Old 03-05-2017, 12:21 PM
Bentwheelbob's Avatar
Thanks for the kind comments. I confess to being slightly OCD. Believe me there have been plenty of messes, but generally the largest problem is dog hair. RamAir would call that a First World problem, and rightly so.
I need a little help here on some clips for the transmission. I have attached below a picture from the assembly manual. What I am looking for are clips 2, 3, 5, and 7. I see that Ames lists clip 5, but can't find the others. Clip 2 looks like something the could repurposed from under the hood perhaps. Clips 3 and 7 seem very specialized though.
Does anyone have: 1) A source for these; 2) Used ones they would part with; or 3) a good picture showing these clips?
Thanks for any help, and again, thanks for the kind words.
  #1102
Old 03-05-2017, 12:59 PM
Pepi's Avatar
Pepi Pepi is offline
Default Pictures of my 73 clips
Bob,
I see #2 is the same as the 73's according to the manual. I would post pictures of mine, but I figured you have your 73 to compare it to.
Also, look at page 8D4. That was a reference I was thinking of in your 73 thread that shows the evap hose routing under the compressor instead of over it like I saw in one of your pictures. Not saying yours is totally wrong, we all know how these manuals aren't always followed.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #1103
Old 03-05-2017, 10:20 PM
Held for Ransom's Avatar
http://www.forums.maxperformanceinc....d.php?t=789861
  #1104
Old 03-05-2017, 11:59 PM
Inline Tube sells retainer #3 and clip #5. Can't comment on quality.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=190908903327
http://cgi.ebay.com/ws/eBayISAPI.dll...m=181201763934
  #1105
Old 03-06-2017, 12:30 AM
Thanks Mike. Bought those parts. 2 doesn't bother me much, but 7 would be nice to find.
  #1106
Old 03-06-2017, 04:45 AM
Norwood's Avatar
Norwood Norwood is offline
Looks like a smart guy might be able to make a 5 into a 7 and have a 2 left over. Just sayin
  #1107
Old 03-10-2017, 09:42 AM
Norwood's Avatar
Old 03-10-2017, 10:16 AM
njsteve's Avatar
njsteve njsteve is offline
I was told there was not going to be any math in this thread.
  #1109
Old 03-10-2017, 11:07 PM
OVERULD's Avatar
OVERULD OVERULD is offline
It's easy if you remember to carry the Naught!
BJ
  #1110
Old 03-11-2017, 05:18 PM
Well, a lot of little stuff got done today. All the vacuum lines are installed. The air cleaner assembly and associated mess has been fitted and installed. Two of the four transmission TCS wiring brackets are in place. The fuel lines are installed and ready. Not much more before this gets a cover put over it and the next piece moves forward. I also mailed out the AC suitcase and seatbelts for rehabilitation, and ordered date code top post clamps for everything from the heater hoses to the heat riser elbows. I love the weekends. Here's a few pictures.
  #1111
Old 03-11-2017, 05:20 PM
RamAir's Avatar
RamAir RamAir is offline
I can't stop looking, excellent
  #1112
Old 03-11-2017, 05:30 PM
Norwood's Avatar
Are thise nos spring clamps ?
  #1113
Old 03-11-2017, 07:02 PM
weranc55's Avatar
weranc55 weranc55 is offline
Who did you send your seat belts to the restoration?
  #1114
Old 03-11-2017, 11:37 PM
I know they look like "mint" NOS, but they have been touched up and painted. A secret for installing these is to wrap gorilla tape around the tips of your slip joint pliers to keep from scratching the finish.
I did zero homework on this and just shipped them to Ssnake-Oyl. I've never heard any complaints about them other than the cost.
  #1115
Old 03-12-2017, 05:30 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Who did you send the suitcase to for restoration?
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #1116
Old 03-12-2017, 08:40 AM
Judge273's Avatar
Judge273 Judge273 is offline
That's one well grounded engine...
Mike/Illinois
  #1117
Old 03-12-2017, 09:31 AM
The Boss's Avatar
The Boss The Boss is offline
Stunning - and to think the line workers did it all in a matter of minutes.
And go racin' in the street.
  #1118
Old 03-12-2017, 04:58 PM
Yeah, I wish I had all the parts and pieces at my disposal that they did.
A little got done today. I set up the phosphating/parkerizing stuff and did both some black and gray parts. In gray I did the prop valve bracket, Z-bar, and inner fender large cup washers. In black I did the ram air boot ring screws, some carb bolts, the AC bracket that mounts to the compressor, and a few miscellaneous fasteners. It's amazing how differently the various pieces take finish. The one that was most resistant was the AC bracket. I cooked that in the same sauce I did the black fasteners in and it looks about like the lighter of the two prop valve brackets. I even cooked it for an hour while the other black fasteners only took about 10 minutes. Also, I did two original large cup washers and four I got from AMK that were rusty. The originals took on much less color than the ones from AMK. Here's a few pictures.
  #1119
Old 03-12-2017, 08:06 PM
It's a private contractor in Texas that used to work for Classic Auto Air doing similar restorations for them. I've never used him, but have talked with others that have and they were very positive. Once the work is done and delivered I will be glad to share a report and feedback.
  #1120
Old 03-12-2017, 08:16 PM
Judge273's Avatar
You have and extra valve holder? Or can I send some of my parts to you for making them blackish?
Mike/Illinois
