seat covers and Dash pad and/or cap.
  #1076
Old 08-04-2009, 09:09 AM
Thomasmoto's Avatar
Thomasmoto Thomasmoto is offline
79-81 Trans Am/Firebird turn signal lever without cruise or tilt
79 Pontiac Trans Am
  #1077
Old 08-05-2009, 11:39 AM
66GTO Jim's Avatar
66GTO Jim 66GTO Jim is offline
Default Wide angle passenger side mirror 66/67
Outlined in the following thread is how to install a wide angle mirror on a 66 manual mirror housing for use on the passenger side, just like the newer cars have. After thinking about this, it shouldn't be hard for the mirror manufacturer to manufacture and install a wide angle mirror in this housing or make the wide angle mirror glass itself available cut to size for the hobbyist to install themselves.
I believe Ames supplies these mirrors for all the vendors, so maybe you can contact them about this.
Here's the thread:
http://forums.maxperformanceinc.com/...ghlight=mirror
Jim
"Never try to teach a pig to sing. It's a waste of time and it annoys the pig"
  #1078
Old 08-05-2009, 05:29 PM
motman motman is offline
ANYTHING for the 1981-87 Grand Prixs
charleston. w.v.
  #1079
Old 08-20-2009, 10:34 PM
GT182's Avatar
GT182 GT182 is offline
How about a complete shoulder belt kit for 66 and up A bodies. It's a hard to find item, but when you do they're not in very good shape and missing some of the important parts.
I had shoulder belts in the 66 GTO I bought back in 1970. And it was a nice accessory, of which I've not seen in any 66 GTO again. At least not around here.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #1080
Old 08-26-2009, 05:47 PM
67cruiser 67cruiser is offline
Would like to see top section of the quarter panel into the trunk with weatherstripping lip.Plus into the tail lite area. For a 1966-7 GTO LEMANS
