Old 04-25-2015, 11:28 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Explain this footer comment Ed: Twin 88M Turbo Rebuild.
That implies that there was something wrong with the Turbonetics T-88 Turbos.
You have never run the turbos, period on any engine.
I would change that to Twin 88M Turbo INSTALLATION Redo.
Just saying.
Tom V.
Tom,
Would it make more sense to all if I quoted “McCarty/BES Racing Engines/IndyCartel 535 EFI RA-V Twin 88M Turbo Rebuild”? This was a supposed to be a package deal, right? The engine has already rebuilt once and now the entire McCarty top end is being replaced. I don’t believe the statement above references any specific turbo brand. You’re right I haven’t run the 88mm turbos I have on any engine yet. I would have really liked to have had the “original” combination dyno tested and tuned with the turbos and Holley dominator EFI before it was shipped to me. I believe you are well aware of the backstory regarding why this wasn’t done. Changing my signature to “Twin 88M Turbo INSTALLATION Redo” would indicate I installed the turbos, which to date I haven't.
On a positive note, the new DCI Motorsports RA-V top is coming along great.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1062
Old 05-08-2015, 11:35 AM
dci dci is offline
Here are pic's of Ed Pages heads. In his thread are the flow numbers for his heads. You may have notice we softened the combustion chambers up a little for the turbo's. Porting is done, guides are sized. Now all I have to do is mill the deck to get the combustion chamber size we need and o ring them for the copper head gaskets. Then I can clean and assemble.
ID:	397146   Click image for larger version
ID:	397147   Click image for larger version
ID:	397148   Click image for larger version
ID:	397149   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #1063
Old 05-08-2015, 11:55 AM
428RA4's Avatar
428RA4 428RA4 is offline
beautiful work Don. Really cool intake port configuration as well.
Old 05-08-2015, 12:16 PM
dci dci is offline
Thanks Mike. Your venture is looking good too!!!!! How much have driven your 5 engine and how's the torque curve? What rear gear do you run?
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1065
Old 05-08-2015, 12:23 PM
428RA4's Avatar
Hey Don -
I took the car out about 3 weeks ago and gave a friend an oh Sh*t ride. Driving down the blvd. grabbing 3rd gear with my foot buried, a cop was going in the opposite direction stuck in traffic. Needless to say, I kept my foot there and proceeded to run for cover in a maze of sub-divisions. Lucky I got away.
The car is not running all that great as the gaskets on the bowls and
accelerator pump is spitting out fuel. The throttle shaft is also shot at this point and in need of being bushed. Damn thing sits more then I drive it, so she needs some more love and money as usual.
I've never had the chance to dyno the car at this point. Maybe some day soon hopefully, but there are so many irons in the fire at this point.
I'm running a 3.08 rear end with an old school Doug Nash 5 speed. First gear just roasts the tires beyond belief.
Old 05-08-2015, 10:55 PM
RAIV-Z's Avatar
Floor just about done, transmission tunnel next.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1067
Old 05-13-2015, 08:27 PM
RAIV-Z's Avatar
In keeping with the classic Pontiac 5 spoke look.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1068
Old 05-14-2015, 08:33 AM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
... your bird is gonna be badazz !! ...
  #1069
Old 05-14-2015, 08:46 AM
twov8sandat4's Avatar
twov8sandat4 twov8sandat4 is offline
What wheel is that?
Do you expect to have the car done this year? I would love to come up to NED to see it run
Panos
Little Miss G Racing on Youtube
  #1070
Old 05-14-2015, 05:39 PM
RAIV-Z's Avatar
Originally Posted by twov8sandat4 View Post
What wheel is that?
Hey Ed,
They are Mickey Thompson Pro 5 ET Drag. We do have a bit of work left to do, but I expect the car to be done and out at the track this year. We should be swapping out the top end soon, Don's almost finished with the heads and Mark "Luhn Performance" is working on the intake.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1071
Old 05-16-2015, 02:07 PM
dci dci is offline
Just finished dry decking Ed's DCI RA5 heads. Next is milling them to get the desired combustion chamber volume and O-ringing them. With the thick deck I designed into my heads. It sure makes this procedure allot easier than some I have done in the past. Most heads have thinner decks and you cannot just drill and tap them,they need welded.
ID:	397946   Click image for larger version
ID:	397947   Click image for larger version
ID:	397948   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1072
Old 05-16-2015, 04:41 PM
Tom Vaught's Avatar
Boost Engineer
Very nice feature and would allow sizing the plugs for coolant flow on a street application.
Good Job Don!
Tom Vaught
  #1073
Old 05-18-2015, 02:23 PM
Hey Ed,
I am not Ed, but thanks for the response
See you at the track
Panos
  #1074
Old 05-21-2015, 06:35 PM
RAIV-Z's Avatar
Rear M/T wheels arrived a few weeks early.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1075
Old 06-05-2015, 04:18 PM
RAIV-Z's Avatar
Decided to go with a Precision Performance Products shifter over the Cheetah Turbo Action. Both are quality pieces, but after trying out both, I preferred the feel of the PPP shifter.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1076
Old 06-16-2015, 06:05 PM
RAIV-Z's Avatar
Front and rear tires showed up over the weekend.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1077
Old 06-16-2015, 07:55 PM
cgeise's Avatar
cgeise cgeise is offline
Very nice shifter - I have one in the GTO -- the safe neutral in front of 3d is nice when your racing
  #1078
Old 06-16-2015, 09:06 PM
mgarblik mgarblik is offline
Man that deck is thick!! Looks like over .750. That will do more to keep the head gaskets on the engine than you can believe. The extra clamp load it provides is fantastic and necessary with the turbos. That's putting a little extra weight where it is desperately needed. Also love the wheels. This is going to be a special effort, high quality car. Looking forward to seeing it on the track.
  #1079
Old 06-17-2015, 01:35 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Clever shift sequence.
  #1080
Old 06-17-2015, 03:47 PM
Rob B's Avatar
Rob B Rob B is offline
Reverse valve body.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
