Old 02-19-2017, 08:22 PM
RamAir's Avatar
RamAir RamAir is offline
It's going to be the nicest F-body Pontiac in existence
  #1062
Old 02-20-2017, 09:00 AM
The Boss's Avatar
The Boss The Boss is offline
Originally Posted by Norwood View Post
I used to joke that in all the years I had known Brewster he had never put gas in that 73 4 sp
That's funny!
He'll drive it, do a big burnout for us too - right Bob?
(Right after judging at MCACN)
And go racin' in the street.
  #1063
Old 02-25-2017, 07:11 PM
Bentwheelbob's Avatar
Dave does the burn outs while I man the camera and provide commentary. I promise a burn out, but it will be after TA Nats and MCACN....I can't wait.
A lot has gotten done the past few days by me and MPD. It's almost time to swing the engine off the stand, hook up the tranny and swing it into the subframe. I'm excited to get this part finished and move onto the next subgroup on the list.
The front suspension and steering parts are all finished and now installed. I elected to not paint most components and used Rust Prevention Magic ("RPM") on the bare steel instead. It doesn't' took as perfect as painting everything, but I think it looks more correct and is certainly more durable. I did a test strip of metal with RPM 14 months ago and it has been outside the Hot Rod Garage since then weathering. A picture is below. The parts I have done since then have been prepped and coated even better.
Lastly, the wheels are now done and ready for rubber. Hopefully next weekend the wheels will get mounted and the engine/Trans assembly installed. Here's a few pictures.
  #1064
Old 02-25-2017, 08:16 PM
Brewster's Avatar
Brewster Brewster is offline
Looking good Bob, cant wait to see the finished car.
  #1065
Old 02-25-2017, 09:27 PM
Pepi's Avatar
Pepi Pepi is offline
Bob, looks good. You and Dave really out do yourselves. Can't wait to see more progress pics and the final assembled car.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #1066
Old 02-25-2017, 09:57 PM
Norwood's Avatar
Norwood Norwood is offline
Simply Outstanding
  #1067
Old 02-26-2017, 09:30 AM
starlightblack's Avatar
starlightblack starlightblack is offline
Real nice Bob
  #1068
Old 02-26-2017, 10:24 AM
The Boss's Avatar
Porn!
  #1069
Old 02-26-2017, 07:09 PM
Well, a little got done today. I sorted a bunch of parts and started making lists, but on the more productive side the engine harness has been installed and distributor and wires are in place. Also, the starter got fit so we could check all the wire connections and lengths. Everything worked out well, but it was pretty tedious getting everything routed in the proper way.
One issue is the old harness from the Black Car had a piece which clipped into the AC compressor plug which mounts on the upper AC bracket. The new harness did not have this piece included and we probably spent an hour getting it extracted from the old harness. We actually had to destroy the female harness piece to get the male plug removed. Their were double trips and none were accessible. Does anyone know what this piece does? It is pictured below.
  #1070
Old 02-26-2017, 07:11 PM
RamAir's Avatar
It's a thermal limiter switch for the A/C compressor Bob
  #1071
Old 02-26-2017, 07:31 PM
Judge273's Avatar
Judge273 Judge273 is offline
Did not know AC could look that good?
Mike/Illinois
  #1072
Old 02-26-2017, 08:37 PM
Norwood's Avatar
Everything looks so good
  #1073
Old 02-26-2017, 08:45 PM
Pepi's Avatar
X2, and yes that engine looks really good.
  #1074
Old 02-26-2017, 09:04 PM
njsteve's Avatar
njsteve njsteve is offline
Bob, that was a new harness I installed on the car. Are you saying the new, newer harness you bought didn't have the thermal limited connector, or just the thermal limited fuse itself? The system won't run without that fuse. They are designed to "pop" if the pressure or heat gets too high. If there is a bulge or melted indent in the body of the fuse, that means it is blown.
  #1075
Old 02-26-2017, 09:11 PM
The new harness did not have it. It does now, but it was destructive getting it out of the old harness. There must be a trick, but we have picks and release tools and none would do it.
  #1076
Old 02-26-2017, 09:48 PM
njsteve's Avatar
Those A/C thermal limiter fuses can get pretty warm and tend to heat the prongs enough to melt them into place.
Is the new harness built for a unitized ignition with a direct 12 volt feed to the coil and no resistor wire?. I figured I'd ask since I ran into one that was manufactured wrong for my 1972 T/A a few years back. Took me a year to figure out that they left out the resistor wire and it fried points on a weekly basis. You don't want the opposite where you get too little voltage and it ruins that NOS coil.
  #1077
Old 02-26-2017, 10:52 PM
It wasn't fused together, it was purely a mechanical connection and due to the design of the fuse there is no real way to get a trip tool into the assembly to release it.
It is the correct harness for a unit distributor.
  #1078
Old 02-27-2017, 03:14 PM
4birds's Avatar
4birds 4birds is offline
Very nice. That is a work of art!
One question Bob, how do you get the coil springs in without gouging them up?
  #1079
Old 02-27-2017, 06:44 PM
Use a coil spring compressor like the one pictured in the link below. Remove the sliding set of arms and only use the threaded arms. Insert the threaded rod through the upper shock mounting hole and grab the coil spring three or four coils up from the bottom. Before starting to compress the spring hook a ratchet strap to opposing ends of the subframe on the side opposite the spring in question, with the strap wrapped twice around the coil spring one coil down from where the compressor is hooked. Begin compressing the spring and as it nears the point where it is compressed enough to start moving into the spring pocket start putting tension on the ratchet strap to pull the bottom into the pocket. Slowly alternate between compressing the spring and tightening the ratchet. As soon as you possibly can get a floor jack under the lower control arm to firmly hold it in place at the highest elevation possible. Once the spring is in place use the floor jack to compress it enough to get the spindle installed.
A few keys:
1) These springs were powder coated which of course is more durable than paint.
2) Even more important than that is "prick punching" or stippling the the inside of the compressor fingers with a hardened punch. As new, these arms are very slick and tend to want to slide around the coils which destroys the finish. By prick punching the inner surface of the fingers you create a surface covered with sharp bumps that bite into the finish and spring metal, and eliminate almost all tendency to slip.
3) In addition to the ratchet strap we also used a rubber coated heavy steel choker for safety.
4) Grease the threads on the compressor liberally.
5) The ratchet end of the strap should be located in the direction you need to pull the spring bottom.
Hope this helps. A lot of this is widely known, but I've seen very few folks abrade the arm surfaces to eliminate slippage.
http://www.ebay.com/itm/New-Coil-Spr...754920&vxp=mtr
  #1080
Old 02-28-2017, 12:41 PM
4birds's Avatar
Thumbs up A Different Approach
Thanks Bob! That is great detailed information. My last 2 sets I installed I compressed from the bottom, and had a hell of a time and scratched up the powder coated springs. I will give this method a try.
